Page 1 of 4 123 ... LastLast
Results 1 to 40 of 137
    Senior Member Two Rings kingDL's Avatar
    Mar 17 2011
    Sweden
    OEM brake upgrade for 3.0T?
    Hello,
    I just bought a 2009 A6 3.0T Avant.
    I am going to tune this car soon, but I am feeling that the OEM front brakes doesn't really cut it and I don't think a swap of pads will be enough. Recently did the Q5 Brembo swap on my A4 B7 and it has amazing brakes now, so I'm looking for something similar. The problem seems to be that there isn't a lot of people doing brake upgrades to their A6's(at least compared to the A4 community), so I can't find any writeups about it. Maybe I am not searching good enough. I have found out some stuff, but I need assistance to find out what fits or not. Can anyone help?
    1. I read that A8 brakes should work on the A6 4F/C6 straight bolt on. Is this true or will it affect ET? There is an A8 setup that has 360mm discs and 2-pot floating calipers. This is a very cheap upgrade, the calipers can be bought for about $100 each new.
    2. Some combination of RS4/RS6 calipoers/discs seem also to be bolt on? But Im unsure what part numbers. Does anyone know? A german ebay seller has been offering a kit like this for the A6 for a long time:
    http://www.ebay.de/itm/Audi-RS6-Brem...tf-rzkk7kpwsIA
    I know that there is StopTech and Brembo GT kits for this car, but they are like $4000. If I source OEM parts on the junkyard, I can find a pair of RS6 calipers for $5-600.
    any input on bigger front brakes for this car is appreciated. I would prefferebly not want to use discs larger than 365.
    2009 A6 Avant 3.0T
    Established Member Two Rings ApexRex's Avatar
    Nov 18 2013
    07 4.2 A6
    Chesterfield, VA
    There is a Porsche brake upgrade that the pre facelift cars were doing, don't know if it works on the C6.5, 2009-2011. I think they were off of the Cayenne. 17Z or something like that? It's been a while since I looked.
    Established Member Two Rings Greenster's Avatar
    May 02 2017
    '87 Porsche 951
    San Francisco, CA, USA
    No one at the dealer knows? I'm sure a tuner would know.
    Sent from my F3213 using Audizine mobile app
    Veteran Member Four Rings 2010A6's Avatar
    Mar 10 2015
    2017 Jeep Cherokee; 2018 S3 Nano Gray
    Albany, NY
    Quote Originally Posted by ApexRex View Post
    I heard that route does require a custom bracket to be made though
    Current: 2018 Audi S3 2.0T Nano Gray / Magma Red
    Past: 2010 Audi A6 3.0T Midmight Blue / Pistachio Beige
    Active Member Three Rings NASAudi's Avatar
    Nov 28 2016
    Chandler/Arizona/USA
    An S6 OE brake swap is where its at. 385mm brakes. I did it to my 3.0t.
    NASAudi
    Mar 17 2011
    Sweden
    Quote Originally Posted by NASAudi View Post
    NASAudi
    Too big--- that requires at least 20" rims, no? I need to use winter tires on this car and they are insanely expensive in anything larger than 18".
    2009 A6 Avant 3.0T
    Nov 28 2016
    19's
    NASAudi
    Senior Member Two Rings Jeremyboukaia's Avatar
    Aug 20 2016
    Elpaso
    These are 17z off a Touareg they are 330 mm Volvo rotors. These bolt on but need the caliper lugs shaved alittle
    Jul 17 2011
    Sin City, USA
    Why do you feel there’s a need for replacing your brakes? The 3.0 come standard with 347 mm front desk and 330 mm in the rear. What type of driving are you planning on doing that would require changing your brakes?
    Unless you’re taking your car to the track on a regular basis or participating in an autocross, changing out your brakes for something different it is overkill in my opinion! That is unless you want to have bigger brakes for looks! Upgrading your current set up with a different rotors from ECS or Adam’s rotors and adding Akebono euro ceramic pads and stainless steel brake lines will resolve all of your concerns regarding the brakes being underpowered for the car.
    '09 C6.5 A6
    Mar 17 2011
    Sweden
    Let's take that mindset and reverse it somewhat: Why does the RS6 have 8-pot brembo calipers in front? It hardly weights any more than my 3.0T. I'm quite sure that the 347mm 1-pot brakes would stop the RS6 too, maybe with even smaller discs, say 321mm.
