Page 1 of 7 123 ... LastLast
Results 1 to 40 of 251
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Lightbulb RP Turbo K04 Car Consolidation Thread
    Hey all. Since it seems as though everyone with RP's is in hiding (or haven't posted), this thread is to have all those owners post up their experience, be it good or bad. This is for the progression of the community and for others to learn.
    Some things that you should mention:
    -mile's since install
    -how you're running them (stage 2+, stage 3-, full blown stage 3)
    -boost level that you are using the turbos at (PSI)
    -any problems
    -quality of the turbos
    -feel free to mention other things about the turbos as well
    Thanks guys! Hopefully this thread will help those make the decision to purchase RP K04s in the future.
    (let me know if i need to add anything to the OP)
    Sep 16 2005
    Asheville, NC
    I've got approximately 50 miles on mine so far. If I didn't have a coolant leak to deal with, I'd have thousands. I'm running a full blown SSP stage 3 tune and have hit the peak of my boost gauge (25 psi). Quality of the turbos *seemed* just fine - hopefully that's it. I'll write a much better report once I get this coolant leak fixed and put some miles on which should be soon.. I plan on getting dyno'd ASAP and will do some logs.
    2000 S4 - SSP tuned Stage 3
    CrtchRktRcr: You could turn it into a unicorn with a gigantic pink dildo and i'd still love a b5s4.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Awesome drkenan, thanks for adding (rather being the first) to this thread!
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    i will start my car up in the next few weeks
    i will be a fully built 2.8 motor with rp k04s on it
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Active Member Three Rings
    Jan 15 2009
    2001.5 audi s4 stage 3
    pennsylvania
    my car is in the shop now rp ko4s apr stage 3 ill post next week when its out.i went today to check it out the motor was out and one turbo was on so its almost done.ill post video on youtube and ill link it to this thread.ill add that i have piggies apr srt exhaust rs4 mounts apr snub mount gaskets on motor are all done timing belt kit baily dvs and a few other things.by june ill have a bbk and suspension done and that all i want to do to it until something breaks.its my dd and thats about it.
    Veteran Member Four Rings VR6Bomber's Avatar
    May 13 2009
    XXXX
    Have some RP's on hand that will be going on a 2.8 build up on most likely VAST or ASP fueling.
    -Don't hold your breathe watching this build
    Established Member Two Rings luvgroovesalad's Avatar
    Sep 24 2009
    2000 Audi S4
    I have mine mocked up to the motor, but have to take the drivers side off to grind the housing to fit the coolant supply banjo bolt... The rest of the fit was spot on :-)
    I am doing the RP K04's, Vast Stage 3 Clutch, LWFW, piggies, SSAC cat back, FMIC (may wait till later to do, but have the parts already), Blitz boost gauge / turbo timer, silicone hose kit, 710n's, timing belt, water pump, thermostat, after run pump, alternator, starter, ceramic coated manifolds, rebuilt Transmission, B&M short shifter.
    Nov 27 2007
    2000 s4 black : 03 600rr Black
    NOVA, VA
    Quote Originally Posted by luvgroovesalad View Post
    What! All that and no mounts??
    mostly the same as above minus the sex change (rebuilt trany), and fmic.
    Add JHM shifter trio and 034 track mounts all around, coil overs, control arms, painted calipers, RMS and all seals, snub + cage, avic z110bt, weighted stock knob, piano black trim
    Sub ssac downpipes, ASP fueling
    I've had them on for 1.5k no issues but most of that was break in. Oh yeah, after break in I was only pushing like 11lbs of boost due to a massive leak caused by me cross threading the boost reference line. The turbo is back from the machine shop and installed. I am just waiting on my rear cam caps to come in tomorrow to put everything back in and see what stage 3 feels like, hell what a new car feels like.
    Stage 3 progress: here
    Picture Gallery: here
    You don't pay a ho to like you, You pay a ho to leave.
    Sep 24 2009
    2000 Audi S4
    Quote Originally Posted by stamps View Post
    The trans mounts were replaced just before the car was taken apart. The stock motor mounts looked just as fresh. My friend who is helping with the build has access to a lift and can bang out doing the mounts in no time, so I was planning on waiting till I kill the stock ones, unless I hit the lottery, then all bets are off and I'll go nutz with my baby
    Senior Member Two Rings Jayco88's Avatar
    Jun 02 2008
    2000 S4
    My car is at JHM's just waiting for a set to become available. For some reason RP's are out of stock everywhere... anybody has a set for sale?
    -It's got nothing to do with your vorsprung durch technic, you now.-
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Awesome! To those that are installing their turbos, good luck.
    Lets keep the contributions going!
