Page 1 of 6 123 ... LastLast
Results 1 to 40 of 218
    Veteran Member Three Rings cdn20valve's Avatar
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    Frankenturbo FAQ
    A summary for those that don't have time to read the long thread.
    Early BETA MK1 F4h-l, the first FT on an Audi, compared to K03s. Note: MK2 housing is identical to MK1.
    FT Tunes
    APR 1+
    18 psi spike, holds 12psi to 7000rpm. ECU adjusted for extra flow, and AFR was spot on, no issue with driveability at all. No limp mode, no overspiking. Wastegate was set as received in the box. Power was a touch better than K03/k04, but without the massive torque spike. Turbo did not choke pass 5000 rpm, but near redline, the software controlled the boost back to 12 psi.
    APR K04
    18psi spike, holds 12psi to 7000rpm. Very similar to the 1+ file. No driveability issues. AFR spot on. Not really worth the $250.00 I paid for this upgrade. If you currently have APR 1+, I would either spend $500 and get another tune, or keep the 1+.
    Note: Both APR tunes were 91 octane files. Not 93 octane The 93 octane may have allowed for more boost at redline, albeit unlikely. They probably just advance the timing more.
    Both very reliable files. No issues at all. The turbo was babied.
    REVO
    Did not work out. Had boost control issues. Test car did have lots of running issues. So it's hard to say. REVO should be very similar to APR, so I'm surprised it did not work out. I don't think we should discredit it so fast.
    Unitronic 2+
    20 psi spike holds 16-17 to redline. This is a great tune. As soon as I got the car flashed, I couldn't wait to go back on the dyno! The dyno results? The highest HP K04'd A4! 239awhp. 265 awtq! A beast, with no lag. Granted, Mike at UNI said he bumped up the base 2+ file for me my 2 psi. So if you opt for this, make sure to ask the Uni dealer, for the 2+ file that was used at waterfest 2010 for the FT Audi A4. They hopefully keep records of their files. Again no driveability issues. AFR spot on, no limp. The 386cc injectors, are pretty much maxed out, so this is the ceiling for this tune. There is no getting better than this without drastic changes to the software. If you already have UNI, than this is a 100% easy decision. Get this file.
    Motoza
    New player on the block. Dave, who owns a B6 FT himself, has created a special tune for our cars. His car made as much power as mine, without meth, and at high elevation! The price is the same as a base tune from the big three, and he tunes for 440cc injectors. I do not have first hand experience with him, or his company, but Slappy (Doug) recommends him, and so do a few other forum members.
    SAI delete and Test pipe options avail at no extra cost.
    Giac Unknown, someone step up to the plate!
    To be continued...
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    My setup
    First of all, I'm not using the FT manifold. As someone who has spent years working on cars, I cannot put up with the stress of installing a high flow mani on our engines. I vowed a long time ago (after doing my first one, never again!) If you can put up with the install, more power to you!
    F4h-l
    FT TIP
    Stock ported exhaust manifold
    Cone air filter, custom heatshield
    034 3" cat
    TT 2.5" downpipe
    Magnaflow 2.5" exhaust
    Stock SMIC
    Labonte Water/Meth kit with MAF based contoroller (basic kit) using -35'c windshield washer fluid. ;)
    386cc TT injectors
    Unitronic 2+ file with slight 2psi boost bump, courtesy of mike at Uni.
    Install tips
    - Your goign to need a k04 install kit, as gaskets and bolts do not come with yout FT. Install kit comprises of exhaust mani to turbo gsk. Turbo to cat gsk. Three bolts for Mani to turbo, and the three turbo to cat studs. You'll also need the new oil return gasket, and the seals for coolant and oil lines.
    - If using the high flow manifold, you'll need longer bolts than oem.
    - The heatshield below the turbo on the B6 is massive. There is not much room for the wastegate arm to move. When i first installed my turbo, it got caught, and I overboosted. This may have been a BETA test issue, but I have gotten IM's from others saying the same thing. So it needs to be said here. The solution is to punch down the heatshield so that it is flush with the mount below it. Also, I remove nut 'c' clip retainer from the wastegate rod. I snugged the nuts up good, and they never backed off. I suggest you do the same. Once the turbo and mani are in, it is next to impossible to access that area wihout taking off the mani or turbo.
    - Manifold, just like all other high flow K03/4 manis are a pain to install. Bend a wrench, have a couple beers, pray. Whatever it takes.
    - The TIP is larger than stock, but all aftermarket TIPS are simlar. Clearance is tight with the HID's.
    Other than the above, it's the same as any other K04 install.
