Page 1 of 5 123 ... LastLast
Results 1 to 40 of 200
    Veteran Member Three Rings mahhdd's Avatar
    Nov 08 2020
    Atlanta, GA
    Supercharger Porting Q&A and Resource Thread
    If someone wants to help contribute to this, I'll edit my post to include more information.
    Please help out and post more questions, and help the quality of this post by suggesting corrections.
    #1: Who is still in the Supercharger Porting game? - NOTE: Ranked by who has contributed most to this thread
    1. Shane Horning (Clyde, NY) - @superchargedaudisport - *active participant in this thread*
    2. Performance Builds, "Albertaholdings" (Edmonton, Canada) - @performancebuilds - *active participant in this thread*
    3. VAST AZ, Marshall Roles aka "Rockcandy" (Phoenix, AZ) - website
    4. Mike Bunton (Plainfield, Indiana) - @_Madbydesign
    5. Shorties Racing (Centennial, CO) - website
    6. Jokerz Performance (Ashkum, IL) - website
    7. S4Matty (I think he left the business)
    #2: What else should be done to the supercharger if it's off or you're having it ported
    -Fresh supercharger oil (there's a special procedure for this, and Jokerz will void your warranty if you don't consult with them before doing this yourself). In short, measure the amount of oil you can get out, and only replace what was removed.
    -Coolant brick inspection, cleaning (if necessary), and or replacement.
    -New gaskets should be planned every time the S/C is removed.
    -Check for coolant anywhere in the area. Any pooled coolant or signs of coolant could be a symptom of leaky IC bricks or PCV (both common).
    #3: What else should be done to the car if it's off or you're having it ported?
    Maintenance heaven! PCV, Water Pump, Thermostat, PCV Breather Hose, Crossover Coolant Pipe, Intake Gaskets, Intercooler Cleaning, Carbon Cleaning, Cold Air Intake Swap. A less common need/issue is needing to change the Fuel Rail Pressure Sensor
    #4: How do I deal with the logistics of having the supercharger off and shipping it away to get it ported?
    Contact the vendor ahead of time and ask if they can send you a freshly ported, comparable mileage unit so you can just do an immediate swap. Shane Horning has mentioned he can sell you one he has in stock and you can send your stock unit back to him, and it costs the same regardless of what path you choose (porting yours or buying his). He also mentioned he can work with scheduling so there's a lower turn around time. Jokerz advertises 15 business days, and I'm not sure if they do any scheduling. Shane Horning mentioned a potential turn around time of 3 business days from the date of receipt - IF YOU SCHEDULE IT.
    #5: What's the cost?
    Depends on what you get done. There's different rebuild options, inspection services, painting/coating options, pulley install options etc. Jokerz has a inspection service for $150, a rebuild service for $500 (cleaning, disassembly, new bearings), and they can deep clean, pressure test, and service your supercharger coolant bricks for $150( See question #7 below for more info). Shane Horning charges $100 for painting the S/C. Jokerz offers powdercoating. Jokerz offers Griptech S/C for install pullies for $229/each.
    Now - the actual supercharger porting itself from Jokerz has seemingly gone up in price since I started my spreadsheet last year. They were $1,300 earlier this year and now they're $1,575. Shane Horning was $750 last year and is now $850 (end of 2021), and $50 if you want your Throttle Body Adapter ported as well.
    Then you need to consider shipping costs... You cover both sending and return costs...
    #6: What are the power gains?
    There's not a ton of data around this. Jokerz advertises "up to" 67 hp and 36 ft. lbs; but I'm not sure if this is wheel horsepower or crank. Also up to +3 lbs of boost gained. There's another thread from 2018 where Bruno_s4 netted 30 whp from S4Matty's port job off a Stage 2 GIAC tune. Another user picked up 50-60 bhp and +3-4mph trap speed in the quarter.
    #7: What are the other benefits?
