Originally Posted by
TofuShop
ah, that's too bad on the custom tune. at least your car is running great without any issues now
my car has been good as well, luckily no issues. i've managed to get 31+ mpg consistently on several tanks of gas now. i'm very impressed
Thanks. I also see consistent 30+ MPG average. It was a little less with the vacuum leak but now I am back up to speed and fuel efficiency. Also, I have been calling my tuner at least twice a day to try and schedule a couple dyno runs so I can finally post my final results of what is going on in there.
I also sent NGK an e-mail about options for plugs. I haven't heard anything back yet. I was wanting to go with the Iridium IX -1 heat range. I can't find a part number on their site that will work with our B8s. After doing some searching on the forum, it seems most people play it safe by going with OEM. Running the K04 and that amount of boost, I would rather look into something a bit above OEM. I want to swap plugs in between dyno runs to see if there is any gains that could be attained by switching out plugs. I will let you know what I find.
On a side note, I talked with APR. It seems the turbo flutter is normal. If I was to add back in the stock air box and possibly the air tank in the turbo plumbing, it would muffle it or possibly drop it all together. I am going to drop the carbonio but not the intercooler piping so it will be something I have to live with.
Also, not sure if anyone else noticed it but I have a high pitch winding noise starting at about 15 psi coming from the intake. it reminds me of a supercharger spooling. This is also caused by the intake. Not very bothersome, but it is noticeable in cab even with the windows up (no music playing though).