    If I think of anything else, I'll add it. If anyone else wants to share info from their setups, be my guest.
    MAF
    The FT TIP is made for 3" MAF. However, many tunes only call for stock maf ( Uni stg 2+ and APR) You need to use the maf that your software calls for.
    In my case, I'm using the stock maf. Of course the FT TIP is too large for the maf. Here is the easiest solution:
    Take the stock TIP, cut off the last ring. Place it on the stock maf, then slip the FT TIP over it and clamp it down strong. As long as all the surfaces are clean, it will never slip off. Mine has not moved in over a year. The seal is perfect. Hope this helps.
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    Veteran Member Three Rings BerNur's Avatar
    Jan 31 2009
    Brandon FL / Astoria NY
    good post very informative thread saving this post when i get my stuff up and running correctly then i will edit
    on another note two thumbs up for Franken Turbo and Motoza
    Apr 08 2009
    Connecticut
    This post is the fucking shit. good work.
    stock
    Senior Member Three Rings jordon's Avatar
    Sep 24 2010
    2015 S4, BMW ///M5, Mercedes R320 CDI
    Saskatoon, Canada
    Quick question: does the FT tip require a different maf? I heard you need a Audi TT maf housing with the stock maf sensor, is that correct?
    Ps: thanks for this write up- great job of condensing the info!
    2013 S7, Phantom Black. B&O, Innovation Package, Cold Weather Package, LED headlights, Carbon Atlas Inlays
    2008 Mercedes R320 CDI, AMG package, Kleeman KD Box, Diesel people hauler
    past:
    2015 S4, Technik, Sepang Blue, Black Optic, Sport Diff, Beaufort Aluminum Trim, H&R lowering springs
    2000 S4 Nogaro, 6spd. Gone too soon
    2001 BMW M5, Imola Red, Evolve AlphaN tune, muffler delete
    Various other Audi, VW, and BMWs
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    I'll add MAF info above.
    Dec 10 2009
    dad- 2002 2.7t allroad
    Champlin, MN
    Ive been doing some research and am definitely looking into doing the uni stage 2+ FT to my a4 come this summer. This thread is really awesome for newcomers to turbo replacements and provides great info. I would also suggest going onto the FT website, they provide great answers to common questions. Needless to say I am super excited about getting further into this "build" come summer!
    Those numbers are incredible with the uni tune.
    Senior Member Four Rings spector's Avatar
    Sep 08 2009
    SE
    Can we get a sticky, mods?
    Senior Member Three Rings Outerfroggy1's Avatar
    Nov 18 2009
    Newfoundland, Canada
    THANK YOU
    Oct 29 2005
    10speed
    San Francisco, CA
    Your post is a bit misleading considering you did 192 on a dyno dynamics and 230 on a dynojet. To be honest if you went back on the dyno dynamics I bet you only picked up 10awhp
    - Clint
    Veteran Member Three Rings daghstdrummer's Avatar
    Feb 09 2007
    2012, Honda CRV - 99 Ford E-150 Conversion van
    Astoria, N.Y.
    Quote Originally Posted by spector View Post
    ^x2
    2002 A4QM 1.8t Frankenturbo Tuned by SSP... R.I.P.
    135
    24R
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Having not read through the long thread, or noticed this anywhere. Is it possible to order just the turbo?
    Dec 01 2007
    Orange County, NY 10918
    Nice write up.
    * Revo Tune user here: I had the FT and like cdn20valve stated it wasnt the best option for the FT. Had to run a MBC to control the boost spikes. BUT once that was installed i spiked at 22psi and held 20psi slowly tappering to 18psi at redline.
    ** I wish my motor held up (not FT related) so i could have produced better results for everyone.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    fuckyeah OP. We've needed one of these for a while.
    Veteran Member Three Rings CamrideA4's Avatar
    Jan 05 2011
    Raleigh, NC
    Quote Originally Posted by Kittrell View Post
    Not sure but I would shoot Doug an email, he's always fast to respond.
    Awesome thread cdn20valve! I'll be able to add Malone's numbers soon.
    2001.5 A4 1.8TQ Tiptronic - FrankenTurbo F4 - 440cc Green Giants - TT225 MAF - Borla exhaust - ST Coilovers - Malone Tuning - Garrett FMIC
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    It's about time, excellent write-up.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Dec 01 2007
    San Jose CA
    IIRC, someone mentioned somewhere that they were available stand alone.
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Quote Originally Posted by CamrideA4 View Post
    You weren't kidding...........
