Originally Posted by
old guy
Monitor blocks 130, 131 and 132. Block 130 will give you the engine outlet temperature and the radiator outlet temperature. Block 131 will give you engine output and engine output specified. The specified will be around 100° c depending upon RPM. Block 132 will give you the radiator outlet temperature as well as the delta between the engine and radiator outlets and the thermostat heater duty cycle.
What you should see is that the block will heat up to around 100°c while the radiator outlet will remain steady. The delta will be significant. Once the engine outlet goes over 100°c you will see the thermostat duty cycle start to increase and the lower radiator outlet temperature will increase. The delta will decrease until you see the engine outlet drop below 100°c. The duty cycle will decrease and the thermostat will close.
If the engine outlet temperature never reaches 100°c and the duty cycle stays really low (3% to 5%) you need a new thermostat.
Edit: And I forgot to mention since I figured it was implied but if the engine outlet is below 100°c and the delta between the engine outlet and radiator outlet is low that would be another indication of a faulty t-stat.
my heat comes on whenever it wants, usually above 10C when i DONT need it, but it has been blowing very minimal to no heat for a while now, the one heater core pipe is warmish and the other one isnt, probably a plugged heater core?
my temp gauge also drops randomly, i thought it was only at above 120 but now even at idling,
I logged it with vagcom today and my duty cycle is mostly at 3.9, and goes up sometimes if im accelerating.
thoughts? CTS, Thermostat and HC?
I will try to upload the log tonight and see if anyone want to analyze it ?
(apologize for copy and pasting the same thing on 2 different post, just want to find answers for this!)
EDIT: didnt read it carefully, i think i do have a bad thermostat because my engine never reaches 100 also a plug heater core...
