Results 41 to 80 of 95
  1. #41
    Veteran Member Four Rings RallyeBourne's Avatar
    Sep 10 2013
    San Diego County, CA
    90% of what 90% of people do to modify any car is overkill. So what?
    You think everyone that buys $3,000 fully adjustable coilovers needs $3,000 fully adjustable coilovers? Nope, $350 lowering springs will do just fine in most cases.
    Sent from my iPhone using Tapatalk Pro
  2. #42
    Veteran Member Four Rings B5carl's Avatar
    Apr 29 2017
    2001 A4 1.8t AWM 5-speed Quattro(SOLD)
    Boston, MA
    Quote Originally Posted by QuattroBucc View Post
    Neither of those are going to cool your coolant though, maybe the oil cooler slightly helps with coolant temp? how hot is "a little hot", because after a hard run then idling with no airflow that makes sense to be above 190, I bet a lower temp thermostat that opens up sooner would be enough of a fix. Aluminum bling is nice but i think its kind of a waste of $$$ for 95% of people with these cars and their driving habits. like B5carl plans to only do HWY pulls and nothing else, his coolant temps will prob never get hot but he still wants this radiator lol
    It's still going to be on the highway most of the time I beat on it though. I do plan on doing some autox so I actually decided to get the g25-660 0.72 like you did since I can't get the twinscroll EFR anymore. Even though I'll probably only make 450whp max on pump gas...
    Anyways, Good to hear that you don't have overheating issues with your car but I do know the 1.8t runs hotter than my Honda for example so that's why I'm thinking I need one of these. And when I say hotter I mean it reaches operating temp much sooner than my Honda. One of the mechanics I use to work with told me that these engines get so hot that they will produce sludge much sooner than other cars and clog up your oil feed, galleries etc..That's why it's important to stay on top of your oil changes. So you might as well get a good dual pass radiator to stay on the cooler side right?
  3. #43
    Veteran Member Three Rings QuattroBucc's Avatar
    Mar 06 2020
    B5A4 1.8TQ g25-660, MK4 GLI K04
    Santa cruz, CA
    Ah so you decided on the g25-660 instead of g30-770 for the head room? I think if you want to use water/meth you should be able to get 500whp, do you have 91 or 93 over on east coast? if you have 93 and use a good octane booster it will raise it to 95 which is waaaay better than 91 and lets you run more timing. I don't know about what your buddy said, because the thermostat controls the temp... once you're at operating temp which is 190F i think. the coolant is gonna stay at 190 while cruising, doesn't matter if its dual pass or triple pass or single pass radiator. The dual pass would only help you cool BACK down to 190 faster once you go above it. Also my b5 AEB takes a few min to get to operating temp- like 5 minutes of driving to the hwy then its at operating temp, much slower than my GLI which has the SAI and all that which gets up to temp in like 2 minutes. No idea why my AEB runs soooo cool but its a good thing forsure lol
  4. #44
    Apr 29 2017
    Boston, MA
    I want the G25 for the quick spool that everyone is talking about. But I did consider it before I realized that I couldn't get the twinscroll manifold. And I have 93 but putting the booster in it doesn't sound like a bad idea. Dual pass is definitely better than single pass plus it's gonna hold more coolant so it will definitely help to keep it at operation temp.
  5. #45
    Veteran Member Four Rings Blazius's Avatar
    Mar 15 2018
    Europe
    Switch to the 83C thermostat, the stock is way to high IMO specially if you are running upgraded turbos and oil coolers.
  6. #46
    Veteran Member Four Rings ralphie_43's Avatar
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Hi everyone just a quick update, we are going to do an official release October 1st. I will have a link for preorder available within in the next couple of weeks for those who want to secure their radiator.
  7. #47
    Sep 10 2013
    Quote Originally Posted by ralphie_43 View Post
    Do we have a ballpark on price yet?
  8. #48
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by RallyeBourne View Post
    Price will be be similar to our B5 S4 radiator
  9. #49
    Junior Member One Ring DJ GLO's Avatar
    Jan 30 2012
    Olathe, KS
    Any update to this? Pricing? Preorder link?