    Lower IATs due to increased blower efficiency (needing data/unproven - supposedly only the 'ramp up' in IATs is slowed down), more boost produced (2-3 lbs on average), supercharger efficiency is moved, and the supercharger can be spun harder. All of these combined will allow you to run a really aggressive pulley ratio and move your torque curve lower. Some 2++ drivers upgrade from their 187-190mm cranks to 194-200mm cranks to pair with their smaller supercharger pullies to make best use of the blower.
    #8: If my PCV goes, should I consider going ahead to do this, especially if I'm paying for labor?
    The short of it is if you're not tuned or at Stage 1, you don't really have to consider this option yet. Getting the supercharger off is actually pretty easy (30 minute job, 15 minutes if you know what you're doing and in a hurry). Porting the supercharger is more of a Stage 2, 2+, and 2++ type of thing. If you have the spare cash and you're an type of person, then go for it...
    VIDEO: FCP Euro Supercharger Removal
    VIDEO: Audi C7 Owners International's "This is how you replace your 3.0T Supercharger Intercooler Cores
    #9: Does a ported supercharger benefit someone that's Stage 1?
    Yes; but, it'll be more marginal in comparison to someone who is spinning the blower harder. The best gains will be seen at Stage 2 and 2+.
    #10: Will my tune accommodate for a ported blower at any/all stages?
    It should; but, check with your tuner. I reached out to 034 and they said Stage 1 will take it just fine. There aren't special tunes for ported blowers; but, there are some tuners who have special tunes for larger throttle bodies.
    #11: Does mileage matter on these units?
    They do. 1320 superchargers wear overtime; but, they can be rebuilt, and these blowers are very common and are easily replaceable with lower mileage units.
    #12a: Does it matter for your shop to get both the Throttle Body Adapter and the Supercharger at the same time?
    Yep! Whoever does your port job can match the port of the supercharger
    #12b: What size Throttle Body makes sense for my ported blower?
    Shane Horning says there's virtually no difference between a 80mm and 84mm TB; no gains were seen at lower altitudes. With a higher P/R and altitude, it may yield some additional power, though (unconfirmed). 034 designed their TB to be 84mm. 84mm is still a good option, and may be friendly for future supercharger options or folks at higher elevations.
    #12c: Do I have to port my Throttle Body Adapter?
    No; but, there's power to be gained if you do. Throttle body kits narrow down to 70mm to match stock charger inlet. The porting inlet opens to ~76mm after porting, so matching something like a 034 adapter will allow for better flow. Nobody has numbers on how much power this actually nets. Shane Horning keeps an inventory of 034 adapters in stock for convenience.
    #13: What about my Supercharger Cooling Bricks / Intercoolers?
    They're definitely a weak link. Inspect them, clean them (if necessary), and plan on having to replace them at some point. Not sure if this is needed now that the Mahle bricks are out for $109/each from FCP Euro. I'm not sure if those Mahle bricks are any good; but, everything from FCP Euro has a Lifetime Warranty, so use at your own risk. The OEM bricks are like $260/each
    #14: Shipping: How big of a box am I going to need? How much does a 1320 unit weigh?
    A good box that should fit the unit and allow for packing is 24x24x16
    Not sure about the weight of the unit; but, I think it's 35-40 lbs. [B]Complete charger plus packing plus the box is roughly 45 lbs.[B]
    Cost saving tip: A lot of employers have corporate shipping rates (15-30% off), so you may want to have your employer print the sending and return labels and just pay them directly to save $30-40.
    #15: Any downsides to porting? Can porting be "done wrong"?
    Need more info from someone who ports
    Yes, a supercharger unit can be ported poorly. From what I remember from a 034 Q&A, ports can be "done wrong." Flow matters, and turbulence from a bad port job can happen and cause a restriction.
    The real downside is the unrelated costs. There's also going to be the need for supporting mods, such as cooling upgrades (Heat Exchanger, Upgraded Coolant Pump), a solution for your stock cats (moving them or doing test pipes) so they don't melt, and.... oh yeah...
    More air into your motor means a larger fuel requirement. Adding E40 puts an even larger stress on the fuel system. A HPFP is already recommended for all of 034's E40 tunes. A HPFP is needed for Stage 2+ and a port, because depending on altitude users have been running out of fuel. So you pretty much have to factor in the cost of upgraded fuel components, meth injection, and an ECA (ethanol content analyzer) so you can blend ethanol. Ethanol has a higher octane, which helps deal with detonation.
