Page 1 of 3 123 LastLast
Results 1 to 40 of 105
    Veteran Member Four Rings 0000 V8's Avatar
    Feb 19 2010
    Porsche Cayenne Turbo, B6 S4, C5 Allroad, B5 A4, Prius C
    Sacramento, CA
    Talking Justin's B6 Race Car Build Thread - Do I Belong Here?
    Hello AZ friends. My name is Justin aka 0000 V8 and some of you may already know me or have seen this car. This has been a project in the making for 3 years. I purchased my S4 back in 2009 with the intent of one day making it a track car. The S4 has always been my favorite car, and I realize there are cheaper and more "track suited" cars out there, but Im not into the cookie cutter cars. I wanted something I could really be proud of. I wanted a challenge. What better way to do that than make a luxury sport sedan into a full track bred beast.
    Long story short, after the initial build and 1.5 years, the car awesome on the track but I ran into some engine troubles with the stock BHF V8. I wanted to swap in an 07K I-5 but realized it would take a while, so I decided to BUILD ANOTHER RACE CAR with a B5 A4 chassis. That project has been hugely successful and we are currently in 1st place in the Western Endurance Racing Championship series, and 1st place among numerous German Touring Series regions across the western US of NASA.
    I eventually opted for a 1.8T motor swap over the 07K after a perfect motor fell into my lap from Max Stanton and much conversation with 034Motorsport about their Time Attack A4 1.8T.
    I feel like a black sheep, not really belonging in the B6 S4 forum, so maybe you guys can take me in?
    Here is some info about the car. The chassis is already finished and 98% of these parts are already on the car. Im mostly finishing up the motor swap in the next couple of months and have a few parts yet to install.
    The car will be raced in the German Touring Series, Super Touring, and eventually the Western Endurance Racing Championship series.
    I have TONS of photos in my old thread but most have died because I linked to Facebook. I will upload ALL photos on this thread from Photobucket so that doesn't happen again.
    Everything on the motor is brand new, all hardware, bearings, crank, valves, springs, etc etc. Engine and head built by Tech Machine works in Livermore, CA.
    Engine/Power:
    - AWM 06B short block
    - 2.0TFSI forged crank
    - 034Motorsport coated bearings throughout shortblock
    - ARP main stud kit
    - IE manual timing belt conversion
    - OEM water pump (factory, not Worldpac)
    - OEM oil pump (factory, not Worldpac)
    - Oil pump chain, guides, everything.
    - OEM all new seals and main seal, Accessory belt for no A/C, etc etc
    - IE Tuscan rod set w/ upgraded rod bolts
    - Custom JE 2.0L FSR pistons w/ VVT valve cutouts (ultra lightweight with no skirt on down stroke)
    - AEB big port head
    - Supertech valvetrain (single ti retainers, springs, exh/int valves, new valve guides and seals (OEM)
    - Adjustable cam sprocket
    - Variable Valve Timing conversion with low mileage Cam Chain Tensioner
    - IE intake manifold, 80mm to 70mm adapter
    - 70mm V6 throttle body, DBC Conversion
    - Tilton Pedal Box with Triple Master Cylinders
    - Denso Racing Alternator kit, no A/C,
    - 034 Motorsport motor mount brackets,
    - new ignition coils
    - new spark plugs
    - Custom Column Mounted Electric Power Steering
    - 034Motorsport snub and mount, vacuum lines and hoses (all new silicone)
    - Custom Side Exit Full Race Exhaust System (3”)
    - Summit Fuel Pump, High Performance (450lbs/hr,65psi,800hp)
    - Canton Racing Accusump, 3q System
    - Stratmosphere Intake Cone
    - Custom Fuel System with ATL Rear Cell 12gal Tank and Racing Fuel Pump
    - Stock Tanks Gutted for Exhaust Mufflers
    - Optima YellowTop, relocated to rear
    - Custom Billet Catch Can
    - Custom Billet Coolant Tank
    - Custom Lower Rad Support Bracket with Snub
    - Precision 6262 journal bearing turbo
    - 034 Time Attack A4 Exhaust Manifold Design
    - Garrett 600HP Intercooler
    - Custom Aluminum Piping
