Results 1 to 40 of 209
    Aug 18 2009
    A Unicorn
    Portland, OR
    CEL came on. Scanned it and found code P0441. Did some research and decided to replace the N80, which resolved the issue.
    Established Member Three Rings mo17k3y85's Avatar
    Oct 23 2010
    B7 A4, lexus RX330, F150 Roush
    carbondale il
    ^^ your sir, have some serious knowledge!!
    06 Quartz Grey B7 - Lowered, 19" RS4 Reps, S-Line front bumper, Color matched Cupra Lip, Smoked reflectors, Spyder R8 led headlights, Hoen yellow fog lights, Led interior, Magnaflow exhaust, In.pro mirror caps, Tinted
    Veteran Member Four Rings Sprode's Avatar
    Aug 27 2009
    07 S-Line, 97 Supra Turbo
    Arlington, VA
    Quote Originally Posted by mo17k3y85 View Post
    No offense meant to Tankdeer, but anyone with access to an autozone, 20 dollars, and google could have done this.
    http://tinyurl.com/24eclcu
    It even redirects to a 5 year old thread, here, that says the same thing.
    Aug 18 2009
    A Unicorn
    Portland, OR
    Quote Originally Posted by Sprode View Post
    Why am I getting called out on this? I didn't start the thread, nor am I confused on the fix. I fixed mine a couple months ago by basically the same procedure you recommend. Scanned it (myself), researched, replaced. I am just trying to help others with the same issue since it's such an easy fix
    Aug 27 2009
    Arlington, VA
    I did not mean to insult you, and it IS good info. Thanks for posting it up. You did what many are incapable of doing.
    Aug 18 2009
    A Unicorn
    Portland, OR
    No worries as I wasn't insulted, just confused.
    I bought a scanner a while back because the autozone at my old house stopped doing free scans. Turned out to be one of the best auto tool investments I've made in a while, and it was only like $60 IIRC. Makes researching a CEL so much easier.
    Veteran Member Four Rings JPT's Avatar
    Oct 11 2010
    '05 Kawasaki Ninja ZX12R
    Long Island/NY
    Also is great of clearing codes... Autozone as a company decided to stop clearing codes, so those cheap scanners work perfectly.
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    Yes, but nobody else did it here yet. So I think it's good info
    Veteran Member Three Rings Trile's Avatar
    Jan 26 2010
    Podgorica - Montenegro
    @tankdeer - same here.
    love the forums ! :D