    #16: What are the differences between a moderate and an aggressive porting job?
    From user RoofRails: This comes down to the amount of material removed from the inlet to the rotor face. All of the Ports seem to remove similar amounts of material in the inlet leading up to the rotor face . Where I see the difference in more aggressive ports (race ports) is the amount of material in front of and around the rotors being removed which exposes more of the rotor face to the incoming air. This can definitely lead to more boost but this style seems to like more RPM to overcome the drag created by exposing so much of the rotors.
    #17: Are there ideal intakes for porting?
    Yes. Some intakes can look like they would flow well; but, when you go Stage 2, 2+, or port the blower the flow actually is greatly restrictive. 034's S34 intake is designed to flow well with all applications. The logs show that my CTS Turbo Intake is fine for Stage 1; but, it may later become a restriction, so I opted to go ahead and upgrade it.
    #18: Are there any bigger blower options available yet?
    Need more info
    I know MercRacing is/was working on something. I've seen something from VPS posted as well. The reality is that these kits are very expensive - $6,000 - $15,000. Even then, you're still up against the power limits of the motor (600hp at the high end) until the ring issues get solved (please save us, Port Injection!). Then... Tuners have to make the business decision of, "Is there enough demand for these upgraded blower kits to develop a new tune around this?" 034 Motorsport is very "wait and see" about this. They don't think it's realistic, given the age of the car and consumer demand. I tend to agree with them. I don't think there's going to be a large number of people looking seriously at $6,000+ blower kits. I think anyone with those means will look at a B9+ series car with all the success they're having and say, "Ya know, I can afford one of these, and the power delivery of a turbo doesn't sound so bad..." Set your expectations realistically here.
    #19: Does an "aggressive" port affect drivability?
    Need someone to answer
    #20: What should I be considering for fuel upgrades
    Definitely a High Pressure Fuel Pump (HPFP), even if you're on 93 (depending on altitude).
    E40 withouta blower definitely requires fuel upgrades. E40 with a blower can get pretty serious, and you need to keep track of things. If you go E40 with a ported blower with an a P/R (Pulley Ratio) above 3.2, there's a good chance you're going to have to consider Meth Injection and/or Port Injection. There's a Port Injection Kit in the works that is supposedly going to allow us to run E40 easily and up to E85, and it addresses the unavoidable carbon buildup issue that occurs with Direct Injection. When running E40, the rail pressure is very high which puts a toll on the HPFP Regulator, which causes a shorter lifespan of the HPFP housing. So expect having to change the actual HPFP at sometime in the future. The best way to monitor the HPFP is to log the pump's duty cycle, and log the car periodically (like we all should be doing)
    #21: Can you try to port a supercharger yourself? Any tips?
    Refer to #15, because it can go wrong. Not sure if anyone who professionally ports will give their secrets, as it'll cost them business.
    #22: What is DA? Does it Matter?
    DA is Density Altitude. It's NOT just elevation. It's an advanced calculation depending on atmospheric conditions, and it matters when determining your ideal pulley ratio. Running a high pulley ratio will help in higher DA; but, in negative DA it doesn't. Shane Horning says if you run Integrated Engineering E40 files in Negative DA with a high PR and an aggressive port that it could blow the rings, which is a common issue from high cylinder pressure, high temps, and/or running lean. Under excess heat, the rings grow and the gap closes and causes the rings to buckle and scratch the cylinder walls (dropping compression).
    #23: What's the ideal Pulley Ratio (P/R) for me?
    It depends. Let's start here - A 206-207mm JHM pulley is NOT more aggressive than a 57.7mm/196.5mm combo. Do the math!!! (Crank Pulley diameter ÷ Supercharger Pulley diameter) - This "just do a big crank pulley" is a common misconception I see on Facebook, where a lot of users say "it's easier and it saves u money." A 207mm with a stock crank is a 3.273 P/R, and a 57.7mm/196.5mm combo is 3.406 P/R, and it's a huge difference.
