Alright, story time.
I just got done with my spring maintenance, which includes: sparks, coils, air/cabin/fuel filters, and fluid changes. All went smoothly except the
fuel filter. One of the old filters nipples broke off inside of the hose and it was a huge PITA to get out. I tried not to tug to hard on the hose, but basically, I had to pull the hose in one direction as I applied force on a pliers at an angle that I jammed in there for friction. Not fun at all, but eventually it popped out.
I filled up and began to pay more attention to my
fuel gauge as I was curious on the impact the spring maintenance would have on my MPGs. And thats when I noticed a problem. The gauge is moving around all crazy like. Its not fast, its a slow move and it also involves the computer (the one that says how many miles are left). I'll move 1/4-1/8 tank back and forth. The computer says I have 200 miles left, then a quarter mile later says I have 250 miles left, then 180 at the stop sign. I drove 300 miles and filled up as to not die on the highway. The gauge went to full but is still doing this.
I checked with my VCDS and found no problems with sensors. I really hope I didn't do anything when I was messing around with that
fuel filter. Please advise me if you know anything regarding this. My assumption is a bad sender. Maybe mine didn't break all the way like Phils, but perhaps cracked and moving back and forth. I followed the guide until I got to the ring.
Phil apparently has the power of Clark Kent. My ring must be held in with 300lb/ft of pressure. I actually bent on my Craftsman drivers trying to free it. Looking in my Bentley, the job calls for a T10202 tool to be used. Its basically a cookie cutter tool that has a 3/8 drive socket. This allows you to apply force on all sides of the ring instead of just one. Very lame, but I needed it.
Looking online, all I found OEM came to about $80. Super lame. I stumbled across this World Impex site with an aftermarket tool that looks exactly the same for $25 bucks. Bought. Its on its way and I'll post here how it works. I really hope my problem is the
fuel sender and I'm not doing all this for nothing.
site for T10202:
http://www.worldimpex.com/parts/oem-...h_2603548.html
