    Are you using the correct tire size?
    (This mostly pertains to after-market wheel/tire combos)
    Fitment is one thing, but some of you forget about the other thing. Will the tires I'm using be strong enough for my car. Tire failures are commonly caused by over-loading and/or under-inflation. Please check to see if your tires are "strong" enough for your car. I've attached a load-index table to help everyone out.
    How to use:
    1. Check what the load index is on your original equipment tires. You'll be able to find this on the placard placed in between the driver's door jam.
    2. Find out what the recommended air pressure is.
    3. Cross-reference that with amount of weight that air pressure will hold.
    4. Check the load index of the tires you are using.
    5. Set air-pressure according to what the load-index table states.
    Note #1. Make you check if your tires are standard-load or extra-load. Extra-load tires will say "XL" or (REINFORCED)
    Note #2 If the tires you are using doesn't meet the load capacity at its maximum pressure, then your tires may fail.
    I hope this helps. Be safe everyone.
    2016 S7 Sepang Blue HRE S101 21 x 10.5 275/30R21 Pirelli PZero. (EUROCODE) APR ECU/TCU Stage 1 VCDS Lowering . Exhaust by MAGNAFLOW
    2015 Q5 TDI Lava Gray The wife's
    2012 S5 6MT Ibis White SOLD
    Air-pressure/Load index table
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Good stuff, thanks !
    Sep 02 2005
    Montreal
    Thanks for this informative post, I will need to make a change... to my no fat chix sticker, from "car will scrape" to "would exceed tire load index".
    Veteran Member Four Rings crisp74's Avatar
    Jun 27 2010
    school bus
    queens, ny
    thanks dude. had to up the psi on my tires by 2 after reading this. good stuff.
    hulk: [New wife + respray] carry the 2
    CARS:
    82 Cadillac Cimmaron: 89 Dodge Colt: 89 Geo Tracker: 90 Ford Tempo: 93 Saturn SL2: 99 Mitsubishi Diamante: 02 Pontiac Aztek: 02 Chrysler PT Cruiser: 03 Buick Lesabre: 04 Pontiac Bonneville
    Bump
