Results 1 to 28 of 28
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ă C, CĂ*
    Coming soon... anyone guess?
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Account Terminated Four Rings
    Feb 26 2011
    las vegas
    standalone?
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    IFC mod, individual flux caps
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    push down coils?
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Veteran Member Four Rings phila_dot's Avatar
    May 26 2010
    2001 S4, 2019 Q5
    Philadelphia
    Keyless system
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    New ICMs because one has a hole and the other just completely disintegrated in the middle? :)
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Feb 26 2011
    las vegas
    Quote Originally Posted by Timtheguru View Post
    the connectors at the bottom are not part of an original ICM, they are used to bypass - I'll take another stab, fusion reactor?
    Dec 30 2009
    Quote Originally Posted by itguy View Post
    It was a joke obviously.... ;)
    Just tell us OP!!!
    2001.5 S4 Sedan
    2018 Q5 2.0t
    May 13 2011
    2015 BMW F30
    LS1 coilpacks?
    | Autospeed | JHM | Pure MS
    Jun 15 2010
    San Antonio, TX
    My guess would be ICM delete...
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    If this is what i think it is YAY!
    I've been thinking of doing this and I've also got a bunch of 2.0t coils that I can use, dreading breaking into the harness for the coilpack connectors though...
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 24 2008
    2000 S4, Blown LS2 240sx hatch, LS3 240sx vert, 02 wrx
    Santa cruz
    Quote Originally Posted by CC Lemon View Post
    That would be my guess as well
    Jan 11 2007
    Salt Lake City, Utah
    Some sort of fancy-pants coilpacks?
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Feb 13 2004
    S Ă C, CĂ*
    :) yea i just finished ordering the last of what i needed to get this going, man the connectors are expensive not to mention the pins. The ones that go to the newer coils are $$, not sure why they cost so much. Im going to make a harness that is complete plug and play for now without a single splice, but i think i might just chop the old coil pack connecors off and solder the new ones in so it looks cleaner.
    Feb 16 2009
    Ithaca New York
    So what is the point of ICM delete?
    Jun 15 2010
    San Antonio, TX
    Well... they're expensive and fail. When they fail it's really annoying. Deleting them gets rid of this problem. I don't know all of the details behind it... but the newer standard for ignition coils is better than what is used with the ICM's and cheaper.
    Feb 13 2004
    S Ă C, CĂ*
    Quote Originally Posted by Emilgevor View Post
    here is a cost comparison per current ecs prices on OEM audi parts:
    old coils 058905105 86.83 x6 = $520.98
    coil packs 4A0905351A 188.37 x2 = $376.74
    Total for old stuff = $897.72
    New bolt down coils 06B905115E 30.87 x6 = $185.22
    or if you want the red push down ones 077905115T 20.29 x6 = $121.74
    You do the math what will save you $ in the long run.
    If you get a misfire, you will know exactly what cylinder is failing cause you dont have to think its an ICM.
    Most of us still have the original stuff on the car which is a ticking time bomb to go out, i am at 140k on the stock stuff one reason im doing this.
    No data, but people that have done this with the 1.8t say they have better spark response.
    The new Hitatchi coils are supposed to be one of the most reliable ones out there.
    Feb 16 2009
    Ithaca New York
    I have IMC issue before and I simply replaced one with used one that I bought from member.
    Cost me $50
    I am still running my OEM coils and im at 112k on the S right now.
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    I replaced the hitachi coils on my wife's 1.8t with the red push down type and now I can run a larger gap since the coils throw a hotter spark, her car has 234k miles.
    188k on the S and im looking forward to this conversion.
    infinkc, the wiring that goes to the coilpacks for the 3-prong coils, how does that pin out with the new 4-pin connectors? is the "new" wire a ground or?
    props to you for plug and play.
    Jun 15 2010
    San Antonio, TX
    I think this has been done before on the S, but still looking forward to seeing how this turns out. I think I might have a bad ICM, so I'm tempted to try this as well. Used ICM's are reasonably cheap though.
    Senior Member Three Rings haggard69er's Avatar
    May 20 2007
    Alligators
    pittsburgh
    update!
    Feb 13 2004
    S Ă C, CĂ*
    Quote Originally Posted by haggard69er View Post
    update!
    http://www.audizine.com/forum/showth...on-upgrade-kit
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Quote Originally Posted by infinkc View Post
    Can you share the part numbers for the ICM connectors and pins? I want to make my own plug and play, easily removable harness.
    2023 Q7 - Ibis White
    2024 SQ8 - Chili Red
    So many have come and gone…
    Feb 13 2004
    S Ă C, CĂ*
    Quote Originally Posted by nefkntym View Post
    Read the first post in my Teaser Thread, has every part number needed to DIY.
    http://www.audizine.com/forum/showth....0T-Coil-packs...
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Thanks!!!
    Sep 17 2005
    Fremont, California
    We stock the Volvo 4 pin connectors and our own replica 3 pin connectors, along with pins and such, if you want to pick them up. Pretty competive pricing since we buy in bulk.
    That being said, we sell our ICM deletes for $60 complete (for both), which after the cost of parts, isn't much.
    Just thought I'd throw it out there.
    Oct 27 2012
    97 A8 4.2L, B5 S4 SSP Tuned
    This helps alot
    Quote Originally Posted by 034Motorsport View Post
    i was looking for this solution
    Veteran Member Three Rings spd579's Avatar
    Jun 04 2012
    05 s2000, 2001 Mazda Miata with SR20deT(GT2871) swap, 1990 Mazda Miata(Tme attack(500whp))
    Charlotte, NC
    you did see this thread is nearly 3 years old....right?
