Results 1 to 9 of 9
    Aug 21 2019
    Montreal, Canada
    Stock 19inches tires for B8.5 ?
    Hi there,
    suspension is stock non-sport/sline and I am running 255/40/19. It rubs in almost every pothole here in Montreal, Canada... I read threads saying that you don't rub with this size but here I come, rubbing on the highway
    So I want to ask what is the best size for 19" by 9" rims ? the stock one is 235/35/19 or 255/35/19 ?
    What are you guys running, with same setup ?
    May 10 2015
    Pittsburgh PA
    I have 19x9 wheels with an aggressive et33 offset and stock sport suspension. With 255/35/19 tyres I only rub over big bumps with passengers in the rear.
    You should be fine running 255/35/19 on the non-sport suspension.
    Senior Member Three Rings vincent_nguyen2's Avatar
    Oct 05 2016
    2014 Audi A4
    Dallas, TX
    I think the stock S-line wheels mine came with were 19x8.5 et43 and my aftermarket wheels are 19x9.5 et45 both running 255/35/19 tires
    2014 Brilliant Red A4 Premium + S-Line
    APR Stage 2 w/ Downpipe | AWE Tuning Quadtip Catback | Airlift V2 | VMR V802 Anthracite Metallic on Falken FK510 255/35/19 | Macan 4P Front Brembos
    2022 Florett Silver SQ5 Prestige
    Maxton Design full exterior kit | IE Intake and Turbo Inlet | IE Catback w/ Audi Sport Tips
    May 12 2017
    I'm running 19x8.5 et35 with 255/35/19 tires. On Bilstein B12 kit, I rarely rub. Haven't had passengers in my car yet but I've stuffed my trunk pretty good and haven't had an issues.
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Quote Originally Posted by zizouomar View Post
    Hi there,
    What wheels do you have and what is the offset? That will be key to determine whether you are pushing the tire out/in too much and getting into the rubbing territory.
    The other part that plays against you is the side profile of your tires. 255/40 is Allroad spec. I assume you have an A4, which calls for 255/35. Your tire is 12.75mm taller than OE spec, so ~0.5" closer to the body/fender and the whole car sits 0.5" higher as well. Typically, it may not matter, but you have 9" wide wheel with unknown offset.
    See the effects of moving away from OE spec here by plugging in your specs: https://www.willtheyfit.com/index.ph...h=9&offset2=33
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Aug 21 2019
    Montreal, Canada
    Quote Originally Posted by eljay View Post
    Thanks for the answers guys.
    I dont know the exact offset, I should take the wheel off and check it out. I managed to find some Michelin PSS 255 35 19 and it seems that it resolved my rubbing issue.
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    I'm using stock S Line suspension. 19x9 et33 wheels and use 255/35. No rubs, funny noises or anything .
    B8 A4 S-Line | quattro | Ibis White
    Boss500 Kit | Custom WPT Big Turbo Tune
    Rev9 IC | Fuel-It E Sensor
    Macan 345mm Front Calipers | S5 Rear Calipers | EBC Reds
    S4 Rear Valance | S4 Exhaust | RS4 Grille
    My Porsche Macan BBK upgrade thread: https://www.audizine.com/forum/showt...-on-B8-B8-5-A4
    Jul 16 2018
    Atlanta
    Audi OE 19" wheel/tire for the B8.x A4 sedan/wagon is 255/35 r19 on 19x8.5 et43.
    Audi OE 19" wheel/tire for the B8.x A4 allroad is 245/40 r19 on 19x8.0 et26.
    Aug 21 2019
    Montreal, Canada
    Thanks for your answers guys
