Yes, M for manual.
Picked up a '01 (MY 2000) D2 S8 off the classified with a blown transmission. My first Audi besides my B5 Passat which is pretty much a B5 A4 FWD underneith. 1 & 2 gear are 90% gone. Did slip it from a stop sign with faulting once. 3 & 4 have a little grip, 5th is fine. It will go into limp mode and lock into 5th gear, which is fine from 20-100+ mph. Perfect car to transplant a 6 speed manual into. Overall the car rides great, just needs some TLC to the interior and a few random bits here and there (radio buttons has been abused, cluster led repair, headlight auto level sensor for the front, front wheel bearings). The suede seat bottoms are pretty beat and need to get recovered at some point, but there are no tears or holes. A/C needs to get checked out, looking like it just needs a re-charge from not being used in so long) 121,286 miles on the OD when I picked it up and no accidents or incidents on the CarFax report.
Got it home from Boston to Syracuse without an issue, ie. without plates, without a temp tag, without insurance, without a title. Brakes are rust from sitting around. Calipers work great and pads are atleast 50%, so just going to turn the rust off the rotors and run them til next year. I think they should last me 10-15k miles yet. Whom ever put the wheels on last was an idiot and over torqued them (probably a 1/2" impact til yield). So a 24" breaker bar and 4 foot jack handle to remove all 20 lug bolts. Calipers came off without an issue. Got the rotors to the machine shop to get cleaned up. Probably blast some of the rust off the inner hats and vains as it was pretty crusty there too. Also found that the right rear caliper is missing the e-brake bracket and spring, so I'm searching for that rigth now. Pretty important.
In the mean time, doing a lot of reading on what has been done before. Looking at 01E or 02A swap and what would need to be custom or modified. I'll post some photos later. Any info and links would be greatly appreciated.
If you want to see what I've done to the Passat, click on the 2L Build in my signature.
