KW thinks their kit is operating correctly and that the height sensors are getting out of range due to lowering the car. One of the faults is with the Ride-Height Sensor, but there is another fault for the Valve for Damping Adjustment. It's possible the height-sensor being off is also causing the other fault, but who knows for sure.
KW could be right and we need to fabricate a part to put the height sensors back in range or find some way to disable the ride-height sensors via VAG-COM. Until this is done, it seems the ball is in our court (the customers) to prove that this is or isn't the issue.
Are their any Tuner shops or Product companies willing to fabricate a part to get the height sensors back in range? If this fixes the issue, I would think this would be a sellable part that anyone with mag-ride who wants coils would need, but I'm no expert in regards to this.
When the error is thrown, traction control can not be disabled or won't stay disabled, this is the main issue, other than the annoying and embarrassing errors that get thrown on the dash, which also blocks out other content from being shown (radio station/song).
Codes:
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 E HW: 8V0 907 376 E
Component: DAEMPFUNGS-SG H09 0072
Serial number: 280115000
ASAM Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide_AU37.rod
VCID: 43855E16CA62FA260B-8016
5 Faults Found:
2117646 - Front Left Ride-Height Sensor
C1034 07 [008] - Mechanical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 4804 km
Date: 2015.08.28
Time: 08:48:42
3149829 - Valve for Damping Adjustment Front Left
C1040 1D [008] - Current Implausible
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 4826 km
Date: 2015.08.28
Time: 10:46:16
3153925 - Valve for Damping Adjustment Front Right
C1041 1D [008] - Current Implausible
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 4827 km
Date: 2015.08.28
Time: 10:46:48
3158021 - Valve for Damping Adjustment Rear Left
C1042 1D [008] - Current Implausible
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 239
Mileage: 4894 km
Date: 2015.08.28
Time: 16:01:15
3162117 - Valve for Damping Adjustment Rear Right
C1043 1D [008] - Current Implausible
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 248
Mileage: 4894 km
Date: 2015.08.28
Time: 16:01:23
Code thrown after aggressive cornering:
Dash indicator, goes away after shutting off the car and turning it back on:
Front Height Sensors (Green Part):
Rear Height Sensors (Green Part):
I get these errors multiple times a week, I don't even have to get that aggressive in the corners, and sometimes just with braking.
Hopefully a tuner shop/manufacturer can help out us enthusiasts here.