    Make sure to read #22 as well, because they're related. Shane Horning also simplified finding your ideal Pulley Ratio as the following:
    Negative DA: 3.1 P/R
    0 DA: 3.2 P/R
    1000 DA: 3.3 P/R
    2000 DA: 3.4 P/R
    3000+ DA: 3.4 to 3.5 P/R
    #24: When does it make sense to replace the Snout bearing and the Rear Needle Bearing?
    #25: Should I change my supercharger oil?
    If you're going to be spinning your supercharger harder (reving higher through tunes, using a smaller supercharger pulley, and/or larger crank pulley), you should be changing your supercharger oil. There's not exactly a specified interval. I'd say it depends on how hard you're running your car. 70K miles would be on the safer side and 100K miles would be on the high side. Any supercharger porter will do this service for you, as it's easier to do when the supercharger is off. You can do this yourself; but, make sure you watch a video of how it's done, measure the exact volume of how much supercharger oil comes out, and only replace the amount that goes back in. If you don't, you risk damaging the blower. It requires a lot of twisting, turning, turning the supercharger rotors, etc to get any out. You can also do this when the supercharger is on the car; but, it'll require a special pumping tool/hose, and there's always the risk that you'll break a piece of that off in the supercharger. The service is like $20-30, so don't be cheap. You can use GM AC Delco Supercharger oil, as it's an Eaton product.
    #26: At what point should I be considering porting my blower? What mods come first? What mods come after?
    For the safest route to go and to get the best performance for every dollar invested
    • New plugs and gap them to your tuner/future tuner's specifications (0.026" to 0.032" normally)
    • Intake
    • Tune (Stage 1) can be done here if your temps are OK. It's safer to do the next two mods.
    • Heat Exchanger - stock cars can benefit from an HX upgrade, so it's smarter to get this installed before you tune it
    • Coolant Pump Upgrade (CWA 100-3)
    • Tune (Stage 1) - this is the more conservative order.
    • Testpipes or Gutted Cats (or relocated cats) - address the OEM melting cats issue, which can totally ruin your motor
    • Consider Exhaust Mods here - keep in mind that if you go gutted cats or test pipes AND have exhaust mods, your exhaust will probably sound like a trumpet.
    • HPFP - consider a Cable for Logging, P3 Gauge to monitor, and ECA if you're running ethanol blends. Assume you don't have a ported blower, you can begin to run E40 here.
    • Supercharger Pulley or Crank Pulley with the Stage 2 or 2+ tune - the OEM stock crank pulley is a point of failure and it's an easier job than a supercharger pulley install
    • Ported Blower
    • Throttle Bodies (Ultracharger or Superdupercharger) with the corresponding tune - You can consider having the TB adapter ported as well for max gains. This is best done at the same time by your porter, so they can match the necks together seamlessly.
    • Getting into E40 to E85 - consider meth or port injection, depending on DA and P/R - The Port Injection kit won't be cheap; but, it'll allow you to really push into high P/R and E85.
    NOTE: Exhaust mods (Test Pipes, Downpipes, X-pipe/Resonator Delete, Mufflers) is "somewhere in the middle" and is kind of subjective on where it should be ranked on this list. Keep in mind that exhaust mods allow heat to escape the vehicle through higher flow/less restriction.
    #27: How easy is it to remove the supercharger? How fast can I do it?
    Albertaholdings from Performance Builds says it takes about 30 minutes... 15 minutes if you're in a hurry...
    If a mechanic is quoting you an hour to do the removal, they're criminally ripping you off.
    I need to come back and do a tool list
    VIDEO of removal made by Albertaholdings
    #28: OMFGGGG I can't wait to port my blower then send the horsepower to 600+++ and boost to the mooooooooon!!!!!11
    Hold up! If you're thinking this way, you're going to pop your motor. There's some other good threads you should check out, seen below. These supercharged 3.0t motors have limits and currently we're seeing a lot of cylinder ring issues. The big concern is avoiding detonation with solid cooling, good maintenance, and quality gas. Then, you need to make sure you're getting enough fuel and avoiding injector issues so you don't lean out. More technical information is below
    Resources:
    THREAD: S4Matty's Supercharger and Throttle Body Porting got me 30 whp!
