UPDATE: Part #'s have been added to some things and I've also made some changes here and there so make sure to read everything if you're interested in doing this.
Disclaimer- Attempt at your own risk!
So I finally got around to converting my fuel system to return style for when I run E85 in the future. It was an fun time! When I was preparing for this, I found more than enough threads to help ensure I do it correctly (Thank you guys for those threads and help with questions). But I didn't find any threads that had documented it start to finish 100% (I could be wrong, I searched high and low though lol). So I decided to document mine :). When I was preparing for this, I wasn't exactly sure which route I wanted to do so I kind of over prepared (I thought I over prepared lol). Well I was wrong lol, I actually under prepared. I bought just enough fittings to get the job done. This was my first time doing something like this. I think it turned out alright. :)
Parts used
1-Walbro E85 fuel pump and E85 filter setup #F90000267 Pump filter kit #400-0085 (motovicity)
2x-5/16 EFI adpters with male end # 799-640930 (Jegs)
1-180 degree -6an hose end with female fitting # 555-110041 (Jegs)
1-Aeromotive 40 micron fuel filter with 2 -6an male adapters #12335 Port Fittings x 2 # 15609 (Aeromotive)
1-034 fuel rail with OEM fpr hook up # 034-106-7008 OEM FPR Adapter # 034-106-5001 (034 Motorsports)
1-20ft of Jeg's Pro Flow line compatible with alcohol/ethanol # 555-111914 (Jegs)
1-90 degree -6an hose end fitting with female adapter # 555-110021 (Jegs)
2x-45 degree -6an hose end fitting with female adapter # 555-110011 (Jegs)
4x-straight hose end adapters with female ends. # 555-11001 (Jegs)
1-Fuel pressure gauge # 083-71511 (Jegs)
1-Small T fitting for tapping in your FPR if you have AMB Intake manifold. AEB Intake manifold has a port for FPR built into it.
I also recommend drawing your fuel system out on paper and note what part goes where so you can get an idea of what parts you will need. Some areas will need up to 3 different fittings/parts just to complete a connection. Chances are you will need more parts than you think. I opted for having to return things instead of having to wait a couple days to get a part that I needed.
I used the A4 mods DIY for fuel pump removal and install. It was very helpful!
I put 2 sleeves on the pump. Fits great with no movement!
Walbro pump was installed with bottom being the same length, stock was from basket (1.75' from lowest part of basket) Also notice I wired it backwards the first time. OEM power + is ACTUALLY BLACK! lolz (I learned that the hard way)
I installed 5/16 EFI -6an adapters to my stock supply and return line.
Blocked off my breather line (some don't even have this line in their car) Made my stock supply, my return line. Attached -6an line with a fuel hose clamp. (make sure it's snug!)
Ran my 40 micron filter down stream a little. It was to big for stock filter placement and that was pretty packed as well. It extends approx 1/2" past sub frame. (plenty of other things lower than it) It looks like it's out a bunch, it's actually not.
with cover on :)
Had to remove some of the rubber on the inside of these metal brackets to fit the -6an in for a clean look.
Here is the engine bay with the fuel rail installed. (NOTE: had to switch out the little bit of stock supply line for the braided line. I first attempted to attach a fitting to it. It ripped to shreds internally and started leaking and building up mad pressure. I switched it out and everything worked flawless after that. Tapped my T fitting at the small boost/vac line that runs to my DV.
I have a 4bar fpr installed. This is my pressure at idle. Not sure if this is normal or not with this setup. Working on finding that out. Any input is appreciated.
Thanks for reading!
