Page 1 of 6 123 ... LastLast
Results 1 to 40 of 210
    Veteran Member Three Rings vwong's Avatar
    Apr 03 2006
    '10 S4, '09 335i, '98 Prelude
    DIY - B8 S4 Oil Change
    **edited 6/6/2011 for correction on the tool used for drain plug**
    **edited for corrections, thanks to dr bryan for pointing out my errors**
    I searched around to see if there is a DIY on oil change specifically for the B8 S4 (found one for the A5 3.2, which is similar). Unfortunately, there isn't any at the moment. Therefore, I decided to create one. BTW, some pictures below turned out to be blurry.
    Disclaimer: The info below is my procedures on an oil change. I will not be held responsible for any injuries you may cause from your own action.
    Tools required:
    - ramps
    - large Phillip (or large flat-head) screwdriver
    - 6mm allen wrench
    - 36mm socket or large adj. wrench
    - 1/2" drive ratchet (used with 32mm socket)
    - needle nose pliers
    - lots of towels
    - drain pan
    - funnel
    Parts required:
    - 8 quarts of oil (the pic below only shows 7 quarts only)
    - oil filter
    First, warm up the engine a little bit. Then drive up to a set of car ramps. You can purchase those car ramps from your local auto parts store. I just happen to have a set of custom built ramps from the days of my lowered Prelude. After driving up to a set of car ramps, just for precaution, put something behind the rear tire to prevent the car from rolling back.
    Remove the lower engine cover, belly pan, whatever you call this thing. There are 11 lock screws (3 in the back, 2 in the front, and 3 on each side just in front of the tire). Use either a large Phillip screwdriver or a large flat-head screwdriver to undo those screws. The 3 screw in the back stay with the lower engine cover, so don't waste time trying to remove them off the cover. Then set the cover aside.
    Now you can see the oil pan. The drain bolt is located on the bottom of the oil pan. Put the drain pan under the drain bolt. Use a 6mm allen wrench to loosen it. Because of the orientation of the drain bolt, it's very messy. It's recommended to put lots of newspaper on the floor under the area to absorb any oil that doesn't end up in the drain pan.
    While letting the old oil drain, remove the filter/filter cap. It is located on the top toward the firewall. Make sure you put some towels around the filter cap to catch the oil. Use a 36mm socket and ratchet to undo the cap. If you don't have a 36mm socket, you can use a large adj. wrench.
    Here is the old oil filter still installed in the filter cap.
    Here is the new oil filter, o-rings, and crush washer.
    After separating the old filter from the cap, replace the o-ring in the cap. This o-ring is the one with the tap, and make sure you install the o-ring with the tap facing down. The tap is there so you can use a needle nose pliers to remove it.
    The other o-ring is located on the "neck" of the filter housing.
    Install the new filter into the cap, then screw the cap back onto the engine. I think the torque rating is molded on the cap. Then replace the crush washer on the drain bolt and screw it back onto the oil pan. Wipe clean the areas, then re-install the lower engine cover. You're almost done.
    Now fill up the engine with your favorite engine oil. I prefer Mobil 1 0W40 (European formula). I used a funnel, however the funnel cannot sit completely into the fill hole because there is mechanical components just under there. Also, when you fill in the oil, don't just pour the entire bottle into the funnel. It will spill all over the engine cover. Fill it slowly. I initially put in only 6.5 quarts of oil as in the DIY for the A5 3.2. But after a short test drive, the MMI showed that the oil level wasn't even half in between max and min. So I put in another 3/4 quart (making it a total of 7-1/4 quarts of oil), and everything was fine.
    So after filling up, put the oil cap back on. Wipe clean the area if needed to. Then go for a test drive. If you don't have a dip stick like me, after the test drive, shut the car off. Then turn the ignition on without starting the engine. Wait about 2 minutes, then the oil level will show up on the MMI screen. If the level is ok, congratulation, you're done!!!
