Your oil pan gasket on the front is shot.
No other way to explain oil drops on the bolt heads on the front AND sides at the same time. If the seal leaks you get oil droplets coming through the thread of these bolts. I had the same issue on my RS4.
I had a complete guide up in the rs4 section but dropbox botched the picture hotlinks... dammit.
Here's a few more pics:
You can see the "oil stain" to the left of the oil pan.
You'll need some force too loosen the old gasket but be careful not to scratch the block too much.
Use a 2x4 to have a flat surface when preparing the seal-area and removing the old gasket material.
End result. Popped in a new oil-pan as my old one was rusted.
