Page 1 of 4 123 ... LastLast
Results 1 to 40 of 144
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    Porsche Macan Calipers on B8 B8.5 A4 FAQ
    I've been getting countless PM's about where to buy and what part numbers I used to get the calipers, and what brakes/rotors to use. I've been mean and not replying to anyone because it took me a long time of searching and looking though this forum and the S4 forum, along with other websites for information so I wouldn't make a mistake of buying the wrong stuff, to just give that information out to a bunch of lazy people. So instead of replying to everyone one by one, I've decided to make this thread.
    This is NOT a DIY. But you will have to search for Porsche sites yourself to buy the calipers if the site I used is out of stock. Please do not ask me to look for you, I will verbally destroy you.
    The reason why I think the Macan/Q5 calipers are the best upgrade for us instead of the bigger 6 piston calipers, is because you get a bigger rotor, 4 piston calipers, and you can use it to their full extent WITHOUT swapping the brake master cylinder. Macan/Q5 uses the same BMC as ours, as does the S4. For this reason alone I didn't go for the bigger 6 piston calipers, because you won't have the full benefit without swapping the brake cylinder and booster, which I was NOT planning to do.
    Yes 3.0T Q5 calipers are the same as Macan. The reason people are going Macan calipers is because they're half the price, so you'd be a fool to buy Q5 calipers.
    You will have to buy bigger rotors (345mm) You can use either 2015-2019 Macan (trims in attached image), 2012-2017 3.0T Q5 rotors, or 2010-2016 S4 rotors. I recommend S4 rotors because they are muuuch easier to find and have lots of options.
    For brake pads, you have to buy 2015-2019 Macan brake pads, 2012-2017 3.0T Q5 brake pads. Those have a sensor slot, but you don't HAVE to use it. I zip tied mine to the side. I think ECS makes a delete kit, but zip ties are a lot cheaper. Alternatively, you can use 2010 Subaru STI brake pads, so you have lots of brake pad options there. I went with EBC Red Stuff so I ordered them for a 3.0T Q5.
    I reused my brake lines because there was nothing wrong with them. I don’t track the car so SS lines weren't needed. Yes they're a little stronger I guess, but if they broke internally there would be no way of knowing you have an issue with them versus the stock rubber ones that you can see when something is wrong. I've never used SS lines in my other cars, including my old track built car. But YMMV.
    I bought the calipers off https://www.harperautoparts.com
    I believe they were $247 each last time I checked. I bought the rest of the stuff off ECS. They didn't have the ducts, clamps, and shields in stock so they had to source it elsewhere. You might be able to source them faster (and cheaper).
    Driver side Macan part number: 95B-615-123-F
    Passenger side Macan caliper: 95B-615-124-F
    Driver side Macan dust shield: 95B615311E
    Passenger side Macan dust shield: 95B615312G
    Driver side Macan brake air duct: 95B615447B
    Passenger side Macan brake air duct: 95B615448B
    Macan brake air duct clamp: 95B699011B (you'll need two)
    You don’t need to change the dust shield, the bigger rotors will fit without modifications (I checked by mounting them before taking them off). I did because I wanted to use the air ducts. You don't have to use the air ducts either. The reason you have to use the Macan dust shields if you want to use the air ducts is because they have an open area where the stock ones are fully closed. So it would be pointless to use the air ducts with the stock shields.
    The upgrade is night and day difference. Take this advice though, they feel incomplete. What I mean is, yes they felt great, way better than stock, but the difference wasn't as big until I also swapped to S4/S5 rear calipers. Now THAT was a huge difference. Like going from stock tuning to stage 2. Think about doing that as well. I didn't do them at the same time so if you decide to wait on the rears then that's okay.
    I think that about covers it. If I forgot some stuff I'll edit in the future.
    B8 A4 S-Line | quattro | Ibis White
    Boss500 Kit | Custom WPT Big Turbo Tune
    Rev9 IC | Fuel-It E Sensor
    Macan 345mm Front Calipers | S5 Rear Calipers | EBC Reds
    S4 Rear Valance | S4 Exhaust | RS4 Grille
    My Porsche Macan BBK upgrade thread: https://www.audizine.com/forum/showt...-on-B8-B8-5-A4
    Veteran Member Three Rings djnuge's Avatar
    May 15 2015
    Nice. Great info.
    Sent from my SM-N950U using Tapatalk
    May 12 2017
    Great write up. I wonder why the Macan calipers are so much cheaper than the Q5's? I picked up the Q5 set from ECS because I'm freaking lazy. But damn, 25% off the calipers is a decent amount of savings (going by ECS prices for both parts).