    2010 Audi S4 6MT
    2009 BMW 335i Coupe 6MT
    YouTube Channel
    Senior Member Two Rings rugbylion's Avatar
    Apr 08 2009
    2009 GMC Yukon Denali XL
    South Bay (CA)
    great write up...appreciate it.....
    2010 Audi S4 , Meteor Gray, S-Tronic, Sport Rear Differential, Black/Black Silk Nappa Seats, B&O, NAV
    Mods: APR Exhaust, Stasis ECU Tune, Ohlins SL suspension, AWE S-Flo Intake, 20" Stasis Wheels, Eurocode Alu Kreuz Stabilizer, RS6 Shift Knob
    Mar 26 2010
    US
    Why not vacuum oil the top side?
    I used the Mityvac on my old Mercedes, requires no operations under the car. It works fine
    for the Mercedes, why not on the Audi? One inserts the tube down the dipstick tube.
    http://www.google.com/products/catal...d=0CDsQ8wIwAw#
    BMW M3 Competition X-drive
    Apr 03 2006
    ^^^ I like the old fashion way. If I didn't have to take the pictures, I'm sure I can finish the oil change in about 1/2 hour. That's how long it takes me to change the oil in my E92 335i.
    2010 Audi S4 6MT
    YouTube Channel
    Sep 12 2008
    South Central PA
    Quote Originally Posted by wwhan View Post
    because the new engines don't have a dipstick, duh.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Senior Member Two Rings akim_hobo's Avatar
    Nov 25 2009
    bellevue WA
    Is there even a place to suck out the oil? If there's no more dipstick, I'm not sure where you'd put the hose to ensure you suck out all the oil. I used to do this with my S40, oil changes took 30-40 mins and was a breeze with no mess.
    2011 S4 :: Prestige :: Stronic :: Meteor Grey :: Sports Diff. :: Carbon
    AWE res exhaust :: AWE Intake :: Alu Kreuz :: PSS10 :: USS
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    There is a dispstick hole, and a traditional dipstick is available for the S4, you can use this method. There is something to be said about using gravity though, the plug in the pan is the lowest point, and if the oil is nice and warm, it's more viscous. The worst pieces of metal and foriegn objects will settle to the plug and are possibly more likely to be carried out with the old oil than from a suction system.
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Veteran Member Four Rings t0mt0m's Avatar
    Apr 26 2005
    Nothern Va
    thank you for this write up, i was planning to do mine in this weekend!
    B6 A4 1.8t 5MT Quattro - Sold
    B8 S4 '10 6MT Prem+ - Sold
    Aug 07 2010
    Vancouver BC
    isnt the whole point of an oil change (other than putting in fresh oil) is to drain out contaminants, dirt, metal shavings etc etc?
    i wouldnt use that vacuum method at all, thats the jiffy lube way of changing oil.
    Mar 26 2010
    US
    The Mercedes C32, in 2002 did not have a dipstick. Plus the the newer AMG models did not have a dipstick either,
    but they all have the dipstick tube for top extraction.
    The Mercedes dealers have been changing oil by extraction through the capped dipstick tube for at least 8 years now.
    Many of the owners have been doing this also. It has worked perfectly fine for many years, with even Mercedes C32s
    that have reach high mileage levels.
    Established Member Two Rings HDClown's Avatar
    Aug 20 2010
    Orlando, FL
    I like to use top extraction via MityVac on "in-between" changes. Those being the oil changes that are in-between the manufacturers recommended intervals, should you subscribe to the mentality of changing the oil more frequently than the manufacturer recommends. It's quick and clean and this way you still get the bottom drain, just not every time.
    2011 S4 - Quartz Gray on Black Alcantara - S-Tronic, Sport Differential, MMI Nav Plus, B&O, Carbon Atlas Trim, 19" Five-Tri-Spoke Wheels
    Senior Member Two Rings dr bryan's Avatar
    Apr 12 2010
    Tualatin, OR
    Thanks, just did mine this weekend. Great writeup. Oil filter socket is 36mm (not 32) and drain plug is a T35 not 6mm allen.
