Results 1 to 40 of 42
Thread: ICM Delete
    Senior Member Two Rings Triple G's Avatar
    Jan 02 2009
    2015 Audi S4, 2018 Ducati Monster 1200S
    Vancouver, BC, Canada
    ICM Delete
    I am in the process of removing my Ignition Control Modules (ICM) and replacing my 4 wire coil packs with the cheaper updated 5 wire coil packs on my 2.7.
    I have been able to follow this DIY up to the point of bypassing the actual ICMs
    This is a wiring diagram showing the path from the ECU to the ICM to the stock Coil Pack on one bank of a 2.7:
    I had it wired as follows and it did not fire:
    Can anyone tell me what wire from the ECU fires which coil?
    Here is a diagram of the other bank of of coil packs:
    Aug 13 2009
    woodbridge va
    whats the purpose of deleting the ICM?what do you gain?
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Sweet! One less thing to fail...
    Registered User Three Rings Jason@Addict's Avatar
    Oct 14 2007
    Blown RS4
    Woodinville,WA
    Looks good
    Jan 02 2009
    So wiring it this way:
    is correct?
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by tike0rz View Post
    One less part to fail, but replacing the coilpacks with a part that fails 10000x more then stock. I've thought about this route. Not worth the price of changing ICMs every 10 years, opposed to how troublesome those new coilpacks will be. Just ask the 1.8T guys how much they suck.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Why don't you guy's use 034 ones? http://www.034motorsport.com/ignitio...ade-p-449.html
    As what i can see, it also eliminates the powerstages.
    Jan 02 2009
    034 route is quite expensive..
    I've used these coils in 1.8T applications before and they haven't been troublesome. I thought this would be an inexpensive way to update my ignition system.
    Just looking for a quick answer to my question so I can get my car back driving
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Wow if this works this is great news, i see the diagram as this, please let me know if this works.
    Edit see below for newer schematics
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    http://www.s-cars.org/postnuke/downl...structions.pdf
    This should be helpful. Doing the same thing, but for a URS4/S6. We have a 4-pin connector iirc on our coilpacks, they have a 3-pin.
    Also, with that wiring diagram above (re: infinkc), DO NOT SHARE GROUND WIRE between the coils, make a seperate ground wire for each one.
    Jan 02 2009
    I'm not actually having trouble with wiring the new connectors for the coil packs. I have separate ground for each coil, etc.
    Where I'm having trouble is bypassing the two ICMs. Instead of the one ICM the 1.8Ts run where it has 5 wires in (1 ground and 4 signal wires from the ECU) and 4 wires out (4 signal wires that go to the coil packs) we have the two ICMs. I'm trying to figure out what wire from the ECU fires what coil.
    1.8T:
    2.7T:
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Quote Originally Posted by Triple G View Post
    1.8T:
    2.7T:
    Each ICM does it's own bank. I do not remember which ICM does which bank, but you can look that up in the Bentley manual or the link that Kevin posted.
    Feb 13 2004
    S Ã C, CÃ*
    they should all feed through to the respected wire across them, here is a pic inside. use the wire colors and trace them to the corresponding coilpack.
    post back the results so we have them for reference.
    Jan 02 2009
    Thanks, this is what I wanted to know. You can see why I asked though since you cross the wires over with the 1.8T ICM,
    Feb 13 2004
    S Ã C, CÃ*
    oh just noticed something, on the schematic it looks like the wires do have to cross according to the pin numbers, Stupid confusing schematics..
    UPDATED:
    http://img228.imageshack.us/img228/1...eteinfinkc.jpg
    Feb 02 2009
    Cars other people killed
    capital city wastes
    i was going to tackle this one after i finished everything else. replacing the icms with individual coils that have their own power stages is an improvement im sparking power over our setup. it should result in slightly more timing and you can run a colder plug/more gap. nothing huge compared to the cost but it should improve the feel of the car nicely. mabye some more mpgs.
    Jan 02 2009
    Quote Originally Posted by infinkc View Post
    UPDATED:
    This did the trick!
    Thanks a lot, car is running way better now.
    Feb 13 2004
    S Ã C, CÃ*
    This did the trick!
    What part number coil packs are you using? i want to make a new diy page for this.
    Jan 02 2009
    Part number: 06B 905 115 E
    Pretty sure they are the latest revision "E" coil packs. They are made by Hitachi.
