This is a relatively easy DIY, but a little habit of electronics is of course a plus. I have very little pictures and my wiring diagram is not top notch either, but I hope I can help someone.
You will need:
* 1x 5pin 12v relay
* 2x 4pin 12v relay
* 1 pack of Ring connectors
* 2 packs(about 15pcs) of Female connectors, isolated
* 1 pack of Quick splicers
* 1 roll(about 5-6ft) of Electrical wire
* 1x Fusible link wire
* Some Heat shrink tubes
* 1x Rocker switch
* Solder iron
Then the tricky part to wire the harness, i made a wiring diagram, not a first class one but you get the idea:
Be sure to cut about 2ft slack on each of the signals, plus, ground and the feeds for the foglights. With that done, its time to install it. Remove the battery MINUS pole FIRST, then the PLUS pole. Remove the plastic trim under the dash and the piece to the left in the pedals area, locate a ORANGE/WHITE thick wire in a orange connector:
Splice in the SIGNAL 2 on that wire.
Pull out the lightswitch(push in, turn right) and locate a BLACK/YELLOW wire:
Splice in the SIGNAL 1 on that wire. Under the dash theres a constant battery plus hub, with a ring connector on the plus feed wire from the harness, mount it there. The harness ground wire can be mounted under this bolt:
You should have 2 wires left on your harness, those will be spliced on the WHITE/GREEN and WHITE/BLUE THICKER wires in this area:
Those are a PITA to splice in on btw. If its all done properly, insert a 15A fuse in your harness and make sure your switch is on. Bolt on your battery plus and try out your new Cominghome feature
I drilled a hole in the little trimpiece to the right on the lightswitch and placed my switch there.
