Results 1 to 11 of 11
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    2002 Audi TT ALMS OEM+ Arizona $10K
    Year:2002
    Make:Audi
    Model:TT
    Mileage:150,000 Miles
    Transmission:6 speed manual
    Engine:1.8t
    Trim:ALMS
    VIN: TRUWT28NX21026976
    Title: Clear
    2002 Audi TT ALMS
    Purchased from the original owner in Southern California (from a CA dealership), now in Phoenix, Arizona. Under carriage, wheel wells and engine bay are in excellent condition due to our climate. Fires up and drives like a brand new vehicle.
    Interior
    $5000 custom stitched interior
    New oem door cards
    New oem radio
    New oem steering wheel
    Custom car luggage
    Billet shifter
    Custom ceiling/visors
    Exterior
    Carbon fiber rear valance
    Carbon fiber rear wing
    Carbon fiber mirror caps
    Custom grill
    Suspension/brakes
    KW coilovers
    Adjustable rear control arms
    Front x-drilled rotors newish pads
    Rear x-drilled rotors newish pads
    H&R sway bars
    Custom made Forgestar F14's made specifically for this exact vehicle out of California.
    Engine
    GIAC Flash
    007 DV
    Cold air intake
    Full Borla twin tip exhaust
    Cons
    ~4" strip of clear coat is peeling up, can easily be sanding away/blended. That same rear panel has some minor scuffs, I was just going to have the whole section resprayed.
    Drivers mirror switch needs replacement ($56 shipped).
    The new passenger door has a little bit of delamination where the oem leather has lifted off the door card, simply needs to be glued back down due to Arizona dry conditions.
    Both front axles were replaced with oem units, one boot on one axle just tore. Axle is fine, just needs a new boot probably from Arizona dry rot.
    Standard half working lcd pixels
    Belt tensor pulley is slightly noisy at idle (always been).
    50 state compliance emissions
    Cold AC
    Can be driven anywhere
    Lots of attention
    It's close to being a show car, honestly who ever gets it should only consider it if you have a garage...you can daily it but probably deserves better then that (take out on weekends instead).
    $10k firm, no trades, located in Phoenix, Arizona - Blake 602-487-383eight
    Feb 28 2005
    Tempe
    - Brand new tires (0 miles)
    - Brand new power coat job in Illusion Gold (0 miles)
    - Brand new Forge Star carbon centercaps (0 miles)
    - Brand new rear hatch hydraulic lifters
    Aug 02 2012
    chicago, IL
    Superrrr clean !
    Feb 28 2005
    Tempe
    - New (er) battery
    - Refreshed alternator
    - New (er) front x-drilled rotors with pads
    - New (er) rear x-drilled rotors with pads
    - Aluminum lightweight lugs w/lock key
    - Aluminum engine fastener set
    Feb 28 2005
    Tempe
    Feb 28 2005
    Tempe
    Being transported to another state.
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    C'mon Blake... you know you customize the sh!t out of your rides...
    Tough to find the right buyer... but they will come along.
    You know Brian @ Audi N. Scottsdale...? He's a TT guy...
    Feb 28 2005
    Tempe
    Thanks! Sent him an email.
    Now in Michigan.
    Oct 12 2018
    Arizona
    Off topic, but I'm also in Tempe. I never see any other old Audis, how often are you in that b5? Ill have to keep an eye out
    Feb 28 2005
    Tempe
    Quote Originally Posted by GsJenkss View Post
    I lived in Tempe for 10 years, I had quite a few heavily modded VW & Audi's...including the B5 I drove around.
    Feb 28 2005
    Tempe
    Deposit taken 12-17-22
    Sold
