Results 1 to 27 of 27
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    CTS K04 oil and coolant line issues.
    Did anyone using a CTS K04 have issues with the oil and coolant lines from the B8 not fit onto the turbo?
    This is in regards to a CTS K04 I bought last year when they were still welding an extension onto the turbo.
    Thanks in advance
    Veteran Member Four Rings bb-tt's Avatar
    Apr 30 2018
    2017 TTS, 2011 Avant, 82 c3 vette, 2002 TT (sold), 2010 CC (sold), 2013 Jetta, 2018 Q7, 2019 Tiguan
    DFW, TX
    Just the coolant line think Iceman (maybe someone else) had same issue had to swap to the top coolant port and put plug in lower port. Then had to stack two copper washers under the coolant banjo bolt/flange or whatever you call that connector the banjo bolt goes through so the line would clear the plug otherwise it leaked like a seive.
    Did you modify the lines as shown in the installation instructions?
    Jul 25 2016
    California
    Quote Originally Posted by bb-tt View Post
    By modify you mean cut the bracket?
    B8 A4 S-Line | quattro | Ibis White
    Boss500 Kit | Custom WPT Big Turbo Tune
    Rev9 IC | Fuel-It E Sensor
    Macan 345mm Front Calipers | S5 Rear Calipers | EBC Reds
    S4 Rear Valance | S4 Exhaust | RS4 Grille
    My Porsche Macan BBK upgrade thread: https://www.audizine.com/forum/showt...-on-B8-B8-5-A4
    Apr 30 2018
    DFW, TX
    Yes, even with the bracket cut could not get coolant line to line up with lower port
    Jul 25 2016
    California
    Hmmm, and here I was wondering if I got sent the wrong turbo. Lol
    Apr 30 2018
    DFW, TX
    Quote Originally Posted by Nano909 View Post
    To be more specific it lined up but could not get the banjo bolt to start without it feeling like it was cross threading.
    2011 A4 Avant S-line Prestige
    Nothing to see here, keep moving!
    WPT+
    Jul 25 2016
    California
    Do you know what post this info was on?
    Apr 30 2018
    DFW, TX
    One of the k04 threads probably around sep 2018
    WPT+
    Jul 25 2016
    California
    Damn, well I'll start searching. Thanks a lot!
    Apr 30 2018
    DFW, TX
    Mar 8 2019 in the k04 owners follow up thread . It was a response to you.
    My CTS K04 came in today. Not too sure I want to install the HFC I got with it now since my smog guy says I won't need it. But I'm super excited.
    So I found half of my notes, the most important thing is going to be having the t55 torx for the cooling lines an Allen wrench fits also can't remember what size, if you could find a t55 Apex bit that would be Ideal. You are going to need a Dremel or something to cut the brackets off the cooling lines. If you have a gfb diverter you will need one longer bolt can't remember the size to bolt on to the adapter that keeps the dv in the stock location. Also in mine I could not get the cooling line to line up with the lower port (kept wanting to crossthread) so I moved the plug from the top port to the lower port. Then the coolant leaked as the cooling line went directly over the sealing plug for the lower port and kept it from correctly seating. I solved by using two crush washers under the cooling line supposedly the kit comes with 1 thicker crush washer, I did not notice and was not taking everything back apart to find so for less than a dollar bought a couple stock crush washers at the Audi dealer. Everything else was pretty straight forward, you can download the install directions although when I did they had not updated them for keeping the dv in stock location. If I remember anything else I will let you know. Oh if you have the eurocode turbo muffler delete with the larger outlet you will need to get a stock size hose from there to the intercooler inlet. Speaking of which I need to post a bunch of parts in the classifieds.
    WPT+
    Veteran Member Three Rings Iceman502's Avatar
    Nov 12 2017
    Pioneer 202 Islander, 2014 Q5 P+, 2013 S5 P+
    Raleigh, NC
    Yeah, when I installed mine (see ebay K04 thread), I had to stack two crush washers on top of each other for the coolant feed line. The core had two ports on two of the sides creating some seating issues since the plugs protruded. And I will say that it was a pain to thread in as well. Getting it started was very challenging due to tension on the line, and once it was, it certainly felt like I was cross-threading. Since I had failed to get it started so many times, I kept going and it proved to be watertight.
