Page 4 of 13 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 504
  1. #121
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    The A7 Tdi came in yesterday from Rockauto.
    Looks like it is made in Denmark. Can't wait to get the time to put it in. It looks small in the picture, but it is exactly like the one posted up earlier in this thread. Much larger than stock. I think I can get to some logging this weekend if possible.
  2. #122
    Apr 20 2013
    Let us know how the install goes and any difficulties faced
  3. #123
    Senior Member Three Rings Rollin Thunder's Avatar
    Aug 14 2012
    2008 F150 FX4
    Central New Jersey
    Ordered the same TDI intercooler myself. I did a little digging just to kill time and it is actually the same part number for the OEM style S5 as well. I know with increased boost levels on the modded S4 & S5 an upgraded intercooler is a must but it's good to know it's the intercooler the S5 runs stock. At stock levels I haven't read many issues with the stock intercooler on those. The S5 I would assume flows more volume of air due to the size of the supercharger. I will be installing mine this Thursday. All of the above is from my reading and opinion.
    MODS: Pretty close to everything and the kitchen sink.
  4. #124
    Stage 3 Forum Advertiser Four Rings Info@EuroCode's Avatar
    Dec 24 2008
    Torrance
    The S4/S5 utilize after coolers which allow for coolant to pass through not air. It also has much smaller inlet and outlets less than 1"ID (inner diameter). What you must have came across is that this TDI part also works on the Audi A5 TDI. This part would never work with any of the charge air cooling of the supercharged 3.0TFSI motor. Hope this helps.
    EuroCode Tuning, Inc.
    1872 Del Amo Blvd Unit A
    Torrance, CA 90501
    310-294-8108
  5. #125
    Aug 14 2012
    2008 F150 FX4
    Central New Jersey
    That does clear things up, I guess this is mislabelled on Rockauto. For a 2011 S5 3.0L V6 supercharged engine it shows an intercooler (Nissen part number 96618). That is the same part # for the 3.0 TDI intercooler. I would have without a doubt went with Eurocode kit if I didn't miss the sale and didn't already have your silicone house kit and charge pipe already. Would you guys ever consider a package with just the intercooler alone?
  6. #126
    Dec 24 2008
    Torrance
    It wouldn't work because the piping for the intercooler is 2.5" and the hose kit is only 2.25".
    Torrance, CA 90501
    310-294-8108
  7. #127
    Veteran Member Four Rings inNout's Avatar
    Jul 22 2009
    IL->WA
    Eurocode silicon hose won't work with TDI IC?
    2010 B8 2.0T 6spd K04 + [HPA Motorsport, Rays, APR, Eisenmann, Bastuck, Eurocode, KW, OSIR, StopTech, ArmaSpeed]
  8. #128
    Oct 14 2013
    2014 A4 Premium Plus, Sport, Black app, MMI
    Quote Originally Posted by inNout View Post
    I believe he is saying that the EC FMIC and the EC silicone hose kit?
  9. #129
    Senior Member Three Rings BaysideS4's Avatar
    Feb 25 2004
    Tampa
    It worked fine for me. Granted I only use the turbo side hose and had to boil some water. We'll see if it holds over time!
    2009 B8 A4 2.0TQ Premium Plus; 18" Sport Package; Meteor Grey; 125,000 miles / New OEM Piston Heads / Ecodes / Eurocode HFC / Revo / 15mm spacers / Bilstein B12 / Alu Kreuz / ÜSS Sway Bars / EC charge pipe and outlet adapter / 3.0TDI IC / RS5 pedals (hecho en China) / AWE exhaust / RIP: Rotamass pulley
    Previous:
    2007 RS4
    2005 S4
    2001 S4
  10. #130
    Jun 05 2009
    Scottsdale Arizona
    I was thinking about picking up just the turbo outlet piece and the pipe that replaces the sound box. Does Eurocode sell just those two alone?
  11. #131
    Veteran Member Four Rings AWDLover's Avatar
    Feb 07 2012
    Quote Originally Posted by A4 Centaur View Post
    I know they do for the high flow intercooler pipe (sound box delete). Not sure about the turbo outlet.
    2010 A4 Quartz Grey (click) | APR | Eurocode | GFB | 034 Motorsports | Eibach | H&R | VMR | P3Cars | aFe
  12. #132
    Veteran Member Four Rings auditd0rk's Avatar
    Feb 02 2012
    Colorado Springs
    Just shot you a text about the EC outlet. I have my 2.5" EC outlet from when I took off the K03.
    2012 A4 Quattro, Monsoon Grey | CTS K04, HFC | APR K04 v3 Tune | AWE Exhaust | Eurocode FMIC, Alu Kreuz, Sway Bars | Bilstein PSS10 | SPC UCAs | Apikol Rear Diff Mount | 034 Transmission Mount Insert, End-links | StopTech ST-60 BBK | S4 rear brakes | CR-15 brace
  13. #133
    Dec 24 2008
    Torrance
    The turbo outlet is not sold by itself as the factory hose will not work with it. We offer a hose kit which does work with the outlet adaptor and is required to fit this part onto your car.