    Veteran Member Three Rings spokismB5S4's Avatar
    Jun 06 2009
    01.5 S4 6mt, 03 RS6, 91 coupe quattro, 12 STI, 02 S6 01E, 97 328is w/6266, 87 325is, 86 325e
    i have had them on for 4000 miles. Full stage 3 ssp tune. Dont know about the boost because my boost gauge is broken ATM. Everything seems good so far, crossing my fingers.
    Anchor Audi Technician
    DM Technik Tuned BB 2001.5 S4 6mt ** ER's, Rostens, Frankenturbos, Tubi Mani's...
    Ben Swann Tuned Black 1990 200 Turbo avant 5mt ** Turbo-xs Bov, Cherrybomb, Catless...
    Sep 16 2005
    Asheville, NC
    FYI - you don't have to grind the housing on the driver's side. I had my wife come out and help me get that bolt lined up. It was frustrating and took forever, but I think that's better than grinding.
    Established Member Two Rings kylel2838's Avatar
    Nov 27 2009
    1987 Porsche 911 Carrera Cabriolet; 1960 MGA 1600; 1971 MG Midget; 1967 Jaguar XKE FHC + 2 more
    Powhatan, VA
    Just sold mine last week......
    2001 Audi S4 = SOLD
    1960 MGA 1600
    1971 MG Midget
    1967 Jaguar XKE FHC
    1958 Wolseley 6/90
    1967 Morris Minor
    Nov 27 2007
    NOVA, VA
    Quote Originally Posted by drkenan View Post
    kenan, your wife is a better man than I, haha. I screwed that thing 7 ways to sunday... no dice. So glad I did do the grinding since I had to remove it twice since.
    Get your coolant plugged up so you can give a review on these RPs
    Sep 16 2005
    Asheville, NC
    Well she DOES have the GI Joe Kung Fu grip.
    I can't wait to get this coolant leak taken care of. Maybe tomorrow...if only.
    Nov 08 2008
    ON. Canada
    I get mine tomorrow according to UPS online Tracking.
    I already have 710N's and GIAC XR chip on my A6
    I ordered:
    - RP k04's along with the 034 inlets,
    - 034 mounts (snub, motor, and trans) all street density all from Clay @ CTS Turbo.
    - timing belt with all accessories (water pump, aux pump, thermostat, etc...).
    - Also Sam from 517 Trans had shipped my TC today so hopefully I'll have all parts this week and start the install.
    Will be removing the stock down pipes and throwing in custom 3" dp's as well
    I can't wait to get this thing on the road, been waiting on the turbos for a month now because they were out of stock
    My car is an 01 A6 2.7T tip btw...
    I'll keep you guys informed about how they hold up so others could finally benefit from this.
    Veteran Member Four Rings S4UCE's Avatar
    Aug 21 2007
    Fairfield County, CT
    Quote Originally Posted by kylel2838 View Post
    Okay, I'll bite - why?
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Update your posts after your installs
    Feb 24 2010
    And have never been happier
    Getting ready to order mine. Thank you for making this thread. This will definitely help future lads like me.
    Nov 27 2009
    Powhatan, VA
    Quote Originally Posted by scar79 View Post
    Decided not to go stage 3..The car is fast enough and $4000.00 is a lot of jack to drop for power that will never get used.
    2001 Audi S4 = SOLD
    1960 MGA 1600
    1971 MG Midget
    1967 Jaguar XKE FHC
    1958 Wolseley 6/90
    1967 Morris Minor
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    WHAT!?!? you have to be kidding me...
    Quote Originally Posted by washyourrhands View Post
    wow.. fully built with k04's?? you going for a lot of low end thunder?? how much more power can you get on a k04 setup than with these guys with out a built engine with k04's?? i havent seen many built blocks with k04's.. so just trying to see what your goals are. good luck..
    RS6 hybrids and corn
    Aug 21 2007
    I didn't realize you could choose when to go stage 3.. I thought the car decided for you
    Nov 08 2008
    ON. Canada
    Nov 27 2009
    Powhatan, VA
    Quote Originally Posted by bigern45 View Post
    Yeah, never going to track the car, and seeing how fast you can get to 60mph gets old after a while. Like I said, the car is fast enough for me as it is.
    2001 Audi S4 = SOLD
    1960 MGA 1600
    1971 MG Midget
    1967 Jaguar XKE FHC
    1958 Wolseley 6/90
    1967 Morris Minor
    May 13 2009
    XXXX
    I'm doing the same, do you have a build thread so I can copy you?
