Results 1 to 9 of 9
    Active Member Two Rings Tunerstop's Avatar
    Jan 22 2008
    Socal, CA
    Help Asap! Quattro Springs on fwd?
    Hey, im about to buy neuspeed race springs locally and just noticed that the springs are for a b6 quattro..I understand that b6 springs fit on b7 but will quattro springs fit on fwd?
    08 A4 S-Line 2.0T - TSP BOV, H&R Springs, 20% Tint, 6000k HIDS, 3000k Fogs, 19" BBS LM's
    Senior Member Three Rings tivs31's Avatar
    Feb 07 2008
    Lemont IL
    Re: Help Asap! Quattro Springs on fwd?
    yes it will, the spring rates will probably be a bit stronger though, meaning a stiffer ride
    Jan 22 2008
    Socal, CA
    Does that mean im gonn ahve a bouncy ride? Will it go as low?
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Quattro springs will fit on a FWD, but you may have a little forward rake. Quattro springs are slightly more firm to accomodate the extra weight of the quattro. Putting stiffer springs on a lighter car means it won't lower as much since you don't have the weight in the back.
    Veteran Member Four Rings GA42.0T's Avatar
    Jul 26 2010
    Atlanta, GA
    Sorry to bring this back from the dead, but I did what any good AZ'er would do when wondering about something for my car. I searched for this topic, this thread came up, and now I've got real world experience to share.
    I just put 2008 B7 quattro Sline springs on my 2008 FWD, and it looks good to me.
    Rear checked in at 27" fender to ground on stock springs. With quattro, s-line springs, I'm sitting at 26.25 rear. Not bad for a conservitive drop.
    The fronts didn't drop too much. Went from 27" to 26.5". I'll rectify that with B5 lowering caps.
    The ride is great too paired with s-line, quattro shocks.
    Here are the pics!
    Note on wheels: 18X8, ET45. 10 mm spacers front, 12.5mm rear.
    2008 B7 quattro, s-line springs. Green, white, white front. Red, red, white rear.
    Jamie | 2008 2.0T FWD 6MT Brilliant Black S-like
    S-line Suspension+B5 Spring Perchs | RAI HFC | ER SMIC | 034 TIP | B8 18X8 Sport Wheels | Spacers: 10/12.5mm | RS4 Sway | "D" DV | De-badge | S4 Blackout Grill | Euro RNS-E | OEM Ecode Xenons | Clear Side Markers | Cupra Lip | S4 Mirror Caps | ECS Slotted/Drilled Front Rotors | Ceramic Pads | Poser S-line Door Badges | Podi | 034 Catch Can. Go: Still Stage Zero
    Oct 14 2009
    Okinawa Japan
    Not bad, needs moar low! I'm in GA too, just moved here, Robins AFB
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Jul 26 2010
    Atlanta, GA
    Update for the other poor FWD souls out there.
    Installed B5 spring perchs today. This is it for me. Perfect DD drop. FYI, this is 2008 B7 A4 AWD s-line supsension + B5 lowering caps on a 2008 B7 A4 FWD. Measures 26.25" FTG front and 26.25" FTG driver rear. Passanger rear is 26"
    My post and pics above saw fronts were 26.5", but I measured before this install and they were at 26.75". Not sure how they raised, but I can see noticable difference with these B5 caps on.
    Jun 30 2009
    Washington DC
    Looks good. That is exactly what it should look like from factory for sports suspensions.
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 14 2011
    12 Taco, 13 Ex, 16 Civic EX, 15 JKUR
    Looks great. I like the clear markers and clear corners as well....very clean look. Gonna get me some b5 caps.
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