    Torrance, CA 90501
    310-294-8108
  14. #134
    Feb 25 2004
    Tampa
    Quote Originally Posted by Info@EuroCode View Post
    The turbo outlet EC makes is pure perfection and is worth the price of the hose kit.
    Previous:
    2007 RS4
    2005 S4
    2001 S4
  15. #135
    Feb 19 2014
    RVA
    stoked to get my hose kit today :)
  16. #136
    Jun 05 2009
    Scottsdale Arizona
    8 Celsius is what? https://www.google.com/#q=8+celsius+to+fahrenheit
    46.4 Degrees! Not bad.
  17. #137
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Yes, 8° Celsius = 46.4° Fahrenheit. A DIFFERENCE of 8° Celsius = a difference of 14.4° Fahrenheit.
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
  18. #138
    Dec 23 2009
    Bucharest / ROMANIA
    If I will upgrade to the 3.0tdi intercooler, what will happen to the plastic sides left and right of the existing IC? They will have to be removed, trimed, or the 3.0tdi model be purchased?
  19. #139
    Feb 19 2014
    RVA
    I just trimmed them down
  20. #140
    Apr 22 2012
    Norway
    I replaced them with the 3.0TDI plastic. Looks a bit more stock.
  21. #141
    Dec 23 2009
    Bucharest / ROMANIA
    And do you have the part numbers for them, please?
  22. #142
    Aug 02 2014
    East Tennessee
    Would love to have this part number as well! Thanks
  23. #143
    Dec 23 2009
    Bucharest / ROMANIA
    The 3.0TDI air guides are 8K0121283F and 8K0121284F
  24. #144
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by lucian_1985 View Post
    Stage 1 more than you RS3
  25. #145
    Veteran Member Four Rings Frinkferta's Avatar
    Aug 27 2012
    Earth
    Ive got a 3.0 TDI IC for sale in the classifieds if anyone is interested. It's $110 plus shipping
  26. #146
    Jun 26 2014
    Killeen, TX
    No need to waste your time with factory parts that won't come close to our kit. Best part its on sale for $895!
    Link to EuroCode intercooler the only complete kit on the market for the B8
    I know this is almost a year old, but I'm looking at purchasing a FMIC and came across this. ?!
  27. #147
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Yeah, I am digging back nearly a year for this thread, but would rather tag on to it than start a new one. I read this, and a few other, when deciding if and then which FMIC I would install. I ended up using the universal inspiration and think I have a great performing setup for under $180, which is partly because I found a $350 IC for $90 because the box had been opened for test fitting.
    It seems the initial purpose of this thread was to compare the different FMICs available for our cars, and being a data driven guy, I am curious as to what real world numbers are. Are there enough others interested in this to setup a test run and data capture process? I would be willing to collect and summarize.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
  28. #148
    Apr 22 2012
    Norway
    Hi.
    I am looking on a K04 kit for my B8 and if I go down that path I might need a lager FMIC. I am at stage 2 today and I have the 3.0TDI IC installed which works great for that tune.
    But if I go K04 I think the 3.0TDI IC will be a bit to small as it only have a core volume at ~8l. (rule of thumb says 3l core volume for every 100hp)
    The K04 kit will probably increase the HP to about 350 ish and for this I need a IC that have a volume for about 10l.
    The best match I found so fare is the FMIC from Unitronic that have the product code UH005-ICA. The size of this core is 20.5" x 4" x 8" and should be around 10l.
    Unitronic says this is a bolt on IC so I guess the installation will be the same for this compared to the 3.0TDI (will use the stock mountings)
    Is the anyone here using this IC?
    Is it any good?
    (Oh and I live in Europe, Norway and I am having a hard time finding someone that have this IC and are willing to ship to my country)
    The next IC on my list is the one from CTS TURBO B8 A4 2.0T FMIC KIT (600HP) but it got a 12l core volume which might be a bit overkill and also it's not stock mounting.
    I am also a bit unsure about the installation coz my car has the headlight washer and I know this can be a problem for some FMIC's.
    Anyone here using this IC?
    Will this give more turbo lag coz of the size?
    Regards
  29. #149
    Jan 10 2012
    Republic of Boulder
    Quote Originally Posted by context.eax View Post
    Hi.
    Is it any good?
    Regards
    I am running the CTSTurbo FMIC on my 2014 allroad (with headlight washers), and the hoses and intercooler do not interfere with them at all. But, you will need to trim off some plastic on each side of the intercooler, as the outlets of the CTS FMIC & hoses cannot get past them without modification. It isn't a difficult install, as the only modifications you'll need to make are drilling into the crash bar as well as trimming those plastic bits. There probably is a little more lag but I haven't really noticed it. However, I can say that when the turbo kicks in it pulls very noticeably harder. CTSTurbo's quality is fantastic, and I highly recommend their products.
    Hope this helps.