    Senior Member Three Rings FlyPenFly's Avatar
    Oct 29 2007
    Australian Shepherd
    San Diego, CA
    should be a sticky
    2014 E350 Coupe
    2014 GLK350
    2010 A4 Premium Plus
    Veteran Member Four Rings Traptalk's Avatar
    Oct 14 2018
    Buffalo, NY
    I ended up just ditching the dust shields all together when I did mine.
    A lot of track guys have noted they retain heat and block airflow.
    The air ducts and macan shields was a good idea. Haven’t had any issues without them tho
    ig: @wastegate_warriors
    i like meth
    Oct 14 2018
    Buffalo, NY
    Quote Originally Posted by hcuorG View Post
    Probably because the Q5 is a known caliper upgrade now that ecs and Fcp sell kits to do the swap. Helps give incentive to just get the full kit
    i like meth
    Jul 25 2016
    California
    Quote Originally Posted by Traptalk View Post
    Yeah I wanted to do everything from the start since everything was going to be off. I only tested the stock shields to confirm that they do fit. I personally wouldn't use them with the stock shields though because of the heat like you said.
    The part numbers are there for the ducts so you can install them and get that extra air flow 🙂
    Senior Member Two Rings schwiz23's Avatar
    Feb 22 2020
    Burnsville, MN
    Great write-up! This gives us another option aside from the A6 caliper/rotor upgrade. Thank you.
    Jul 25 2016
    California
    Quote Originally Posted by schwiz23 View Post
    Thanks. None of the credit goes to me though. All I did was do a buttload of research and compiled everything I found together on one thread, along with my experience using them. There's not a complete Porsche Macan caliper upgrade thread anywhere so I decided to make one to help the community.
    Aug 30 2018
    Quote Originally Posted by Nano909 View Post
    Except in my build thread ;)
    2019 Audi Q5 - 28k; Arctic White; Black Optic
    2003 Mercedes ML350 - 166k; Gray
    Jul 25 2016
    California
    Quote Originally Posted by ps2cho View Post
    Build thread =/= Macan Caliper thread
    Established Member Two Rings itsav8's Avatar
    Feb 06 2007
    Ma$$
    I didn’t see you mention if you used your old caliper to housing bolts/nuts etc ?
    - - - Updated - - -
    Aug 30 2018
    Quote Originally Posted by itsav8 View Post
    - - - Updated - - -
    As they are TTY you're supposed to replace them. At bare minimum I'd put fresh blue loctite on them.
    Jul 25 2016
    California
    - - - Updated - - -
    I reused all bolts. 2 ugga duggas and send it.
    Feb 06 2007
    Ma$$
    Absolutely. Just wanted to make sure no special bolts/nuts/washers need to be ordered.
    I will buy new bolts and won’t reuse the old ones.
    Jul 25 2016
    California
    Oh, no special parts needed. All plug and play.
    Veteran Member Three Rings whats77inaname's Avatar
    Aug 09 2018
    ¯\_(ツ)_/¯ Tx
    One of the best things I've read on here since I joined *lol*.
    Jul 25 2016
    California
    Quote Originally Posted by whats77inaname View Post
    Well I hope that inspired you to do the upgrade 😏
    Active Member Two Rings PJs4Rings's Avatar
    Aug 25 2019
    PNW
    Just the thread I was looking for! This will work with the Allroad B8.5 too?
    Aug 25 2019
    PNW
    Jul 25 2016
    California
    Quote Originally Posted by PJs4Rings View Post
    Glad you found it 🙂
    Yes it will, so go for it!
    Senior Member Two Rings PsorianoPre99A4's Avatar
    Dec 13 2015
    B8.5%20AR%2014%27%20P %20
    PNW
    Nano--Will you need bigger carriers or would stock carriers work with this upgrade on the b8 Allroad?
    My Daily
    1999.0 A4 1.8TQM AEB Casa Blanca White
    Stage 3 United Motorsports - Vogtland GT3 - Frankenturbo F21L - TR18T FMIC - 630cc - 3" MAF - 3" 034 HFC - 2.5-3" Neuspeed Catback - ECS RA4 Clutch/12lbsteel - OEM Roof Rack - K&N/F21 TIP - DAWES MBC - VDO Gauge - TurboXS DV - 034 PCV - 034 Rear Sway/Subframe - 034 ICM Delete 2.0 coils - Stock Internals
    Jul 25 2016
    California
    Quote Originally Posted by PsorianoPre99A4 View Post
    The Macan caliper is a single unit, you don't use any carriers.
    Aug 25 2019
    PNW
    Nano I sent you a PM
    Feb 08 2006
    Charleston, SC
    What else is needed for s4/s5 rears? just the calipers?
