Results 1 to 14 of 14
Threaded View
    Aug 02 2020
    York, Pennsylvannia
    Cannot Figure Out This P0011 Code All Help Appreciated
    Hi guys, I've been having a problem ever since putting this car back together. Had the usual timing tensioner problem but ever since I've put everything back together I've gotten this P0011 code that I can't seem to pinpoint. I was wondering if anyone here has had the same problem, the list below is what was done so far.
    -New head that I bought used online (valves were fine)
    -New N205 solenoid
    -New Cambridge
    -Checked both cam/crank sensors, even replaced the camshaft because it was so cheap.
    -New Intake camshaft because the old one the shaft and the gear broke apart (basically I could turn the engine by hand but the lobes weren't moving)
    -Checked timing 3 times and everything was spot on
    -Replaced chain and tensioner twice
    -The car runs fine and I can seem to pinpoint the issue causing the P0011 code.
    I'm all out of ideas and was wondering if anyone could help, I want to keep the car if I can get rid of the code so I can pass emissions but in the last 4 months I'm very tempted to sell it.
    2010 Audi a4 2.0t MT 155k
    Pics Included of timing measurements. (Balance shaft links were lined up when I first put the car together, it takes a couple rotations to line back up)