    Jan 02 2009
    I can also take a few pictures of what everything looks like this evening.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Hitachi coils FTW.
    Veteran Member Four Rings P0234's Avatar
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    A full writeup would be awesome. I'd love to see some back to back testing before I took the plunge though. I wonder what sort of plug gap these can support vs the stockers.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Did you put on BEL 2.7T valvecovers to support the "pushdown" coils, or just put them in the stock covers?
    Jan 02 2009
    I used the bolt down Hitachi coil packs:
    Senior Member Two Rings titikaka's Avatar
    Dec 25 2009
    S4 00' , A2 Sport 03'
    Bulgaria
    any DIY on that for our S?
    any reviews....?
    Dec 12 2006
    Charlotte,NC
    sweet will be doing this, cause im missing the icm's from my engine i bought.
    MK4 GTi 1.8T converted to AWD
    New 1/8th mile 7.36@102mph-27psi 93 octane, no meth
    New build times 23psi pump 11.9@126mph-96mph in the 1/8th
    04' A4 1.8t frontrak converted to quattro, was RWD for a lil now its quattro finally
    2011 JSW Tdi 6speed manual
    Senior Member Two Rings BlakMarketKlash's Avatar
    Apr 18 2009
    00 S4 ,350 SIERRA, 98 GTI
    Calgary
    alright! glad u got it solved.
    Oct 27 2012
    97 A8 4.2L, B5 S4 SSP Tuned
    i too would love a write up
    i would love a wite up to this with pics ... i want to do this next and cant find a place to have all the data i need to do it ...
    Veteran Member Three Rings Taloras's Avatar
    Jan 19 2011
    PDX
    Quote Originally Posted by Giotown View Post
    Holy zombie thread, batman!
    This has been DIY'd a million times since this thread came about. Some more searching will turn up more threads with more pics and more steps.
    Oct 27 2012
    feeling real stupid
    Quote Originally Posted by Taloras View Post
    i just cant seem to find anything ... i keep turning up with older threads and keep getting stuck ... sorry guys
    Senior Member Three Rings Breppinq's Avatar
    Apr 05 2012
    VW ATLAS, VW JETTA GLI MK4
    Long island, NY
    Feb 13 2004
    S Ã C, CÃ*
    Wow the thread that started it all. Wow 4 years!
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    UPDATED:
    Can someone 'redraw' the schematic since the photo links are gone? What does "wires have to cross according to pin numbers" mean? Which pins go to which cylinder?
    They should be
    Cyl 1-3
    94
    110
    102
    Cyl 4-6
    95
    11
    103
    But not sure which pin to what cylinder?
    Also: brown ICM connectors for bank 2 (cyl 4-6, driver side, left side), black ICM connectors for bank 1 (cyl 1-3, passenger/right side)?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Feb 20 2010
    Brighton, MI
    The diagram shows:
    94 to cyl 3
    102 to cyl 1
    110 to cyl 2
    Is this correct?
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    Like this?
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    The 4 pins of the new FSI coil connector:
    pin 1 +12V from harness (old connector pin 15 (ro/gn = red/green)
    pin 2 and pin 4: ground from old harness (old connector pin 4a (br/ge = brown/yellow)
    pin 3 signal from ECU via old harness 4 pin connector (94=gr/ge, 110=gn/gr, 102=ws/gn) to old harness 3 pin connector pin 1 (br/bl, br/gn, br/ge).
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    UPDATED:
    Can some PULEASE confirm that (using Bank 1 as example) the the signal lines are correct as shown in the 'crossed over' schematic:
    94 pin goes to cyl 3
    102 pin goes to cyl 1
    110 pin goes to cyl 2
    I have wired bank 1 (bank 2 left alone for now) per schematic (+12V from harness (red/green) on pin 1, ground pin 2/4 (and to valve cover), pin 3 signal according to above.
    But it does NOT start! Double and triple checked.
    Plugs are sparking, not no start (just a random 'puff' once in a while).
    05 Golf TDI
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by vtraudt View Post
    That is correct, i need to fix the broken links when i have a chance, its been awhile.
    Feb 20 2010
    Brighton, MI
    Is it not running because so far I only did bank 1 (bank 2 still on brown ICM and old coils)?
    05 Golf TDI