    - 034Motorsport Stage IIC ECU
    - Custom Mil-spec harness specially made for custom application
    Trans/Drivetrain:
    - 0A3 Quattro All-Wheel Drive with 6-spd Manual Transmission from B6 S4
    - Torsen 4:1 Center Differential Upgrade
    - CAE Race Shifter
    Chassis/Suspension:
    - Evil Genius Custom Built Full Roll Cage
    - PSi Raceline Twin-Tube Coilovers with Ohlins TTX Dampers/Eibach ERS Springs 800/1800
    - 034Motorsport Solid Rear Sway Bar
    - 034Motorsport Sway Bar Adjustable End Links
    - 034Motorsport Fully Spherical Adjustable Upper Control Arm Kit (Race)
    - Apikol Rear Differential Mount, Red
    - Apikol Snub Mount w/bracket, Red
    - 034 Motor Mounts, Motorsport
    - 034 Density Line Transmission Mount
    Brakes:
    - STaSIS Alcon Mono4 355 BBK (F)
    - Cobalt XR2 Track Pads (F)
    - Slotted Rear Rotors
    - Stainless Steel Brake Lines (F&R)
    Wheels/Tires:
    - Enkei 18x9 et35 5x112 PF01’s
    - Federal 595 RS-R 255/35/18
    Exterior:
    - EuroGEAR Carbon Vented Hood w/AeroCatch Pins
    - APR GTC-300 Carbon Wing
    - APR Custom Carbon Splitter
    - Custom 3" Brake Vents [awaiting fab]
    - GT3 Carbon Side Mirrors (with curved glass)
    Interior (Fully Gutted):
    - Status Ring GT Blue Suede Carbon Racing Seat
    - AIM DataLogging GT Steering Wheel
    - Sparco Quick Release Steering Hub
    - Sparco Floor Plate
    - Sparco Aluminum Pedals
    - MOMO Shift Knob
    - Custom Race Gauge/Switch Panel
    - AEM Digital Gauges
    - A/F Ratio, Fuel Pressure, Oil Pressure, Oil Temp, Water Temp, Trans Temp, Voltage
    - ATL Fuel Gauge
    - Auto Meter Pro-Shift Light
    Safety Misc:
    - 6-pt Status Harnesses, Red
    - Scroth Window Net
    - Scroth Right Side Net
    - Safecraft Fire Suppression System, 5lb Lever Release
    - HANS 20-deg Neck Restraint (QuickClip with Gel)
    - Sparco M-5 Driving Suit
    - Sparco Slalom SL-3 Shoes
    - Sparco Tide H-9 Gloves
    NOTE: Some of these photos are older and may not represent the car as it currently sits.
    Feb 19 2010
    Sacramento, CA
    -Reserved-
    Veteran Member Four Rings krew53's Avatar
    2023 RS6 - 2013 B8.5 S4 - 2003 B6 1.8BT quattro
    Simi Valley, CA
    Ok.. You can stay
    2013 Solar Orange S4
    6MT | APR stage 2+ Ultra | Eurocode Headers | APR CPS | Meisterwerk clutch | Milltek Exhaust (resonated) | KW V3 coilovers | HRE FF01 | Stoptech trophy BBK | Alu Kreuz | Eurocode Sway / Endlinks / Trans & Dif mount | LYKT Control arms | E-Codes | Eurocode Short Shifter | P3 Gauge | Vinyl roof / trim / blades | B&O / JL Sound system | Probably more..
    Veteran Member Four Rings elewsader's Avatar
    Mar 24 2006
    2003 A4 1.8T Avant MTQ, 2001 Audi S4 Sedan
    Central, IL
    welcome Justin! looking forward to the day when you document that 07K project
    Ed
    why say lot word when few word do trick.
    Established Member Two Rings mdh's Avatar
    Jul 22 2015
    Missouri
    This thread makes me happy.
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Wow
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Senior Member Two Rings DJHoro's Avatar
    Dec 16 2014
    Fresno
    Hold up....gotta change my underwear.
    Veteran Member Four Rings ShogunR32's Avatar
    Aug 22 2004
    Very nice
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant/2001 Red Audi TT 225Q.
    Current: 2004 BMP Vw R32
    Feb 19 2010
    Sacramento, CA
    Quote Originally Posted by elewsader View Post
    I'm not doing an 07k. Doing this 1.8T!
    Mar 24 2006
    Central, IL
    Quote Originally Posted by 0000 V8 View Post
    I only saw the 07k, and stopped reading..I'm now le' sad..
    Ed
    Active Member Two Rings DC9708's Avatar
    Oct 19 2014
    Clarksville, TN
    Damn, this is awesome!
    Jan 24 2008
    Pennsylvania
    Wow. I think I can safely speak for most of us here. You have our attention. Incredible build(s)!
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Veteran Member Three Rings USAF Long's Avatar
    Nov 05 2010
    Salt Lake City, UT
    Quote Originally Posted by krew53 View Post
    Ok.. You can stay
    ^This.