    THREAD: Life Beyond Stage II - The higher stage development thread
    THREAD: Cylinder 5 Issues (The Dreaded Cylinder 5 Misfire) / Melted Rings
    VIDEO: 034 Describing their take on the Ring issues we're seeing with high HP applications, poorly maintained vehicles, and "poorly upgraded" vehicles
    Help Build this thread:
    Ask your own questions.
    Provide additional data
    Suggest edits.
    Experts - HELP!! Give input where you can. Share the questions you get the most that aren't on the lsit. Correct things as you see things that need correcting.
    Give mahhdd a deal on a ported supercharger
    2015 Sepang Blue S4, 6MT, Sport Diff, Ceramic Coated
    034 Stage 1 Tune, Intake, UCA & LCA Kit, Springs, End Links, Drivetrain Mounts/Inserts, RSB, and HPFP Piston, Bilstein B8 Shocks/Struts, P3 V3 Gauge
    MercRacing S6 HX, CWA 100-3 Pump, JXB Shifter, Mount, Extended Slave, and Reinf. Linkage, USB Stainless Steel Clutch Line, ECS Resonated Valved Exhaust, Engine & Trans Skids
    Jul 08 2020
    Calgary
    Im wondering how a very aggressive port affects daily drivability
    Veteran Member Four Rings RoofRails's Avatar
    Apr 29 2018
    #1 Who is still porting. You can add (Mike Bunton) _Madbydesign , Marshall Roles with Vast AZ and Shortiesracing.
    #7 What are the other benefits: You mentioned lower IAT as a benefit. I would say that is a little misleading. People have been claiming this forever (increased efficiency) but has anyone actually proved it ? To me decreased IAT means if I was hitting 60C at the end of a 1/4 mile pre-ported blower then after the port if all other factors are equal I will see less then 60C.
    That wasn't what I saw after my ported blower. I saw more boost for sure and my IAT did not skyrocket but it definitely did not go down.
    #10 Will my tuner accommodate for a ported blower ? None of the tuners that I'm aware of have a ported blower tune. On a Dual Pulley file They typically set a Boost request based on the limitations of 2 bar map sensor which most typical dual pulley set ups won't hit in less then perfect conditions. Adding the ported blower and or a big pulley ratio gets you closer to if not over this boost setpoint (depending on your PR).
    #15A Any downsides to porting: With a good port added to a E40 full bolt on dual pulley vehicle in good air (boost season) you may find that you are out of fuel. If you do find that to be the case you will need to add a supplemental fuel source (Meth) to get things back in shape.
    #15B Can porting be done wrong ? I believe you can overport a case. At some point you will be making far more heat and heat equals boost. We associate boost with power but not if it's a byproduct of heat.
    #16 difference between moderate and aggressive ports. This comes down to the amount of material removed from the inlet to the rotor face. All of the Ports seem to remove similar amounts of material in the inlet leading up to the rotor face . Where I see the difference in more aggressive ports (race ports) is the amount of material in front of and around the rotors being removed which exposes more of the rotor face to the incoming air. This can definitely lead to more boost but this style seems to like more RPM to overcome the drag created by exposing so much of the rotors.
    I will just say that this whole porting game is one where people aren't motivated to share their knowledge so finding facts about the intricacies of porting isn't the easiest. That being said this is my understanding of what's going on based off of conversations I've had with different people in the game. If someone sees it differently I'm always open to change my understanding of something LOL !
    Sent from my SM-N986U using Audizine Forum mobile app
    2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
    Active Member One Ring tastyratz's Avatar
    Jan 14 2022
    usa
    Quote Originally Posted by RoofRails View Post
    Wouldn't 3-4 additional PSI with no change in IAT's be proof of less heat for the same total psi/cfm/whp? Absolute vs relative.
    A PR change to get 4 additional psi would be apples to apples in that respect.
