The Chase Bays booster has 4 threaded bosses on the back with studs that go through the firewall, this is common for the BMW E30 and mk2/3/4 VW's. I unscrewed 2 of the studs from the plate and they line up perfectly with the A4 brake booster, so this gave me some hope.
So this is where the fun begins....removing the pedal bracket inside the car...be prepared to use several cuss words, hands cut and an achy back. The pedal bracket is bolted up with 2 bolts into the firewall and 1 under the steering column. Before you can get to the bolts you have to get the rod that supports the clutch and brake pedal, which is held in with 2 spring clips that are a bit of pain to get off. I ended up destroying them and going back with a small R-clip to hold it in place.
Once the pedal bracket is out, there are 2 red caps that hold in threaded inserts that the brake booster bolts thread in to. Once you remove those, the booster delete studs slide in, but you will have to cut some of the bracket away to get a nut on the thread studs.
You can see where the studs come through, but here isnt any access to the threads because of the casting of the bracket. I will have to clearance these areas, as well as creating 2 more holes for the other studs to mount up. This also shows that the dual piston actually clears the opening, unlike a lot of other cars where you have to cut out a half moon shape for it to clear.
Not a finished picture but this how much room is left when the booster delete is flush at the firewall. This also comes with an adjustable proportioning valve for the rear brakes.
I will be updating this as I go, so stay tuned.