    That was the only line I had to double stack washers. Unfortunately, I forgot the outside crush washer on the banjo bolt for the coolant return line under the exhaust manifold, but it seated well enough that I haven't had an issue. Also, ensure the oil return line gasket is seating correctly on the bottom of the turbo. Mine was not which lead to a leak, and getting to that to replace it with the turbo installed is one of the worst things I've had to do on this car.
    2012 Audi A4 P+, S-Line, ZF - IE K04 - Totaled
    2013 Audi S5 P+, DSG w/Sport Diff - EPL 3.125PR E40
    2014 Audi Q5 P+, Reman CPMB - Daily
    Feb 08 2017
    Quebec
    I had many issues with mine.
    Overly tight coolant and oil return line. Coolant line drips here and there. Oil line went full pissing mode at one point. Had to change the oring.
    I did have to relocate the coolant line. Also what a pain in the ass to bolt the banjo bolt.. Better off putting that damn thing on before sliding turbo in.
    Jul 25 2016
    California
    Wooooooow, I'm such an idiot. I knew I remembered something about it. Good thing I posted here.
    Jul 25 2016
    California
    Quote Originally Posted by Iceman502 View Post
    Thanks for responding. I have the car in a very reputable shop, so I'll pass the info along and see if they can do it.
    - - - Updated - - -
    Quote Originally Posted by spin0rz View Post
    Wish I screenshot that post at the time. Smh
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    I mean it was a little tight getting everything to fit but in the end got it all sorted. No issues here. Put it on only 500 miles or so ago. Just had to be patient and make sure everything was lined up correctly.
    Oh, no double stack washers or anything. Just modified brackets like they said.
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
    Veteran Member Four Rings Perry01's Avatar
    Jan 22 2016
    Touareg V8 FSI 8V A3 - B8.5 Q5 - MKVI GTI
    Hawaii and Utah
    Quote Originally Posted by Der Konig View Post
    I mean it was a little tight getting everything to fit but in the end got it all sorted. No issues here.... Just had to be patient and make sure everything was lined up correctly.
    Same here, no issues with the installation.
    CPMA / CTS K04-0064 / IE custom tune / Wagner FMIC / Custom ZF8 TCU tune
    Jul 25 2016
    California
    Thanks for the replies everyone. Turbo is on the car. We had to make a new oil line since the old one was pretty beat from the oil leak it had. Made a steel braided oil line and also got the cam cover resealed.
    Jul 25 2016
    California
    Quote Originally Posted by Perry01 View Post
    Hey the IE K04 file is based on yours right?
    Jan 22 2016
    Hawaii and Utah
    Along with a manual trans. B8 A4 that the owner purchased in SLC for dyno testing.
    Jul 25 2016
    California
    I'm making the switch to IE for the K04. Hopefully it doesn't disappoint.
    Jan 22 2016
    Hawaii and Utah
    After downloading the file, drive it a hundred miles, log some data and send the logs to [email protected] , Ask them to take a look. If adjustments are needed, they will fine tune it.
    Jul 25 2016
    California
    Cool. What's the break in period like for the CTS?
    Jul 09 2009
    Cleveland OH Area
    Most turbo manufacturers recommend an hour of operation before full load from what I've seen.
    Nov 12 2017
    Raleigh, NC
    Pull the fuse on the fuel pump the first time you start it so that the coolant and oil have an opportunity to pump through the core. Overwhelmingly, that was the most important piece of info I read repeatedly through various forums and technical sites outlining turbo installations.
    Following that, I'd go by Der Konig's suggestion and just drive it normally for maybe 50 or so miles to ensure everything is airtight and lubricated properly.
    Jul 25 2016
    California
    Nice, can't wait to let it rip!
    Jul 09 2009
    Cleveland OH Area
    Good call, definitely do this. Some say unnecessary but its such a simple and easy precaution.
    After my engine build I did 4 bursts of about 12 to 15 seconds to prime the whole engine. So I would go for around that to ensure lubrication.
    Apr 27 2019
    Danville, IL
    I just swapped my stock IHI K03 turbo to a CTS K04. Got all the lines swapped over and got the turbo installed. I'm having a coolant leak, not from the lines but from the port plugs on both sides. It is a very slow leak but still a concern. Has anyone else had this issue or recommendations on a fix?