    PREVIOUS:
    1991 Audi 200TQ Avant
    2001 Audi S4 Avant
    2009 Audi A4 Avant (click)
    2014 Audi allroad
  30. #150
    Established Member Two Rings inv3rtig0's Avatar
    Oct 22 2014
    1976 Toyota Celica GT
    Paso Robles, CA
    Maybe a dumb question, but does that fact that the top 1/3 of the intercooler is being blocked by the crash bar matter at all? It seems like it'd be significantly less functional since there is no airflow going over that section.
    2010 A4 Quattro Prestige 6MT S-line | build thread
    Revo stage 2 | 034 HFC | AWE Quad exhaust + downpipe | 034 trans mount insert | interior LEDs | ECS short throw shifter
  31. #151
    May 13 2015
    Calgary AB
    Quote Originally Posted by sbryden7 View Post
    Not really no. Air isnt linear. secondarily, the moving air through the fins that are exposed will also cool the upper portion of the intercooler, and thus the air flowing through it, as a byproduct of being one solid conductive unit.
  32. #152
    Apr 22 2012
    Norway
    Quote Originally Posted by secondchance View Post
    So say if you remove the crash bar (Yes I know you wont but just for a test) then would this IC produce cooler air?
    Now I am far from any IC expert but logical I would think this IC would operate better without the bar..
    If so then perhaps the IC from Unitronic will be a better cooler since the whole core will be exposed to air flow (nothing is hidden behind the crash bar)?
  33. #153
    Apr 22 2012
    Norway
    Quote Originally Posted by crash1121 View Post
    Hope this helps.
    Thanks for your answer and all the nice pictures. :)
    I guess there will be no problem with the headlight washer hose then.
    But you say you have to drill into the crash bar. Wont that weaken the structure of it?
    I know non of us will crash our cars but what if? :)
  34. #154
    May 13 2015
    Calgary AB
    In theory it would produce nominally cooler air, but the effect would not be noticeable until you were pushing the threshold of the intercoolers suggested power levels. that power levels rarely seen on the a4's. Like 600 hp +
    Its certainly not even remotely worth the safety risk removing the crash bar. The fins behind it still receive effective amount of cold air as it is.
  35. #155
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    The bottom portion of the intercooler would most certainly provide better performance than the portion that is behind the crash bar. The airflow through the cooler is going to be driven by the total pressure differential before it and after it. Total pressure is the sum of velocity pressure and static pressure. There will be virtually no velocity pressure behind the crash bar, but there will be static pressure: the entire intercooler/radiator/AC condenser assembly present a restriction to the airflow that will cause some of the velocity pressure from above and below the bar to be converted into static pressure. In air conditioning, we have what we call the "45° rule"... if you have an obstruction before the cooling coil, you want enough space between the obstruction and the coil so that the there is no more than a 45° angle required for the air to re-distribute over the entire face of the coil. That doesn't mean that at 45°, the air is distribution across the coil face is completely even, that's just considered a compromise point where the affect from the upstream obstruction is reduced enough to be acceptable. Hard to tell from the pictures, but it looks to me like there's not nearly enough space to clear the 45° rule (go up 45° from the bottom of the crash bar, the intercooler looks close enough that you would hit the intercooler before clearing the top of it).
    It's not ideal, but the affect is probably not very noticeable. Even the top portion will be contributing to the cooling, just not as effectively as the bottom. Intercooler sizing is a trade-off: the bigger they are, the better they cool, but the larger the internal volume, the more they can affect transient response due to the time needed to pressurize all that space. The top portion will be additional volume that doesn't provide as much cooling for that trade-off. But as said, removing the crash bar shouldn't even enter into anyone's mind, especially for such a trivial difference.
    '11 S-Line A4 Avant
  36. #156
    Veteran Member Three Rings Carlos74's Avatar
    Mar 30 2014
    Palatine, IL
    So I'm going APR Stg 2 next month... currently still on stock IC and I'm thinking of going with the 3.0 TDI IC and EC Silicone IC kit. Should I get the IC and hoses installed before ECU upgrade? or does it matter if I do that after getting flashed?
  37. #157
    Jun 05 2009
    Scottsdale Arizona
    I would get it installed if you have the funds now. That way you are all set once your get flashed.
  38. #158
    Apr 22 2012
    Norway
    I installed the IC after the tune so that I could compare them using vcds.
  39. #159
    Veteran Member Three Rings slowone11's Avatar
    Feb 15 2015
    Castle Rock Colorado
    Any one try the unitronic front mount?
  40. #160
    Apr 22 2012
    Norway
    Quote Originally Posted by slowone11 View Post
    Yes. I just installed in on my car a week ago. There was a small fitment issue so I had to trim some plastic of the front bumper plate. Still waiting for an answer from Unitronic support.
    I really like the design of the Unitronic FMIC. The whole core is exposed to air flow and will give max cooling.
    When temp dropped to 18C I could go out and log it like I did with the stock FMIC and the 3.0TDI FMIC.
    Here are the result:
    I kind of knew it would be a bit better but I did not expect 8C cooler compared to the 3.0TDI. The reason I am upgrading is that I am also upgrading my turbo to a K04. (log was made with the IHI K03)
    I have a lot of pictures in my K04 thread if you want to have a look:
    http://www.audizine.com/forum/showth...g-K04-on-my-B8