    DJ GLO - http://www.djglo.net - 5-speed manual swapped 2004 VW Passat 1.8T AWM FWD
    GIAC Stage 1 ECU/Touareg 17Z BBK/Aluminum uprights/Jetex Exhaust/Techtonics DP/034Motorspot HFC/Eibach Pro Kit Springs/Bilstein B8 Sport Shocks
  10. #50
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by DJ GLO View Post
    I’m working on getting everything ready I’ll have a link by end of next week
  11. #51
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Hey everybody here is the preorder link for the CSF B5 A4 1.8T radiator
    https://www.ecstuning.com/b-csf-part...ator/7204~csf/
    Let me know if anyone had any questions. Get in on that preorder to get your radiator ASAP!
  12. #52
    Jan 30 2012
    Olathe, KS
    Yikes-- $459 + shipping from ECS is high . Is there a group-buy offer or discount code for the folks in this thread?
    I don't think I'll be buying this unless the shipped price starts with $3xx.
  13. #53
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    As of now there is no group buy planned for this pre order.
    This is the only perfect drop-in fit radiator for the B5 1.8T out right now. The car we tested on was 1.8T bored out to 2.0 with an EFR6758 and the temperatures on that car have been perfect since day 1 and has had no issues since.
  14. #54
    Jan 30 2012
    Olathe, KS
    I believe that it's a great radiator for the B5 1.8T. But considering the triple-pass B5 S4 radiator is commonly available for $399 with free shipping (034Motorsport, FCP, Summit, Amazon), this dual-pass B5 1.8T radiator for $459 + shipping does not seem like a good deal by comparison.
    Speaking for myself, $3xx shipped is reasonable.
  15. #55
    Oct 14 2006
    by the lakeshore, mi
    What are the chances of making a all metal heater core?
    Current: 01 A4QM avant daily driver.
    Past: 92 ABZ 100CSQM avant, 97 A6Q avant, 93 S4, 95.5 avant, 93 S4, 91 10vt CQ, 98.5 SC'd & IC'd A4QM sedan.
  16. #56
    Jan 30 2012
    Olathe, KS
    Will this be sold at FCP?
  17. #57
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Quote Originally Posted by speedydtp247 View Post
    I feel like the Passat one is all metal.
    1998.5 A4 1.8TQM My Build
  18. #58
    Veteran Member Four Rings Mattr567's Avatar
    Mar 20 2016
    1989 Honda CB-1, 1986 Suzuki SP200
    Quote Originally Posted by xdewaynex View Post
    This what I remember too
    FWD in the tradition of AutoUnion
    99.0 B5 A4 1.8TMS
    I turned a $750 car into a $10,000 car worth $2500
  19. #59
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Yes, once the preorder is over and we officially release this part it will be available on FCP
  20. #60
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Just placed my order for the radiator. Getting all of what I hope to be the final pieces I need to get this car 100%.
  21. #61
    Veteran Member Three Rings HUFset's Avatar
    May 08 2014
    B5 A4 GTRS, MK4 Jetta F21T
    CLFX, Denver
    Quote Originally Posted by Blazius View Post
    Do you have the part number for this?
    2000 A4 1.8TQM|GTRS Elim|550cc Maestro|034 AEM WMI|ECS RA4|Carbonio CAI|034/Borla TBE|CTS FMIC|2.0T/AWP harness|Toy Guy/JHM duo SS|034 mounts|034 CAs/Links|ST Coilovers|A6 Strut Brace|ECS RDiff Mount|Apikol Rear Diff Bushings|A4 Sport Cloths|Euro S3 FBMFSW|B6 S4 Rearview|Euro Bolster|All S4 Interior/Exterior Bits|Sport Mirrors/Trim|M3 Spoiler|Aero Arm Wipers|OEM Votex Rack and A4 Bra|A8 Fat Fives|S4 Cluster|P3 VIDI Gauge|Pioneer AVH-X4700BS|Alpine PDX-V9|6 Polk DB Mids|Eclipse 12"
  22. #62
    Mar 15 2018
    Europe
    Quote Originally Posted by HUFset View Post
    032 121 110F
    More specifically I got GATES TH00182G1
  23. #63
    Oct 14 2006
    it looks like your right
  24. #64
    Jan 30 2012
    Olathe, KS
    Thanks for the reply! I'll see what the total price ends up being from FCP & may end up ordering it from there.
