Results 1 to 19 of 19
    Jul 26 2010
    Turning off warning chime when lights on
    Tried searching and didn't turn up anything. I have a 2010 P+ that comes with the auto headlights and its always on the auto position. I really get annoyed when the warning chime goes off telling you that the lights are on when the driver door is open.
    Is there a way to turn that off? I understand the reason for this feature if its not set on the auto position...
    Jun 02 2009
    San Francisco
    This question would be better asked in the VAG-COM thread in the Tech forum.
    Senior Member Three Rings neptunesfinest's Avatar
    Jun 03 2010
    New Jersey
    As far as I know, this has not been figured out. Doesn't mean it's impossible though.
    Veteran Member Three Rings ACowabunga's Avatar
    Feb 24 2010
    OC, CA
    Or you can just push the reset button on the underside of the wiper stalk to mute the buzzer.
    Veteran Member Three Rings rippin'av's Avatar
    Nov 18 2009
    '00 S4 Stage 3, '05 LR3, '08 ML63 AMG, '02 BMW 1150GS, '71 BMW R75/5
    CA
    Quote Originally Posted by ACowabunga View Post
    That buzzer really used to bug the $hit out of me...yeah, push the reset buttom to mute it.
    2015 Jeep Unlimited Rubicon
    2000 S4 6MT ASP Stage 3
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    i could kiss you
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    i guess i learn something new about my car everyday haha
    2010 A4 quattro, Tiptronic, Ibis White
    Feb 24 2010
    OC, CA
    After finding the mute, I really enjoyed the car that much more. That buzzer is annoying, especially when the ignition is on an I'm looking at stuff at night with the VAG cable.
    Veteran Member Four Rings ThePiombino's Avatar
    Dec 01 2008
    North JerZ
    This I did not know. Learn something new everyday...
    09 A4 2.0T Quattro - Tip - Black/Black /// MODS: APR Stage II+ | AWE CB Exhaust | 034 HFC l EC HFIC Pipe | Forge DV Spacer | 3M Di-NOC Carbon Fiber Interior Trim | 3M Chrome Grille Trim | SG Supreme 28 | Debadged | Fly Eyes Kit (f&r) | Needle Sweep | Window/Moonroof control w/Keyfob | Seat Belt Chime Disabled | "Wink" Disabled | Double Unlock "Beep"
    Senior Member Two Rings SupFly's Avatar
    May 07 2010
    2023 Tuono Factory
    Plano, TX
    i could kiss you
    jus so you know, it's not gay if it's another fellow Audiziner... ;)~
    2010 A4 S-Line Avant | Phantom Black | Huper Op Tint | V-1 Hardwired |AWE FMIC | KW V1's | H&R Rear Sway | K04 - Unitronic Software | APR HFC-Resonator ~ AWE Exhaust | Eurocode High Flow Intercooler Pipe | Carbonio CIA | VAG'ed
    Oct 23 2010
    LA
    How about us people with no Reset button, aka P- people?
    Feb 24 2010
    OC, CA
    Hender: Hahaha. Glad I could help.
    Rookz: I'm sorry, I don't have an answer for you on that one.
    Jul 26 2010
    Wow...thanks! Did not know about the reset button.
    Jun 27 2020
    Sydney
    Same! Thanks again! Will try it out.
    Senior Member Two Rings J.kaseno's Avatar
    Jul 08 2016
    Central Wisconsin
    I used OBD eleven to disable the "lights on" warning tone. Long coding, as it wasnt a preset change. Cant remember exactly how but your answer is found through searching. Vagcom should be capable as well! You'll be so much happier with it disabled. Same with the seatbelt tone!
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by J.kaseno View Post
    Why would somone be happier with a safety warning device disabled or warning their battery could discharge disabled ?
    Just hit the button for the rare times you need too.
    Sent from my SM-G973W using Audizine mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jul 08 2016
    Central Wisconsin
    Just personal preference I guess. I disabled my seatbelt warning, because I could even though I wear a seatbelt religiously. The lights on chime drove me nuts. Anytime I made a stop and jumped in or out it would go off. Many times I leave the car running and run in some place and got sick of hearing it, as did my passengers. My lights almost never leave the auto position. So yes.. Its night, I lwft my car running, I got out real quick...There ia absolutely no need to tell me my lights are on. To each their own
    Jul 08 2016
    Central Wisconsin
    I believe this is the thread I used to disable the "Lights on" warning.
    https://www.audizine.com/forum/showt...-annoying-beep!
    Like anything use at your own risk.
    Feb 15 2016
    Cambridge,Ontario
    fair enough...
    i guess we all have different pain tolerance for things.
    1976 Yamaha XS 360
