That's the right attitude!! Way to go....
Not that you'll read this but for the benefit of others who may:
The control arms are fine. Lowering your car will cause accelerated wear on them unless they are realigned (reinstalled so their neutral point lines up with where the car rests at its ride height). Most people don't do this and thus their arms wear out at the upper bushing. Some people get lucky and this isnt a problem but the ball joint will likely wear out faster since its seeing added stress from being at a more severe angle relative to the stock ride height. If you know how they work this makes perfect sense. You can buy adjustable arms which mitigate this issue when lowered. At stock heights, as long as they are installed/aligned correctly you shouldn't have issues with them unless you have some sort of defect or other failure.
I would say the control arms will last 100k+ miles under normal circumstances. Audi has used the same design since he b5 so I'm pretty sure they've gotten it sorted out in the 10 years previous to them building your car.