    Yes, I'm running that all-metal heater core in my B5 Passat after the original plastic one started leaking after ~8 years. Someone at FCP reviewed it as fitting the B5 A4 as well:
    https://www.fcpeuro.com/products/vw-...19031c#reviews
  25. #65
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Some CSF All aluminum Radiator love coming to the B5 A4 1.8t manual coming very very soon! Here’s some pictures from our test fit if a prototype let me know if you have any questions I’ll try to answer as many as I can.
    Yea Attachment 268489Attachment 268490
    This is my car in the image with the CSF radiator. LOVE IT... HIGHLY RECOMENDED
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
  26. #66
    Jan 30 2012
    Olathe, KS
    This upgraded radiator helps manage coolant temperature to keep the engine as cool as possible while at operating temperature. This helps with keeping the engine at a much safer point during hard operation like track or spirited driving helping to eliminate overheating and keeping the engine performing at its best.
    With the increased cooling capacity of this radiator, is it possible to remove the clutched engine fan & rely solely on the electric A/C fan to maintain coolant temperatures?
    That would be an advantage vs the OEM radiator + an additional electric fan to replace the clutched engine fan.
  27. #67
    Mar 15 2018
    Europe
    I just recently did that on stock radiator. 2 electric fans in place of existing ones , lower temp rad switch, 82c thermostat. Fans automatically trigger from the existing AC fan plug.
    Much better.
  28. #68
    Sep 10 2013
    You don’t need any fans if you keep moving fast enough. But that increased cooling capacity requires airflow.
    The clutch fan doesn’t do anything at highway speeds; that’s why it’s clutched. It’s the low speed and idling that requires fans to push/pull air and create that airflow across the fins.
  29. #69
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Hey everyone, the radiators will be arriving and shipping this week. Make sure to hop on that preorder asap to secure your radiator!
    Link for predorder attached ---> https://www.ecstuning.com/b-csf-part...ator/7204~csf/
  30. #70
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Awesome! Can't wait to get mine installed.
    Sent from my LG-H931 using Tapatalk
  31. #71
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Just got an email, unfortunately shipping date has been pushed back til Nov 15th.
  32. #72
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    They will ship sooner than 15th, stock is arriving this week possibly even today.
  33. #73
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    CSF B5 A4 1.8T Radiator
    CSF 7204 have now arrived and ready to be shipping out ASAP! Place your order to get yours now!
  34. #74
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Bumping the thread! Find the link attached for more information on the new B5 A4 radiator!
    https://csfrace.com/new-csf-audi-b5-...ance-radiator/
  35. #75
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Tracking shows mine will be delivered this Friday. Going to be a nice upgrade.
  36. #76
    May 08 2014
    CLFX, Denver
    Do you have any numbers to support your cooling claims?
  37. #77
    Apr 19 2022
    Cactus Green '99 A4 Avant TQMS Project, '00 E39 BMW 540i6
    New England
    I would also like to see some hard numbers, especially for that price. Also not gonna order from ECS 'cause fuck 'em.
  38. #78
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Got mine installed Sunday afternoon. Looks and fits great. Only thing I saw that needed modified are the upper rubber bushings need trimming.
  39. #79
    Senior Member Three Rings zatta's Avatar
    Sep 02 2018
    Ohio
    Will this be a limited run? I use my B5 for track and figure I’ll hold off until spring likely to purchase but don’t want to miss this.
  40. #80
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by zatta View Post
    This is not a limited run it will be available from now on!
