Page 1 of 12 12311 ... LastLast
Results 1 to 40 of 445
    Senior Member Four Rings Gaberossi's Avatar
    May 12 2009
    Volcano Black Audi A4 pte5857, YZF R6-no longer running, 95 Toyota pickup
    Parkland,FL
    GabeRossi's Build Thread
    Hey there Audiziners, I am currently in the process Building my B5 A4. I am going with a Precision Turbo 5857 DBB, my power goal is 400FWHP+ and 500+HP when I build the head. Running an AEB 1.8 motor... Usp Motorsports is going to be supplying the parts, install, and software upgrade , Usp has never let me down!! What a great shop!.) I will be updating this as everything goes along. Thanks for looking!!
    **UPDATED: 2-1-11**
    Parts....
    Engine:
    AEB 1.8L
    JE Pistons
    Integrated Engineering Rods
    ARP Head Stud Kit
    Main Bearing Set
    Rod Bearing Set
    Thrust Bearing
    Knock sensor
    Head Gasket
    Crankcase Gasket Set
    RS4 Motor Mounts
    034 Transmission mounts
    034 Snub mount
    Usp Motorsports custom catch can setup
    Turbo/ECU:
    Pag Parts Turbo kit/exhaust manifold V-banded
    Precision 5857 Dual Ball Bearing Turbocharger .64 V-banded
    Oil feed/return lines
    Eurodyne Maestro
    Forge DV
    Tial MVS Wastegate
    Precision 600hp core w/ custom Usp Motorsports Inter-cooler Piping
    MAF/Harness
    K&N cone filter
    Fueling:830cc Injectors
    044 fuel pump
    Exhaust:
    Custom Usp Motorsports 3in Down-Pipe/3in Down-Pipe back exhaust all V-band
    Trans: OEM 5 speed with southbend stg 4 (4puck) clutch and LWFW
    JHM shifter assembly, weighted shift knob and linkage with delrin bushings
    Wheels: Team Dynamic Pro race 1.2 18x8.5
    I ordered Raxle's to help me stop breaking axles
    99.5 A4 1.8tMan AEB FWD-SouthBend Stg 4 (4puck)clutch-SB LWFW-Stern Control Arms -830cc -Custom USP 3in exhaust/DP - PTE5857 Ball Bearing Turbo- JE Pistons/IE Rods-EurodyneMe-Coilovers-AWE DTS-034 Mounts-Team Dynamic Wheels-BFG KDW2-and a whole lot more..-Sleeper-USP Motorsports #1 Shop!-VEI SYSTEMS[Currently employed]
    Click>>>>>My Build Heel-Toe'n the b5 everyday =P
    Senior Member Three Rings Polski's Avatar
    Sep 21 2009
    1997 Audi A4 1.8TQM w/sport & winter pckg
    Montreal
    im intrested in ur k04 setup, pm me what is included in the setup and some prices.
    Thanks
    MontrealAudiClub
    May 12 2009
    Parkland,FL
    pm sent
    Senior Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    08 GLI,08 Jeep, 99 MK3 jetta VR6
    Palm Beach,Fl
    Good stuff Gabe. Let me know if yo need any help with anything.
    034 Stage 3 BT, Unitronics,H&R,etc,etc
    Senior Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2011 MKVI GTI 4 Door DSG
    Pittsburgh/PA
    Car looks good
    Hot Photos<--Click Here
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG
    2012 S4, Monsoon Gray, 6MT
    www.AskMy2Cents.com
    Veteran Member Three Rings chris164935's Avatar
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Pretty sure the AEB motor doesn't have balance shafts. Only VAG motor that I know of that has balance shafts are the 2.0t FSI motors. They might have been referring to the intermediate shaft? But that's not really any kind of problem... That I'm aware of anyway.
    Best place I could think to find an 058 block would be VWVortex classifieds.
    As for the clutch, I'd recommend doing the FX400 swap while your have the block out of the car (if you are planning on pulling the whole motor out); that will save you from having to drop the sub-frame to pull the transmission to swap out the clutch later. Clay at CTS Turbo has them for pretty cheap now.
    In any case, good luck! Oh, and you will be kicking yourself wishing your car was Quattro when you are done with the build. Ask me how I know. Lol.
    "You know you have a bad idea when Ford guys are making fun of you."
    "The Internet is dead."
    FS: Bullseye Power S372 1.10AR Divided T4 W/ Standard Cover.
    May 12 2009
    Parkland,FL
    Quote Originally Posted by chris164935 View Post
    Great info Thanks!! HAH i have been kicking my own ass for the past 3 years wishing it was!! I got the car from a family friend then had a whole lot of bs happen to the car and a ton of money went in it...this is going to be my weekend/show car when its done and i plan on getting an B5 S4 or BMW E30 M3
    May 12 2009
    Parkland,FL
    Bump for update...and a quick pic of the engine bay with a K04 setup BEFORE its gets torn down!