    '02 A4 1.8T QM - RIP
    '04 A4 3.0 QA - RIP
    '08 GTI - RIP
    '11 GTI - RIP
    '11 BMW 335xi - RIP
    '14 BMW 335xi - RIP
    '18 Audi S4 - RIP
    '14 Audi A4QM - RIP
    Veteran Member Four Rings LionKing's Avatar
    Mar 09 2017
    2009 A6 Avant - 5.2L V10 Swapped, 2013 S4 Backroads Warrior
    MD
    Quote Originally Posted by icon5585 View Post
    Just the carriers.
    Sent from my LM-V450 using Tapatalk
    "Exhaust Gases go in the turbocharger and spin it, witchcraft happens, and you go faster"
    Veteran Member Three Rings SNice's Avatar
    Aug 06 2019
    Philadelphia
    Calipers and carriers - s4/s5 rear rotor is not only bigger (330mm) but it is also thicker (vented).
    2014 A4 B8.5 - AUDI _ EFR 6758 / WPT Stg. 3 Flex-Fuel TUNE / WM Injection / Custom HFC / JHM D-Pipe / AWE FMIC & EXHAUST / APR INTAKE / KW V3
    2002 SV650 - SUZUKI
    1989 nt650 HAWK GT - HONDA
    1972/4 r5/rd350 Hybrid (WIP) - YAMAHA
    1971 r5 350 (basket case) - YAMAHA
    Jul 25 2016
    California
    What Snice said. Calipers, carriers, AND caliper motors. You can reuse your rear brake lines.
    Feb 08 2006
    Charleston, SC
    Does anybody have part #'s by chance for the rear equipment? :)
    '04 A4 3.0 QA - RIP
    '08 GTI - RIP
    '11 GTI - RIP
    '11 BMW 335xi - RIP
    '14 BMW 335xi - RIP
    '18 Audi S4 - RIP
    '14 Audi A4QM - RIP
    Aug 30 2018
    Quote Originally Posted by LionKing View Post
    Just the carriers.
    100% wrong - future posters do not listen to this post - you will end up getting stuck. You HAVE to get the calipers. You do not need the caliper motors if you're 2014+. There is a cutoff in 2013/2014 and you have to match the motors with the calipers. I.e. if you get teh calipers off a 2011 S4, and you have a 2012 you're good. If you buy calipers off a 2015 S4 and you have a 2012, you can't transplant your motors.
    I photographed the differences:
    Jul 25 2016
    California
    Thanks for doing what I didn't. I didn't bother measuring because I wanted to finish already 🤣. But thanks to "The Infiltrator" for being the guinea pig. S4/5 carriers with stock rear calipers will NOT work unless you trim some material off the break pads, essentially shortening their life.
    Mar 09 2017
    MD
    I appreciate the correction. I learned wrong as well and just passing off knowledge I thought was right.
    Jul 25 2016
    California
    No worries bro, we all got fed wrong info regarding brake upgrades.
    Feb 08 2006
    Charleston, SC
    Has anyone found an Audi decal to cover the Porsche writing on the caliper?
    '04 A4 3.0 QA - RIP
    '08 GTI - RIP
    '11 GTI - RIP
    '11 BMW 335xi - RIP
    '14 BMW 335xi - RIP
    '18 Audi S4 - RIP
    '14 Audi A4QM - RIP
    Jul 25 2016
    California
    You'd have to sand down the caliper either way since it comes powder coated, so you won't be able to put a decal on it. Well I mean you could but it won't last very long on there. Lol
    Veteran Member Three Rings hellovaras's Avatar
    Oct 28 2018
    PNW
    Hey guys - two dumb questions inbound. Apologies in advance. 1. So in order to paint the caliper I need to sand it down? 2. Will the Macan caliper fit an S4? I ordered the one listed in this thread. It seems it could since the S4 has the larger 345mm rotor. Just checking. I have an S4, not an A4, hence the question. Thanks
    2013 Monsoon Grey B8.5 S4 6MT | ECS CF Wing | ECS CF Front Lip | Canyon Run-15 Strut Brace | ECS Front Strut Tower Bar | Injen CAI | ECS Center X-Pipe | 034 Motorsports Rear Sway Bar | ECS Tuning Lower Control Arm Brace | Ziza Interior Light Kit | Luft-Technik Intake Air Scoop | ECS CF Antenna Cover | ECS CF Rear Diffuser | IE Stage 1 |Do Tinted Windows Count?
    Aug 30 2018
    Quote Originally Posted by hellovaras View Post
    Yes and you can re-use your rotor if you'd like to. Just need new pads S4 uses the same mounting points.
    Jul 25 2016
    California
    1. Yes since you want to remove everything down to the metal so the paint will stick.
    2. Yes it is a 100% bolt on caliper for the S4. You won't need to change anything.
    Oct 28 2018
    PNW
    Thank you
    Oct 28 2018
    PNW
    Thank you