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Too bad I sold my car. *Sigh*
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Veteran Member Four Rings CleanA4's Avatar
    Jun 23 2009
    B5 s4, 06 gsxr, lawnmower
    Chicago
    Wow so glad that Im not chipped yet because I was planning on going with revo but the Unitronic tune is a beast.
    BTW could I see simliar numbers on my tiptronic or does the manual cause a better power output.
    2001.5 S4 -GIAC stage 1, SSAC TWIN ll, OZ Superleggera
    2006 gsxr 600
    2004 USP- sold
    Lawnmower
    NEED A FENDER ROLLER? OR FENDERS ROLLED?-PM ME
    -Admir
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Quote Originally Posted by CleanA4 View Post
    Similar enough that your butt dyno won't know the difference.
    Jun 23 2009
    Chicago
    I would like to know this too.
    My butt dyno doesn't mind all that much just wondering if the power will be smooth meaning no limp mode/acting up.
    2006 gsxr 600
    2004 USP- sold
    Lawnmower
    -Admir
    Mar 27 2005
    The Cold North
    If you are planning on going FT eventually then i would urge you to go with the Uni tune. The Revo tune will require the use of a MBC and lemmi to get the same results as the uni on the FT.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Jan 05 2011
    Raleigh, NC
    cdn20valve - It may be worth mentioning in the OP that the FT (like any K04) is going to put out a lot of hot air at boost and that an upgraded IC or W/M injection is needed. I thought I'd be able to get away with not upgrading that part of my build (stock SMIC) but my IATs are through the roof when it's anything but freezing out. I'd be more than happy to post my 66*C IAT logs if that helps.
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    Franken seems like a good choice, however its disappointing to find out that there is no
    compare to k03/k04. I like torque better than hp
    Veteran Member Three Rings Rirruto's Avatar
    Dec 09 2009
    Ocala
    Can't tell if you are being facetious or not, but no torque spike does not mean less torque. FT has a lot more torque.
    -Bryan
    2005 Dolphin Gray S4
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Quote Originally Posted by BASARAB View Post
    Franken seems like a good choice, however its disappointing to find out that there is no compare to k03/k04. I like torque better than hp
    Too bad the K03/K04 tq lasts for a split second and then falls on its face. It gets old really quick. lol
    Jul 14 2009
    Pasadena
    this
    IG: @matthewee
    Veteran Member Four Rings Bische's Avatar
    Jun 03 2009
    2002 Big Block Avant
    Sweden, north
    Signature material right there haha
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    I would recommend emailing Doug. He will answer that question pretty quick for you.
    Dec 10 2009
    Champlin, MN
    Thats what I continuously hear regarding the ko4 setups, that they get nice torque but not for long.
    Jan 05 2011
    Raleigh, NC
    Torque spike is also what kills rods. smooth torque curve>torque spike
    Jun 23 2009
    Chicago
    Just did. Thanks
    2006 gsxr 600
    2004 USP- sold
    Lawnmower
    -Admir
    Senior Member Two Rings G-Ride's Avatar
    Dec 16 2008
    Imola 2003 A4 1.8TQ 5spd
    Melbourne Australia
    Just did. Thanks
    You'll also need the turbo intake pipe. Your standard piece wont fit the FT as the inlet is larger.
    Imola Yellow '03 A4 Quattro 1.8T 5 Speed
    :: Motoza Performance Tuned on e85 ::
    : Frankenturbo F21-L : Bosch EV14 750cc Injectors : 3" MAF : Milltek Turbo Back Exhaust : AudiSport Suspection : ER FMIC : Sachs RE Clutch : TyrolSport Brake Kit : StopTech & Ferodo DS2500 : Goodridge SS Lines : Forge 008 : 034 SD Engine & Trans Mounts : Apikol Snub & Rear Diff Mount : Podi & VEI Digital Boost Gauge :
    Feb 09 2007
    Astoria, N.Y.
    I also am running revo software and have to run a mbc.. though i have yet to crank it to 20psi...
    135
    24R
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    Nice writeup CDN!
    A VAST custom tune using 440cc Bosch injectors is also a good option for the F4h. It takes a little more effort to get it dialed in, however, it will be dead reliable. Dyno results still forthcoming....
    Dec 01 2007
    Quote Originally Posted by daghstdrummer View Post
    crank that shit up! 22psi on the FT is nice smooth power
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Jan 31 2009
    no lie John you gotta do it
    Dec 10 2009
    Champlin, MN
    From people owning the FT, i would just like to know cause I have seen numbers but want to also hear from you guys. Were you happy with the power increase over a 2+ setup with a ko3? Was it quite noticeable and if you had to do it again would you??