    '17 S6
    Veteran Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2013 Jetta GLI
    Ohio and GTA
    very nice write up
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG (Gone)
    2012 S4, Monsoon Gray, 6MT (Gone)
    2014 S4, Glacier White - fully loaded (Gone)
    2019 S4, Glacier White - Prestige
    Senior Member Two Rings rx7ven's Avatar
    May 14 2010
    2007 Mazda Miata
    San Francisco
    i hope im not hijacking the thread as its somewhat related. i was wondering about the brand of oil to use. the shop that i normally goto for oil changes uses amsoil synthethic oil. was wondering if i can use that for the s4.
    1988 10th Anniversary RX7 (sold)
    2005 Mazda 6 (Totaled)
    2007 Mazda Miata
    2011 Imola Yellow S4
    Apr 12 2010
    Tualatin, OR
    There is a good thread about that titled "Break in oil and first oil change??" over on AW.
    '17 S6
    Established Member Two Rings newtonc2001A4V6's Avatar
    Jan 23 2006
    2011 Audi A4 2.0T, 2004 Lexus RX330, 1977 MG-B
    Colorado
    Quote Originally Posted by Dan[FN]5857 View Post
    Not a physical dipstick, but the car still has a dipstick tube that can be used with an extractor. Speaking of which, the oil extractor's work great. On my V6 A4, I used it and removed the drain plug to see how much additional oil came out (and install a fumoto valve) and there was very little additional oil. As with the other poster, I also follow the procedure of every 5K I extract the oil and every 10K, the dealer takes care of the oil/filter.
    Jul 27 2010
    Singapore
    I agree wholeheartedly, I do this for all my cars for "in-between" oil chages (more frequent than dealer required).
    Quote Originally Posted by HDClown View Post
    Jul 27 2010
    Singapore
    INterestingly, as I am anticipating the arrival of my S5 Sportback, which has the same 3.0 V6 TFSI as the S4 and the S5 Cabriolet in the USA, I couldn't find the dipstick for this engine on the Audi parts system. I suspect that this particular engine is the exception - there is no dipstick that can be bought - only a plug that comes from factory.
    Is this true? S4 owners, anyone got a dipstick?
    Quote Originally Posted by NWS4Guy View Post
    Apr 12 2010
    Tualatin, OR
    My local parts dept did not stock the dipstick or have record of it. I bought one online and it works and is accurate. Search for part number 06E115611H at http://www.genuinevwaudiparts.com/ $23.83 shipped
    '17 S6
    Sep 29 2009
    I said availible, not comes with :)
    Chris has them in stock.
    http://www.ecstuning.com/Audi-B8_S4-....0T/ES2070638/
    $23
    Oct 31 2010
    Lafayette, Colorado
    Just for the record, I changed the oil on my 2011 S4 today and the drain bolt was a T40, not a T35... perhaps they changed it.
    Apr 03 2006
    Just a little update. I did another oil change (at 20k) this past weekend and confirmed that the drain plug is indeed hex rather than torx.
    2010 Audi S4 6MT
    YouTube Channel
    Veteran Member Four Rings ENV²'s Avatar
    Nov 04 2010
    What is the cost of this DIY and what Amsoil is the one to use? I know redrocker mentioned it once
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Veteran Member Four Rings FatalBert's Avatar
    Apr 19 2011
    US
    Resurrecting this thread for a question:
    Does the filter cap just unscrew with only counterclockwise torque? I got in there with the adjustable wrench and it was just not coming loose. Felt like the cap was going to snap if I tried any harder. Was this not an issue for anyone else who has done it themselves?
    Apr 30 2010
    San Diego
    Quote Originally Posted by FatalBert View Post
    I used a big socket and it came right off going counter clockwise.