    - Scott Long -
    2002 Audi A4 1.8t Quattro - 5-sp | 3M Wrapped | Test pipe | Custom Exhaust | Tint | 19" Staggered Wheels |
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    I would like to see this car versus JetJockey's
    Feb 19 2010
    Sacramento, CA
    Quote Originally Posted by imnuts View Post
    Agreed. I really like Mikes car. Is he still on AZ? Haven't seen anything about his build in a couple of years.
    Jan 10 2013
    03 A4 Avant 1.8TQ
    South San Francisco, CA
    LOL my name is Justin as well and was like "wait, i have a race car build?!"
    Sep 08 2015
    1998 Land Rover Discovery
    Lake George, NY
    Christ on sale!! Awesome build man. Hopefully I'll have a build like this one day.
    You have my respect and then some. ha
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    You seem really into your new build. Congratulations!!!
    Your parts list is super.
    Save your money and buy parts from JHM, MJM Autohaus, 034, Integrated Engineering etc...
    DON'T build your car @034 or have them wrench on your pride and joy.
    PM me for details.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Mar 24 2006
    Central, IL
    He's still around, he posted an opportunity for a heated windshield product run that was reasonably priced a little while back..
    Ed
    Feb 19 2010
    Sacramento, CA
    Quote Originally Posted by A4SoftWalker View Post
    PM me for details.
    I don't do JHM. I have a good relationship with IE, and an even better relationship with 034.
    I do all my own work including custom stuff, unless it's welding something for safety like the cage or steering rack. I do weld brackets and misc things though.
    Mar 02 2015
    miami
    REAL RACEKOR! this is awesome
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    *drools* welcome!
    May 13 2008
    NoCal - EBay
    This^^^
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Dec 05 2007
    I was afraid to press on the link for this thread, but glad i did. Please post an in cabin video when you get the chance.
    Feb 19 2010
    Sacramento, CA
    Here are som old videos of one of the first track days when I still had the V8 in it, and other vids from the first build. I will post a video of the inside after this weekend for you though.
    To be clear, the car has never been driven with the built 2L.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    How much does the car weigh?
    2019 SQ5 Prestige
    Feb 19 2010
    Sacramento, CA
    Quote Originally Posted by texasboy21 View Post
    I have not weighed it with the new motor. I'll do that once the car is near complete.
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    This is awesome
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Apr 01 2007
    houston texas
    How much did it weigh with the V8?
    Feb 19 2010
    Sacramento, CA
    I honestly can't remember, but something close to this:
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    very nice! i definitely can respect the work and time and $$ into it.
    Audi Club Bay Area
    Registered User Four Rings UroTuning's Avatar
    Aug 23 2007
    Tampa Bay, FL
    Wow! The car looks great!
    Oct 29 2005
    10speed
    San Francisco, CA
    I think you'll fit in just fine, maybe more than the other forums. Still gotta check this beast out @ Sonoma!
    - Clint
    Feb 08 2015
    03 A4 quattro 1.8t 5speed
    Fort Riley, KS
    The flyby video sounds so good. Car is awesome.
    Veteran Member Three Rings Audi body's Avatar
    Jan 03 2013
    bike and a pit bull powered pair of rollerblades!!
    the woodlands tx
    Absolutely beautiful!!
    Mar 05 2013
    CA
    Senior Member Three Rings brady.'s Avatar
    Sep 25 2012
    green bay, wi
    awesome thread :) subscribed.
    '02 audi 3.0 quattro with 123,000 miles.
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    Looks great! I cant wait to see your progress!
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Feb 19 2010
    Sacramento, CA
    We got a lot done this weekend. Started on the engine harness for the 034EFI IIc, installed fuel rail, injectors, and mocked up timing belt and Fluidampr harmonic balancer.
    We also finished gutting the OEM harness and removed the OEM steering column which will not be reused. I have an electric power steering column from a Saturn that will be fabricated to fit. We removed at least another 125lbs from the car today.
    Now we will spend the next few days prepping the car for a full pressure wash inside and out. We will pull the motor for the final time (to allow room to reroute custom brake lines for the Tilton pedal box, remove false firewall, work on custom shifter, etc), clean the inside and remove the rest of the fueling components at the back, and clean clean clean to prep for a full interior paint. Then we can FINALLY start reinstalling stuff permanently.
    Theres going to be a lot of custom stuff coming up in the next few weeks. Stay tuned.
    http://i326.photobucket.com/albums/k...pswzxfahox.jpg
    Apr 07 2011
    This thread is full of win.
