Results 1 to 11 of 11
    Stage 2 Banner Advertiser Four Rings Tech/Sales@JHM's Avatar
    Jun 04 2008
    The Fastest Audis
    California
    Thumbs up JHM Oil Cooler and Auxiliary Radiator Delete Kit For B6-B7 S4!!
    Hey Ziners!
    JHM Introduces the long awaited JHMotorsports Oil Cooler and Auxiliary Radiator Delete Kit for the B6-B7 S4!!!
    We've been testing this kit on our Shop S4s since 2008 and have installed a number of these kits for local customers. After a lengthy Research and Development process, we are ready to fully release this kit.
    At JHMotorsports we have known for a long time that the OEM Air to Water Oil Cooler on these cars creates a lot of hot air and is the reason why many "Cold Air Intake" kits don't work. The Auxiliary Radiator creates heat that most kits end up sucking into the intake tract. Our JHM Oil Cooler and Auxiliary Radiator Delete Kit is the solution for this issue that deletes this radiator while also improving oil cooling and oil capacity.
    Click Me For JHM Oil Cooler and Auxiliary Radiator Delete Kit!
    Our kit includes a custom CNC machined adapter plate that installs behind the alternator and replaces the OEM Water Cooled adapter. This Oil Cooler kit is thermostatically controlled with a high-quality Mocal 180 degree F thermostat. It includes everything shown in the photo above including stainless braided hoses with AN fittings, an upgraded Oil Cooler, Mounting Kit for the Cooler, and an upgraded Power Steering Cooler.
    Additional Images:
    NOTE: Since this kit uses a lot of the same parts found in our JHM Stage 1 Supercharger kit, if you upgrade to this kit before you buy our JHM Stage 1 Supercharger Kit, we'll credit the majority of your Oil Cooler Kit purchase towards the price of your Supercharger Kit. Below is a picture of one of our customer's JHM Supercharged B7-S4s with our Oil Cooler Kit Installed:
    We have designed this kit to be upgradable and have made it so you can run any size Oil Cooler core that will fit behind your bumper. The core we supply with the Kit measures 5 inches by 13 inches by 2 inches and will keep oil temperatures at optimal levels, even in extreme conditions. One of the first cars to have this kit ran it during open road racing in 90 degree F temperatures and only saw oil temperatures of about 250 degrees F.
    If you are interested in this kit and have questions or would like help placing an order, feel free to give us a call at (209) 968-0077 or shoot us an email at [email protected].
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Hey everyone!
    This kit is now on a bigger sale! You can pick this up for $795 now!!!
    Please let me know if you have any questions!!
    Jake
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Damn, you guys are killing me. Already was getting your headers and IM over the winter. Then you came out the LSD. Now this is on sale. So many things to buy with so little money lol
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Aug 31 2011
    Lathrop
    Quote Originally Posted by FastEddie View Post
    Haha well, if you get this and our 6-rib kit, you are two steps closer to our blower kit!
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Welcome to my world.
    Aug 31 2011
    Lathrop
    Quote Originally Posted by JimmyBones View Post
    Just about everyone's world I think!
    Apr 01 2012
    Queens
    Quote Originally Posted by Jake@JHM View Post
    already have 6 rib kit.
    Aug 31 2011
    Lathrop
    Well if you get this oil cooler kit then all you are missing is the blower!
    Veteran Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    Scrap Transmissions!
    Hey JHM, I’d like to make an oil cooler kit for a B8 S5 4.2 and there doesn’t seem to be an air to oil cooler kit for the S5 yet. Could I purchase just the adapter plate that mounts to the engine block from this kit? The B7 and B8 are both 079 blocks and the oil coolers look to be the same shape. If you think the adapter plate can be used on a B8 I would definitely like to purchase just that piece. Thanks!
    Aug 31 2011
    Lathrop
    Quote Originally Posted by b7_Andy View Post
    Shoot an email over to [email protected].
    Junior Member Two Rings
    May 08 2017
    Villa park, IL
    Hey Jake, do you guys have a adapter plate to delete the smaller oil cooler for the RS4 b7?