    Feb 16 2019
    miami, fl
    Quote Originally Posted by tastyratz View Post
    yes that's what he is saying. your iat's wont go down, but your psi will go up.
    that doesn't help you if you're bleeding boost from too high of iat's, unless you plan to port just so you can go lower pr for same boost, which isn't the point normally to port.
    it's like how a bigger turbo can give you better mpg because it is less of a restriction, but it doesn't because you'll put your food down and get rid of those gains real fast in turn for more smiles.
    Jan 14 2022
    usa
    Quote Originally Posted by wrxkyle View Post
    Sort of,
    More boost means more airflow... which would normally mean more heat to go with the additional airflow from the additional SC rpm. Let's say you wanted to stick to a 24k rpm cap. This lets you get the boost of a higher ratio without pushing over. You're gaining efficiency at the limit where you might have pushed your IAT's to the moon trying to get that via PR. You can reach it at a lower SC rpm which = lower total btu's per cfm.
    Not a lower IAT than before but more power without additional IAT. I'd rather port than up the pulley.
    Apr 29 2018
    Sort of,
    I agree with this. This is actually the route I went. I'm running Jokers new port ,
    APR UC and a 3.17 pulley ratio and its a absolute beast. Only issue I have is that now is having more air then fuel. Seems to be that if you are running a good port and TB near sea level without meth you will most likely be running into fueling problems.
    Apr 29 2018
    My point was the way people describe the reduced IAT is misleading. You will still be fighting the same IAT issues you had before the ported blower.
    Established Member Two Rings SuitedUp2The9s's Avatar
    Aug 08 2013
    2002 Audi S4 Laser Red
    Alberta
    I had mine ported by PerformanceBuilds.
    Can be found here https://instagram.com/performancebui...dium=copy_link
    I have the Race Port version of his ported blower. I was trapping 119mph before and after that single change I was trapping 123mph in the 1/4 mile. Based on the weight of my car and the horsepower needed to get my 4300lbs C7 A6 with me in it, from 0 to 1/4 mile I picked up ~50-60bhp. DA being almost equal.
    2002 B5 S4 ll 2012 C7 A6
    Instagram ll Youtube
    Dec 29 2020
    Highland Village, Texas
    Subbed.
    Any thoughts on DIY for those who may be willing to potentially screw up our own superchargers? There is some info out there and I think a mega thread could use some info on that option!
    Apr 29 2018
    Here is my before and after 1/8th mile on a 2015 3.0TFSI Q5. 034 E40 file 200mm crank pulley Stock SC pulley.
    The 7.33 @ 96.89 was sock blower / Stock throttle body and 3.17PR. Full weight
    The 7.21 @ 98.82 was APR UC Throttle body and Jokers new no epoxy port and same 3.17PR. Full weight. This was on my second attempt at a dragy run following the install.
    The 7.18 1/8th and 3.19 0-60 were my new PB with the Ported blower , APR UC and some good DA before I stopped testing. (Full weight).
    I knew going in based on what others have posted that without meth I there was a chance I could run into fueling issues on E40 and that's exactly what happened so I limited the number of test runs I made and logged every one of them. I have a meth kit on deck waiting to find some nice weather and time to install it.
    I logged the boost pre and post install and it's 2-2.5psi more across the board. The Yellow line is the boost request and the pink line is the boost actual. The first image is pre install and the last image is post Ported blower. You can see the ecu fluctuate the boost request I'm guessing as a result of my HPFP duty cycle and Injector duration going too high. Once I add a little fuel this should clean up and result in a new PB.
    FB_IMG_1640882624863.jpgFB_IMG_1640882617940.jpgScreenshot_20211127-182800_dragy.jpgScreenshot_20211127-182719_dragy.jpgFB_IMG_1640884029514.jpgFB_IMG_1640884019855.jpg
    Veteran Member Four Rings Shane Horning's Avatar
    Nov 16 2018
    2012 A6 Prestige IE dual pulley. custom trans tune. mercracing hx. autotech hpfp.
    Upstate. New York.