    Senior Member Four Rings Seerlah's Avatar
    Dec 05 2007
    Engine already built? Doesn't seem you held back on this build, minus head work. I would have gone a different route with the header, though. If I were going tubular, I would have contacted Jay Thorton. PM me if you want info.
    I hate it when my car acts like a little bitch, treating me like the bitch
    FS:Brand New K&N Air Filter RU-3700 (3" inlet, 5" base, 4" tall, 4 5/8" top), Brand New 3" Injen (Amsoil) Dry Filter Setup with Heat Shield, Brand New OEM 06A Oil Pump, Used Greddy Intercooler...throw me some offers
    May 12 2009
    Parkland,FL
    I just got all parts ordered and now im waiting for them to get here...Head Work will be done when i can get a spare AEB head and the money$$...but for now i dont plan on going WOT very often...i just want the car to have a nice setup for FIXX Fest
    Registered Member Two Rings Nate_R's Avatar
    Aug 11 2010
    Camano Island, WA
    Car looks good. I've been thinkin of gettin my car to 400 bhp but haven't really researched it. I was wonderin how much it cost you to build your motor? And is there any huge advantage in going with a Precision 5857 turbo over a 30+r?
    May 12 2009
    Parkland,FL
    PM'd^^Nate_R
    I think the pte5857 flows more than the 30r
    Senior Member Three Rings Papa Stone's Avatar
    Jul 25 2008
    Chev Z71 DD
    San Juan PR
    It does, but is also has a slower spool. If you are researching the block, you should really look into going 2.0L. It will help with spool and more HP.
    official AWE/GIAC dealer in Puerto Rico
    Chevy Silverado Z71
    Audi A4 Avant(Project Scary)
    http://www.audizine.com/forum/showthread.php?t=270772
    May 12 2009
    Parkland,FL
    I know that the 2.0L is the way to go for spool... i feel that a 1.8 or 1.9L will be more reliable...i dont mind the lag anyway.
    Dec 05 2007
    Expand the power band and the lag shouldn't really be a big concern. These cars love to drive in the higher RPMs.
    May 12 2009
    Parkland,FL
    I totally plan on it in the near future Seerlah... when i can afford it i am definitely building the head..i should take a pic of the invoice ..it really jumps in price when u add a head job lol i would not have a dime left if i build the head now.
    BTW Seerlah how is your hunt for BT parts coming along??
    Oct 06 2004
    Minnesota
    Cool project you have there. Moved to projects and builds.
    AZ B5 & MW Moderator: PM me with any concerns or questions
    '99 Audi A4 1.8T Holset HX35W- Widebody- Matte Green -PVW 11.09
    R135
    246
    May 12 2009
    Parkland,FL
    thanks Rob!
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    1.8L with a 5857? I'm curious to see how this will turn out... Can't really take advantage of that turbo without bigger displacement or a built head. I'd go smaller so you can actually have some more usable power.
    otherwise, cool build. I love those team dynamic wheels.
    The most heavily built K03'd engine on Audizine...
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    May 12 2009
    Parkland,FL
    thanks dude i love these wheels...once the head is built i think it will be just fine, i want this together by fixx fest this year so i can have some fun runs down the track.
    Senior Member Three Rings Oceanside's Avatar
    Dec 12 2008
    2001 A4
    St Pete FL
    Quote Originally Posted by Gaberossi View Post
    I officially challenge you to a duel of the FL FWD BATS! :)
    AWM BAT A4 / AGP D42 .48 / Tapp 630 / IE Rods / LwFw+ S4 SB / APR Stealth / Garrett-Precision 450 / 2001 FWD Highway Menace
    Jul 12 2008
    Palm Beach,Fl
    I am going to try to get in on this too. Hopefully I can get a better clutch.
    May 12 2009
    Parkland,FL
    Quote Originally Posted by Oceanside View Post
    I accept hahaha!! FWD BAT's FTW!
    May 12 2009
    Parkland,FL
    Quote Originally Posted by lowandslow4now View Post
    yea man get that clutch so you dnt have to worry about any slippage
    Jul 12 2008
    Palm Beach,Fl
    I know I have been lucky so far but if I want to put it on the track and run it hard I will definetely need a new clutch.
    May 12 2009
    Parkland,FL
    oh definitley dude...that monster of a setup you have needs to be unleashed
    Senior Member Four Rings Dan[FN]6262's Avatar
    Sep 12 2008
    02 A4, 94 GMC, 06 450R
    South Central Pa, Dundalk MD
    PM'd^^Nate_R
    the 5857 flows almost as much as a 35R
    35R flows 65lbs/min
    5857 flows 60.5lbs/min
    30R flows 50lbs/min
    a 5857 will make more power on a lower boost than a 35R. example: 35R @ 20psi will make less power than 5857 @ 20psi. This is only true up to a certain pressure, but I can't remember what it is. This is because 5857 has Extended Tip Technology
    Also, you'll want a better clutch than a FX400 if you're running this turbo. I would recommend the FX850 Super Single. I have one, and I love it. and its only slightly more expensive than a FX400
    Quote Originally Posted by Kyle H View Post
    I'm running a 5857 on 1.8L with stock pistons and built small port head. there is more than enough usable power.