    2011 Audi S4 | 6MT | Ibis/Black Silk Nappa | Nav l B&O | Sport Diff | Carbon Inlays | H&R l Strat Intake l Strat SS l Alu Kreuz l AWE Exhaust l AG M510 20x10 et35 l GIAC Stg II l DTM Lip l Eurocode Diff Mounts l SS Clutch Line
    Apr 15 2009
    PA
    Were you able to get the filter housing off? Also, did you happen to use something to drain the housing? I am about to DIY the oil change for my 15K service and wonder if the MetalNerd (for example) drain assembly is useful (or even relevant to the B8):
    2019 Audi RS5.
    Aug 04 2010
    Queenz/Westchester
    Quote Originally Posted by RX Renesis View Post
    Magnetic oil drain plug helps too:
    http://www.ecstuning.com/Audi-B8_A5-...n_Plug/ES5386/
    Veteran Member Four Rings phillips2024's Avatar
    Mar 03 2011
    Southern NH
    Quote Originally Posted by JJDubya View Post
    im confused. why are you doing your own 15k service?
    2017 Audi S8+ | 2021 Audi RSQ8 | 2021 Cadillac Escalade Sport Platinum | 2007 Porsche Turbo
    2021 Sea Ray 350 SLX | 2020 Polaris Ranger Crew XP1000 | 2022 Polaris Indy VR1 850/650
    Senior Member Two Rings QSonx's Avatar
    Jan 31 2011
    2013 Scion FR-S, 2016 Audi Q3 Prestige
    Olathe, KS
    Quote Originally Posted by phillips2024 View Post
    Why not? I did mine. Not a lot to do for 15k.
    2011 Audi S4 Premium+ Bang and Olufsen | Sport Diff | Nav | Apr Carbonio Stage I/II Intake | APR RSC Exhaust | APR ECU S2+ | APR Pulley | Vogtland Coil-Overs | Alu Kreuz | SPC Adjustable Control Arms | 19x9.5 VMR V710 | Michellin PSS | AWE Vent Boost Gauge
    Mar 03 2011
    Southern NH
    Quote Originally Posted by QSonx View Post
    just that its free if you take it to the dealer. after my 15 ill be doing my own
    Jan 31 2011
    Olathe, KS
    Could had sworn just our first one was free. Besides I'm not quite ready for a TD1 and I put Motul 300V in there for the track season to try it out.
    Veteran Member Four Rings svander's Avatar
    Mar 16 2011
    '11 S4
    Seattle Metro Area
    It is only the first one that is free.
    Apr 15 2009
    PA
    Since I'm not sure how the TD1 issues will play out, I want to play it safe and avoid the dealership. Additionally, I like working on my own car. Also, only my 5K service was "free". 15K would be on me.
    2019 Audi RS5.
    Mar 03 2011
    Southern NH
    hm..i was told mine would be covered. ill have to double check
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    Did you buy Audicare?
    Mar 03 2011
    Southern NH
    Quote Originally Posted by Stereodude View Post
    no.
    if its not covered by my dealer, which is sounds like it may not, ill prob buy 7L of Lubro Moly Synthoil Premium 5W40
    Oct 20 2008
    Is there suppose to be a washer at the drain plug? there wasnt one on my car, and my mechanic put it back on without one, and no leaks
    "I know it won't create actual downforce at 125 MPH. I know it does make the S4 more stable." - westwest888
    "It doesn't say anywhere in the rule book that a dog can't drive autocross" - westwest888
    "It would be easier if we just accepted my OP as fact in the Audizine sticky wiki. " -westwest888
    Apr 19 2011
    US
    No the filter housing is what I am speaking of. It has the large socket above which I cannot seem to turn loose. It is either on there way too tight, or I am doing something else wrong. It feels like its about to snap if I try to just turn counterclockwise (I'm talking like 80lb + of torque and still didn't come loose). It sounded like an easy feat in the tutorial, and as RavinJetta said it came right off for him. Don't know why mine is giving me such a hard time.
    Apr 03 2006
    Quote Originally Posted by Akatsuki... View Post
    Yes, there should be a crush washer that must be replaced on every oil change.
    2010 Audi S4 6MT
    YouTube Channel
    Oct 20 2008
    Quote Originally Posted by vwong View Post
    Thanks I'll remember to replace it next. still good so far no leaking
    Dont know why my car never came with one.