    I have an aggresive driving style and I want brakes that I can depend on even when the speed is twice the legal limit! I know a caliper with more pots will give me what I am looking for, and if I can do an OEM upgrade it will be cheap too.
    2009 A6 Avant 3.0T
    Senior Member Two Rings juniorcruzer's Avatar
    Sep 28 2014
    2007 Suburban
    Center City Minnesota
    put a decent pad on this car, and you would be surprised at how well it stops. I have an aggressive driving style myself, and not once have I ever thought about upgrading to a big brake kit when street driving. Now if you are talking track, that is a whole different story.
    Jon
    2010 S4 3.0T, chipwerks stage I
    2010 A6 3.0T, APR Stage 2+, Roc Euro Intake, VMR V710 18x9.5 HyperSilver, 30% tint, A3 clear marker lights, LED Reverse lights, RS6 Grill
    Mar 17 2011
    Sweden
    Quote Originally Posted by juniorcruzer View Post
    Jon
    Yeah but say you could spend another extra $400 to make the brakes even more effective. Would you do it?
    EDIT: From what I understand it could be possible to use A8 brakes in front. The discs needs to be replaced also soon. So the extra cost over the 347mm oem setup would be the larger 360 discs, but they can be found at about the same price. The pads are also the same price. A set of brand new 2-pot A8 calipers is about $220. The OEM brake lines will propably work but I would change these into a setup of steelbraded ones, so maybe another $100.
    So $320 extra to make the brakes more effective than just a pad swap. Even if they don't get much better, $320 is not alot of money.
    2009 A6 Avant 3.0T
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Quote Originally Posted by kingDL View Post
    Probably becasue that car is a lot faster.......
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Sep 28 2014
    2007 Suburban
    I would buy a slotted set of stock size rotors, and a good set of brake pads. Maybe also do stainless brake lines, little better peddle feel on the street and track. If you plan to track it, then upgraded brake fluid as well.
    Jon
    Dec 01 2007
    Orange County, NY 10918
    S6 Calipers with spindles
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Mar 17 2011
    Sweden
    Hello,
    after much searching around I have now found out 2 things:
    1. There is an OEM Audi brake option which is called 1LL, which is only fitted to armoured A6's but is standard on many Audi A8 and VW Phaeton. This is bolt on 360x34mm discs with 2-pot calipers.
    2. When I searched around I realized that both the calipers and the carries on the A6 are the same as on the S4 B6/B7. The only thing that differs is the discs which are 347x30mm instead of the S4's 345x30mm. That leads me to think that the Q5 calipers can be used on the A6 C6/4F also. I recently just did that mod on my A4 B7 so maybe I could just swap the calipers and pads from it.
    EDIT: If you are not familiar with the Q5 brake mod; it's 4-pot fixed brembo calipers made in alu.
    we will see what happens.
    2009 A6 Avant 3.0T
    Active Member Two Rings Flad.Solo.View's Avatar
    Mar 07 2012
    Ukraine, Kiev
    few bolt-on options from my top list:
    1) Audi Q5 Brembo 4-pot calipers
    347mm OEM Audi A6 C6 rotors
    2) Brembo BM5/17Z
    Mercedes A 230 421 08 12 (Ate 24.0132-0153.1) 330x32 rotors
    3) Brembo 18Z
    rotors:
    Mercedes A 221 421 16 12 07
    Mercedes A 221 421 11 12
    you only need to enlarge the center bore of Mercedes rotors from 67 to 68mm
    if you need some help with part numbers etc.. PM me;)
    Mar 17 2011
    Sweden
    Quote Originally Posted by Flad.Solo.View View Post
    I'm gonna go with this option since I have the calipers already, I checked the brake lines and compared with the A4 B7 ones. The difference is only 5mm so maybe the custom steel braided lines I had made for the A4 will fit the A6 too.
    Pairing this with Redstuff pads and Zimmerman sport rotors(drilled) all around. I will get back with pictures and result.
    BTW: is it necessary to put the electric parking brake in service mode?
    2009 A6 Avant 3.0T
    Mar 07 2012
    Ukraine, Kiev
    you don't need to do anything with parcing brake since you gonna upgrade front ones;)
    Audi A6 C5 '03 1.8T AWT FWD
    Audi A6 C6 '07 2.4 BDW FWD
    Audi A6 C7 '16 2.0TFSI FWD
    Mar 17 2011
    Sweden
    Haha yes but I am going to replace the rear discs and pads too.