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    Quote Originally Posted by VR6Bomber View Post
    well i was originally doing a 3.0 GT car, then things took a turn for the worse. I got a deal on this brand new 2.8 built block. it had been 6 months since i had driven my car and the show season is coming up FAST. So i got the idea of using the 2.8 block with 2.8 heads and k04s for now. GREAT for the track for all the low end and should still be faster than your average k04 car.
    Yeah i do have a build thread although ill be the first to tell you its not the greatest of them. Soon ill be updating it when i pick up the motor from 034.
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Oct 13 2009
    Other Broken Vehicles
    Farmington Hills, Michigan
    i have 800 miles on mine. stock fueling at the moment not really getting above atmospheric. until i get fueling and a tune : (
    (\_/)
    (o o)
    00 Laser Red "stage III" S4: Sold
    04 Moro Blue S4 6MT: Sold
    01 Allroad 6MT: Sold
    06 A4 Avant 6MT
    09 C63 P30
    Mar 18 2009
    brooklyn, ny
    was wondering exact same thing... why build engine, especially 2.8L for K04? people are too cheap spend $800 for proper BW K04's but spending at least $2K+ more to buid engine????????? how does that make sense?
    Sep 28 2009
    ky
    ....50-100 NEVER gets old.... ive seriously never talked to other stage 3 owners about 0-60.. its always been from 50-110 or something.. but thats cool, stage 2 is fast, definitely fun for a street car, but stage 3 power is retarded.. it doesnt get old..
    Sep 28 2009
    ky
    oh.. well thats cool. do you have a different compression ratio? they arent as strong as the turbo blocks are they? i guess with being built and all, you wont have to run the same boost to achieve the same power as a k04 stage 3 2.7, seeing as how youll have more compression.. i think i may have read about your build somewhere else.. you may get some serious power, depending on how far you can push that block.. oh well.. interesting build, i hope it goes well..
    Nov 27 2009
    Powhatan, VA
    Yeah, well 80MPH plus means go to jail in VA so that wouldn't even begin to be in my vocabulary unfortunately. As much fun as it is, VA State Troopers are dicks and love to give out reckless tickets!
    2001 Audi S4 = SOLD
    1960 MGA 1600
    1971 MG Midget
    1967 Jaguar XKE FHC
    1958 Wolseley 6/90
    1967 Morris Minor
    May 13 2009
    XXXX
    Quote Originally Posted by alexverve View Post
    Do you own a pair of either brand K04?
    It costs more than 2k to rebuild and go to 2.8 btw.
    Thanks for your post.
    This thread is called 'RP Turbo K04 Car Consolidation Thread'
    Jun 14 2007
    2000 S4
    Connecticut
    Washyourhands only went with the RPs because of money issues I believe..
    He had plans of putting GT's on, but something happened financially to cause him to sell the kit.. He's not THAT crazy!
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Jezzzz...start a new thread..all this and have only ~3 people reporting in and the rest is nothing.
    But yeah, talk about the owners being in hiding, I've had B5 A4 RP turbo Roll Call Threads here and Vortex for a week plus and nothing.
    Active Member Two Rings Adam_S4's Avatar
    Mar 17 2009
    England
    Got mine the other day.... Hoping to have them fitted this weekend. Will be running standard fueling for now untill i can get some new injectors and fuel pump and then another remap:
    Noggy S4 B5 Avant | 19" RS6 C6 Reps | H&R Springs | Full RS4 Exhaust System (Gutted DP's, Custom Tips) | BMC Panel Filter | 710n's | After-run Mod | RS4 Intercoolers | 034 K04 Inlets | RP K04's | MRC Remap
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Guys, I don't mind the car discussion but can we please keep this thread on track? Thanks!
    I'm trying to encourage the RP owners to come outta the wood work, I have a feeling a bunch are still shy
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    this also....
    next winter ill have an agtronic kit
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Dec 28 2009
    '69 Dart GTS, Ducati S4Rs, KTM SMR 450, '76 CB400F, KTM 200EXC
    FL
    I picked up kylel2838's to replace a whinning k03 during some other repairs. No promise on the install time as I'm trying to pick up some fueling parts from the classifieds but not doing so hot on the replies from some of those posting parts for sale. I'm also in the middle of sourcing parts for the front end after a minivan blow out in front of me took out the front bumper cover, fan, condensor, radiator, etc. I'll post up as it goes.
    And thanks to kylel2838 for a straightforward, honest and quick transaction!
    Nov 08 2008
    ON. Canada
    Got the turbos and inlets today from CTS
    This is my build thread on the A6 section for those of you interested in more pictures and info,
    http://www.audizine.com/forum/showth...or-my-A6/page2
    But as i rack more miles on the RP's after installation I will add to this thread and hope that members could benefit from my experience