    Great info! Another thing you could add is pulley ratio. Depending what your altitude and or da will help determine best pulley ratio. Running a high pulley ratio will help in higher da but in negative da it doesn't. Another thing to watch for is be careful with 034 and ie e40 files in negative da with high pr and aggressive ports. Have seen quite a few blown rings from it. What I've learned so far is in negative da 3.1pr, 0 da 3.2pr, 1000da, 3.3pr, 2000da 3.4pr, 3000+ da 3.4 to 3.5 pr.
    Nov 08 2020
    Atlanta, GA
    Quote Originally Posted by Shane Horning View Post
    Why are the rings getting blown? Is it running out of fuel?
    Since you do this stuff professionally, can you give your $.02 on things that are incorrect, need editing, need more info, etc? I'll amend my post as needed.
    Apr 29 2018
    Quote Originally Posted by mahhdd View Post
    Rings have been our Achilles heel. Under excessive heat they grow and the the ring gap closes causing the ring to buckle in on itself scratch the cylinder walls and drop compression. I believe its related to a lean condition but others are saying it's related to cylinder pressure. Oleg was running more boost then any of us for quite some time because he had his fueling figured out. Same for the turbo B8.5 Mario built.
    Nov 16 2018
    Upstate. New York.
    It's not entirely related to fueling. It's related to cylinder pressure when running peak timing. Oleg didn't have problems because he was running 20 degrees timing, we are at 34. Same reason he didn't lift his heads whereas Justin and my car we lifted the heads in negative da.
    Veteran Member Four Rings hunter_killer's Avatar
    Mar 25 2020
    Mandan, North Dakota
    Has anyone made a head stud kit for this engine or contacted say ARP yet to your knowledge? I thought Shorty and Oleg were but I haven’t seen any update from either in a long time (I know Oleg has more so moved to the 4.0 side with his swap).
    2013 Quartz Gray S6: APR Stage 1 and CTS intakes.
    Gone: 2013 S4 Stage 2. RIP.
    Nov 08 2020
    Atlanta, GA
    I passed along some info to 034 and they were able to address some of their thoughts on this week's Q&A about the Piston Rings
    Check the 46:41 mark
    https://www.youtube.com/watch?v=Js-PvVBZz9A&t=2802s
    Worth the listen for anyone in here. They talked about it for a good 10 minutes.
    Apr 29 2018
    I just listened and they said that the rings aren't our issue but fueling was. Good we agree with that and I clearly stated that the excessive heat was a result of a lean condition. By getting caught up in what exactly happens once the cylinder goes lean is not as important as finding out how to prevent that from happening in the first place.
    A question I still have though is why is the scored cylinder wall / lost compression on a single cylinder. Is that typical amongst other platforms as well ? I think we have all seen a pattern with cylinder 5 as well. I do see other cylinders joining the party but #5 is a over achiever.
    We throw lots of ideas and theories around on these pages and it's often time the debate that spawns a answer or a solution. Thanks for entering into the debate 034, it sounds like this still needs more discussion but we agree it's a fueling issue.
    Nov 16 2018
    Upstate. New York.
    80mm throttle body is basically the perfect size. I've done comparisons with 80 and 84 and no improvement with 84. Another thing to add is with aggressive port and 3.2+pr on e40 in low to negative da you will need port injection or methanol injection to handle the fueling as ie or auto tech pumps won't keep up. Also when running e40 the rail press is very high which puts a toll on the hpfp regulator causing a shorter lifespan of the hpfp housing so expect having to change the actual hpfp sometime
    Nov 08 2020
    Atlanta, GA
    What's the best way to catch this? Logging? Do you remember the parameters?
    Nov 16 2018
    Upstate. New York.
    Yes logging hpfp duty cycle. On my car the duty cycle slowly kept getting higher till maxed out at 99%. I'm not sure what parameters on vcds as I log with ie or 034 cables
    Nov 08 2020
    Atlanta, GA
    I'm coming back to this, and it's my first time paying attention to Density Altitude. I'm in Georgia, and I was pretty shocked to learn it could fluctuate so much! I'm currently -650 DA and it was +1700 DA the other day. What's the philosophy for planning around these fluctuations???