    2009 A6 Avant 3.0T
    Mar 07 2012
    Ukraine, Kiev
    oh, then yes)
    its easy to do!
    i made it few month ago https://www.drive2.ru/l/474148997389353104/ (use google/chrome translate if you are interested to read;))
    Feb 14 2015
    Benidorm Spain
    19' rims you need minimum but you can go whit some 18'.
    All rims r18 from a6 c7 it goes whit this setup of s6.
    I have this brakes on my 3.0tdi and someone who I know whot same setup of s6 brakes it runns on 18th inches rims from a6 c7 4g.
    Mar 17 2011
    Sweden
    Should have posted this earlier but I have fixed the brakes on my car.
    This was bolt on with no issues at all, I had steel brake lines custom made for these calipers to my previous car, and A4 B7. They fit nicely on the A6 C6 also. Could be that the OEM A6 C6 brake lines will work also, but I'm not sure.
    I am using Zimmerman Sport rotors, I know the drilling they come with is mostly a gimmick but they are supposed to have better quality steel in them compared to the standard version. Pads are Redstuff.
    The brakes are better than before and has a nice pedal feeling. But it should be noted that I had OEM pads before, so not sure how much the pads alone affect the performance. Considerable weight saving also!
    Definatley an upgrade worth doing, the extra cost is just the calipers, which I paid $300 for.
    A picture: https://imgur.com/a/RnLRQXy
    2009 A6 Avant 3.0T
    Established Member Two Rings corrado-correr's Avatar
    May 28 2015
    Royal Oak, MI
    Hey kingDL can you say exactly what you ended up using to fit the Q5 calipers?
    Is it just the calipers and brake lines form this kit: https://www.ecstuning.com/b-ecs-part...14366ecs03kt2/
    Raven
    Mar 17 2011
    Sweden
    Quote Originally Posted by corrado-correr View Post
    Hello,
    Nothing but the calipers themselves, it's a direct fit. Maybe the brake lines, but thats a big maybe, the OEM lines might work.
    This is assuming that you have the 347x30 OEM brake setup, cars with other setups might have different hubs(?).
    2009 A6 Avant 3.0T
    Veteran Member Three Rings Kem's Avatar
    Aug 30 2004
    Colfax, CA
    What size rotors does the ROW TDI SQ5 use? Here in the USA they are 380x36. How does that work with a 347x30 oem rotor?
    Hello,
    2005 6MT ur-Allroad
    Veteran Member Three Rings B. Rock's Avatar
    Jul 27 2008
    09 3.0T A6 Avant
    Isn't 347x30 the standard size for the C6's? If nothing else, those calipers look fantastic on the front of the car.
    09 A6 Avant 3.0t
    06 E350 4x4 Cummins swapped
    01 WJ rock toy
    Mar 17 2011
    Sweden
    Quote Originally Posted by Kem View Post
    The Q5 brake mod does not refer to the SQ5 but the Q5 3.0 TFSI - the SQ5 has another brake setup, I think it has floating calipers with dual pistons. The Q5 3.0T has 345x30 rotors.
    These calipers can be found on other audi models also - the ones I bought came of an A6 3.0 TDI -16.
    Quote Originally Posted by B. Rock View Post
    There is several different front brake setup's for the C6, depends on what engine/trim level the car has.
    I choosed to paint the calipers black - but if you like more attention they would propably look great in another color. It has a large space for text or something also.
    2009 A6 Avant 3.0T
    Established Member Two Rings NJAUDI1's Avatar
    Sep 24 2006
    07 S4 A/T, 07 RS4 6MT, 11 S4 6MT
    Will the Q5 calipers work with the prestige 18inch wheel?
    Sep 24 2006
    Hello,
    If you have 3.0t you will need to replace brake lines with q5 ones. Other then that it is a direct bolt on.
    Senior Member Two Rings alexdell's Avatar
    Jul 29 2011
    Central NJ
    So I have the Macan calipers that I never ended up using on my old B8.5 S4. I'm thinking of installing it on my C6.5 3.0T avant (MY2009). I know the Macan is the same exact calipers as the Q5 (345x30mm 4-pot). Since the OEM calipers are 347x30mm (single pot), do I need to change the rotors as well? Also, based on what I read above, I need to replace the brake lines to the Q5 ones as well and everything else is a direct swap? Thanks for your help.
