Results 1 to 11 of 11
    Apr 11 2012
    Cool What size tire on 19x9.5 Rim?
    I am currently running a 245/35/19 and I find them too thin and too stretched. What would be a good size tire to run that won't need a stretch and has a decent sidewall to defeat the terrible potholes in Montreal Lol .
    I was recommended 265/35/19? or should i go with a 40 profile? or is that too large for that size?
    The wheels are Avant garde m310 19x9.5" and im on adjustable coil overs so i dont think rubbing will be an issue.
    Let me know :)
    You won't want to change the profile size, unless you want to change the speedometer as well. The profile on a 265/35 will be slightly larger than the profile on the 245/35 but not enough to throw anything out of whack. I think a 245/35 is perfect for 9.5" wheel but that's just personal preference, nothing wrong with running a 265/35
    2008 B7 2.0T Quattro 6MT
    Sold:
    2013 VW CC R-Line
    2005 B6 1.8T Quattro 6MT
    RIP:
    2002 B6 1.8T - April 2019
    2004 B6 3.0 - August 2018
    Jul 17 2011
    Sin City, USA
    Remember, the "35" is the aspect ratio and is a percentage of the first number. So a 265/35 will have a thicker sidewall than a 245/35 (35% of 265mm is > 35% of 245mm; 66.25mm to 61.25mm respectively). I would not worry too much about speedo because you should be able to VAGCOM the tire size into the ECU to allow for proper speedo reading. Rubbing on wider tire would be my first concern. The 265 will be 20 mm wider than the 245. All things being equal, you will gain 10 mm inside and 10 mm outside. before buying, check clearance on both to ensure your not going to interfere.
    '09 C6.5 A6
    Apr 11 2012
    Thanks, what about a 40 profile? or is that too big?
    Jul 17 2011
    Sin City, USA
    I have a 255/35 tire on my A6 which is a big car and I feel that the sidewall is plenty big. I think a 40 side wall on a 265 my be overkill but that is just my opinion.
    '09 C6.5 A6
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by stuntdevil View Post
    Let me know :)
    265's will rub like crazy, use this site to play around, watch your speedometer variance, http://www.willtheyfit.com/, i would use the stock 255/35/19 personally.
    Stage 1 more than you RS3
    Apr 11 2012
    Quote Originally Posted by o1turbo30v View Post
    I want to get rid of the stretched look - i am personally not a fan. I am running a 9.5" wheel and there seems to be plenty of space?
    Im running 245/35/19 and its a huge stretch. Why would 20mm more cause rubbing?
    Feb 24 2013
    CA
    Im running 245/40/19. A bit more side wall bc 35 you could feel everything
    Jul 17 2011
    Sin City, USA
    A lot of it will depend on the offset of the wheel you are running. You may have room on the outside (from tire to fender), but you may not have the additional space on the inside (tire to suspension).
    Did you buy the car with the current setup? One of the main reasons for stretch is to have a wider wheel then the car would allow for with an unstretched tire.
    '09 C6.5 A6
    Apr 11 2012
    Quote Originally Posted by Ulisses03hd View Post
    I know its super rough on montreal roads - What size if your rim?
    Apr 11 2012
    Offset is 40 i believe?