    Nov 16 2018
    Upstate. New York.
    Well actually I kinda worded it wrong, I would say it should more be based of altitude. However just a baseline, kinda take an average da and match the pr to that.
    Nov 08 2020
    Atlanta, GA
    Throw out a min and max number for reliability in GA
    I don't want to blow motors or be lifting heads
    Nov 16 2018
    Upstate. New York.
    If you see negative da I'd run 3.3pr
    Nov 08 2020
    Atlanta, GA
    Were you saying that the 84mm throttle body was potentially a cause for the ring issue, or were you saying that's just something to "add" to what I have. I think you're saying the later.
    That's some good info.
    Nov 16 2018
    Upstate. New York.
    Just something to add. A bigger tb will flow more air but going from 80 to 84 isn't necessarily an improvement. Not saying that the 84 isn't a great option, just thot I'd mention that the 80 is big enough
    Nov 29 2018
    Edmonton
    Best logs I have ever seen on stock blower is everything ported to 81mm with my adapter. I'm hitting 1389maf limit now. IMG_20211209_205104.jpgIMG_20211127_165740.jpg
    Sent from my GM1917 using Audizine Forum mobile app
    Nov 16 2018
    Upstate. New York.
    Quote Originally Posted by Albertaholdings View Post
    Yes the important thing is to port the charger inlet as large as possible but with apr,ie or 034 adapters etc I haven't seen a gain from swapping out the 80mm to an 84. However I'm +500ft sea level so at a very high altitude with thin air and high pr an 84 may very well give more gains.
    Nov 29 2018
    Edmonton
    There's not 84mm of material. So I'm just sticking with the Hemi that measures 81mm at the back. Maybe could do 84mm but the heads of the bolts would be sticking out on the inside.
    Nov 08 2020
    Atlanta, GA
    • Updated my original post to add more questions
    • Edited some of my responses to include more information
    • Highlight some of the actively participating porters in this thread
    • Color coding to what's needed
    Aug 08 2013
    Alberta
    I updated my post with more accurate information
    Nov 09 2018
    east stroudsburg pa
    Is a hpfp needed for a stage 2+ with a ported blower on 93 octane?
    Sent from my Redmi Note 9 Pro using Audizine Forum mobile app
    Nov 16 2018
    Upstate. New York.
    Quote Originally Posted by stevemannn View Post
    Depending on altitude but yes guys at sea level run out of fuel on 93 with a good port
    Nov 09 2018
    east stroudsburg pa
    Interesting, thank you.
    Junior Member Two Rings
    Jun 24 2020
    Far away
    I'm going Oleg way on 3.0T, right now im on way building another engine with forged internals. ARP dont have any head stud kit for our engines yet(Hope they will take a custom order for it). I bought a turbo kit from Oleg (G35-900).
    What companies else can provide me a head stud kit ?
    Nov 16 2018
    Upstate. New York.
    Quote Originally Posted by nosport View Post
    Lmk how the eng build goes. I'm very interested in doing that same thing to a few engines I have that #4 cylinder is damaged
    Mar 25 2020
    Are you going to do any head work (porting/ polishing) or bigger valves? I’ve never seen any head specs on these engines and nobody talks about them so are they good enough from factory?
    Jun 24 2020
    Far away
    Quote Originally Posted by hunter_killer View Post
    Head will be little polishing for sure. Time will show, whats more will be done. Probably different valve springs. Not many peoples doing hard work on those engines still(Why?)
    Audi A7 C7 3.0 TFSI STAGE 2+ (589HP/665NM)
    -Ported Supercharger.
    -Port matched inlet with 80mm TB.
    -200mm/57.5mm Dual Pulley Setup.
    -WMI 500cc + 250cc.
    -Killer Chiller.
    -2 x CWA100-3 Water Pumps.
    -AutoTech HPFP.
    Mar 25 2020
    Sweet. I don’t know, maybe there’s not a big crowd for it (which is probably true) but enough interest will still keep pushing the platform more and more.