    Alex
    IG: @puzoyAlex
    C6.5 A6 Avant Ibis White | KW V3's| H&R F+R Sways| XLR8 Dual Pulleys| EPL Stage 2 tune| S4Matty Ported SC+TB| APR CPS| JHM Downpipes| SkiGuard Roofbox|
    gone ---> B8.5 S4 Sepang Blue (6MT) |APR Stage 2+ UC|
    Sep 24 2006
    Quote Originally Posted by alexdell View Post
    Alex
    If the same as The q5 brembo 4 pots then only have to change the brake lines. The 347mm c6 rotors work fine. You can upgrade them if you want, but size wise they work fine with the q5 calipers.
    Senior Member Two Rings DOBERMAN@UA's Avatar
    Sep 15 2008
    A6 c6 3.0 Tdi (300hp)
    Ukraine, Kiev
    Hi,
    I have a6c6 with 347mm front rotors, upgraded with q5 calipers, works perfectly. Now I do want to save some kilos on brake rotors, but two peace rotors are only 345mm, will it fit my set up?
    A6c6 3.0 tdi(300hp), koni sport shocks, eibach pro kit springs, q5 4pot brake calliper, a8d3 sport seats
    Senior Member Three Rings dluxxx's Avatar
    Mar 13 2013
    2016 Porsche Cayenne Diesel
    Nor*Cal
    Quote Originally Posted by DOBERMAN@UA View Post
    Hi,
    what year q5 calipers did you guys use??
    so just to get things straight... its a direct bolt on (no modifications) except for brake lines
    2010 A6 C6.5 3.0T, Remus Mufflers w/ Quad tips, Magnaflow Resonated X-Pipe, RocEuro Intake, EPL Stage 1, Transparent Gloss Copper Verde Axis V99 20x9, Michelin Pilot Sport 4S 265/30, Bilstein P14 PSS Coilover, H&R Rear Sway Bar, Ultra Racing Front Lower Brace, Ultra Racing Center Lower Brace, RS6 Black Gloss Grill, Rear diffuser, Black Vinyl window trim, Smoked Rear Tailights, Complete Interior LED Lights, Blacked out front sidemarkers, Morimoto 5000k D3S bulbs, SB3 Alpha Ceramic Coating.
    Sep 15 2008
    Ukraine, Kiev
    8R0615108G and 8R0615107G. You need only brake lines. Easy to do, night and day difference
    Mar 17 2011
    Sweden
    Quote Originally Posted by NJAUDI1 View Post
    Sorry for late answer but I think they even would work with 17". I can confirm or deny this when I'm putting on my winter wheels, if we ever get any snow this winter. ^^
    Are you sure about needing other brake lines? I havent measured but the A6 OEM one seemed to be about the same length as the steel ones I am using now.
    Also,, is 2 -piece rotors really worth that crazy extra cost? :P
    2009 A6 Avant 3.0T
    Sep 15 2008
    Ukraine, Kiev
    For sure you will need new brake lines because q5 calipers have different connections. And yes q5 calipers will fit some 17 inch rims. I even saw 6 pot brembo calipers with 350mm brake disks fits 17 inch rims, but it depends on geometry of rims. For this size of brakes I would recommend at list 18 inch rims, during hot weather and hard braking you will need space for cooling down brake. In 17 inch rims there is no space at all. Even in winter calipers will clean rims and all dust would be on pads, it will cause excessive wear on pads
    Two piece rotors abut 2,5 kg lighter then stock 347mm rotor it increases handling dramatically. The same effect as forged rims
    Jul 29 2011
    Central NJ
    So my indy shop tried installing the Macan/Q5 Brembo calipers w/ a new set of ECS rotors (345x30) which were the ones for the B8 S4/Q5. Although the 345mm diameter works, the depth/height of the rotor hat seems to be 1/2” shorter than the stock 347mm rotor for the C6.5 A6. Basically the rotor was rubbing against the front of the inside caliper due to the narrower height of the rotor hat. I just ordered a set of the 347mm OEM size to see if it will work. I’m assuming the 2mm width difference should not be an issue clearing the 345mm calipers. Here’s a pic of the difference of the hat height as a reference.
    IG: @puzoyAlex
    Sep 15 2008
    Ukraine, Kiev
    345 30 rotors doesn't fit q5 calliper on c6?
    Jul 29 2011
    Central NJ
    It’s not the caliper fitment but the height of the rotor hat. So a stock C6 A6 rotor w/ the Q5/Macan caliper should work. As you can see from my pic above, the height of the c6 rotors are taller than the S4/Q5 rotors. It’s probably hard to tell as both rotors were flipped upside down to show the height difference. Here’s an animated gif since I can’t upload the video.
    IG: @puzoyAlex
