Getting the grill off:
You will see a hole on the inside of each grill, put a hook or Allen wrench in there and clamp down with a wrench. Then pull from inside to outside.
On the outside there are two tabs, don't break them. You will also see another hole on the outside, that's only for adjusting your fog light aim, so don't use unless you need to adjust after the install.
It's held on by two screws at the bottom. Take those out and push the unit back slightly and then pull out. The top of the fog has tabs that rest on the top part of the bumper assembly.
Easy as pie, also a good time to clean in there I had all sorts of crap and I have less than 5k on my car.
So if anyone needs some h12's let me know!
And just because I thought this was funny:
Cheers!