    OP, you'll love it.
    You can see my build if you click on the link in my sig
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    When is FIXXfest this year? Late October, right? I wish I could get in on some of this action. Although, my car won't be FWD.
    As for spool, I didn't have any problems running a 35r on my 1.9L. Boost came on around ~4500 RPMs and that was with a shit tune.
    EDIT: PTE series turbos are ball-bearing AND extended tip?
    Jul 12 2008
    Palm Beach,Fl
    I believe fixxfest is the weekend before thaksgiving November20.
    http://www.fixxfest.com/
    Sep 12 2008
    Yeah, Precision Turbos come in ball bearing and extended tip (as long as they're the new billet wheels). I have a Journal bearing 5857 and I have 18psi by 4.5~ 4.8k rpms on my Revo 550 tune running 0* timing.
    *I wanna see your build finished. lol.
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Apr 18 2007
    2001 Audi A4 1.8tQM
    Orange Park, FL
    Quote Originally Posted by Dan[FN]5857 View Post
    Damn, I'll bet those aren't cheap! I'd love to run one though, if they make a 72mm flavor.
    Me too! Lol.
    Sep 12 2008
    mine was 900 bucks brand new email Clay@CTS Turbo.
    and yeah, Precision makes some pretty decent sized turbos. check them out.
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    May 12 2009
    Parkland,FL
    OP, you'll love it.
    Sweet man thats awesome....i will definitely upgrade to the fx850 when this one goes
    Dec 05 2007
    Didn't even notice this question. Parts are coming along gradually. I don't plan on installing till next spring, so that leaves me plenty of time to get the rest of my parts. But for now, I want to complete my drivetrain and susppension mods. Just ordered Hothckis sways to complete my suspension (I have other goodies already) and now need motor/tranny mounts to complete my drivetrain (I have other goodies installed, and def want to get the 034 billet rear diff carrier in the future for safety reasons). As for turbo build parts, I have these:
    -Catch can
    -ATP fuel rail (need to get adapter to use stock like fpr)
    -630cc injectors
    -PSi Concept t3 manifold
    -PSi Concept oil/coolant line package
    -Forge 004 BOV
    -Injen/Amsoil 3" filter with Hydro Shield
    -Turbo-XS BC-HPBC (hoping the bleed valve will reduce torque spikes and help my engine out)
    -Precision PW39 Wastegate
    -034 Bosch 044 fuel pump (needed to buy replacement pre-filter due to damaged in shipping, and that bad boy ran me $70 for a f*cking little screen filter. bought used, so could not complain to anybody. nor did I want to give the seller a burden, as he is a regular on here and let me pay off in installments)
    Then picked up some other goodies, such as 034 powder coated vavle cover and coil cover. I just need the turbo, clutch, intercooler (Mike Hood is trying to have an intercooler made to fit behind our stock bumper, so I am waiting on that. 530hp garrett core), PSi Concept tp/dp (will have a full custom 3" one made to my 2.75" Milltek, but will need this to get me to the shop), Innovate LC-1 (already have gauge for it), SAI block off plate, and miscalaneous parts (clamps, couplers, hoses, gaskets, etc). Going to try and scoop most of this up during the Christmas sales. Plan on running with the Garrett GT2860RS T3 flanged and .63 A/R (stock block). I have Eurodyne software currently, so my tune will cost me $250 (purchased CTapp originally for my stock turbo flash for this very purpose).
    And you need to update this thread
    May 12 2009
    Parkland,FL
    I will update this thread as the parts get to the shop...Then I can document everything.
    I want that valve cover! I think there is going to be a ton of cutting to my bumper to fit this Precision 600hp core =/
    Stage 3 Forum Advertiser Four Rings Sales@RAI's Avatar
    Jun 22 2009
    Dundalk, MD
    35R flows 65lbs/min
    30R flows 50lbs/min
    OP, you'll love it.
    Dan, while this is cool in theory, I don't know how much the whole extended tip thing does
    May 12 2009
    Parkland,FL
    Got my car on the lift at school today after getting it towed to take out my broken CV shaft on the drivers side...the dealership didn't have one in stock so I had Usp find me one...EDIT: Just Ordered a Raxle
    Active Member Two Rings fr3nz33's Avatar
    Nov 10 2006
    1999 A4 Q 5spd, pretty stockish
    boston/wmass/ri
    I'm building a very similar setup, that should be done in the next week hopefully. PTE 5857 ftw. Subscribed
    May 12 2009
    Parkland,FL
    Are you documenting your build??
    Oct 06 2009
    VW Passat 1.8T GT30R
    Hull, United Kingdom
    Nice Build.!
    B5 S4 Franken Turbo
