Results 1 to 22 of 22
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Abt AS400 clone, 13 Allroad/RS5 swap
    SoCal, but not the nice part
    Custom virtual cockpit project
    I've posted in the telematics forum to discuss this as well, but it's for my B6 S4 avant, so here we go.
    I'm jealous of the new tech in the current Audi lineup, so I want to rejuvenate my project car, a 2005 S4 avant. I was originally thinking about how I could somehow utilize a newer gauge with the Virtual Cockpit and somehow get it to work in an older car, but just the differences in the communication network of the car would be very hard to overcome. I found a guy who makes custom digital clusters, and he has effectively copied the VC look. However, I think I may be able to do this myself, using raspberry pi or something similar. The LCD screens are available:
    Seems close to what Audi uses:
    This may take a while, but I'll try and keep this thread updated. I'll also be running a tablet in the center console replacing the stereo, and I'd like the two to be linked together. Anybody got any advice?
    -Tim
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Pretty cool idea. I doubt getting the new Audi stuff to work is viable. Your hunch seems right that differences in communication through the eras would be a problem.
    It seems like it would entail having someone build a custom computer that turns CAN signals and other car communication into graphics. Many people have “hacked” the cluster to display different things, by sticking extra modules between the cluster and the rest of the car computers, for example to display the output of a radar detector, boost, coolant temp, etc. And the wiper stalk is used to scroll through this information. So it’s clear that you can effectively read the CAN information you need from the car, and control things using inputs from the car’s buttons. Seems like the big step would be the computer/graphic design to turn those into something meaningful on your dash.
    Mar 13 2007
    The nice thing about this is that enough people have done similar things on other platforms to drive creation of canbus adapters that work with a raspberrypi. The hardware seems available off the shelf. I like that I can have a graphic added so the intro splash is an animated Abt Sportsline symbol as well. Anyway, I have a lot more research to do, but this is looking very possible. If I end up having trim bezels manufactured, I may offer them for sale or post the 3D models up to make this available to everyone.
    -Tim
    Senior Member Two Rings icanfly's Avatar
    Jan 12 2012
    06 B7 S4 | 92 Corrado SLC VR6 | STI Powered HandBuilt TarmacRallyCar | Skydiving Rig
    Looking for a canyon to carve.
    I cant see your pictures, but am doing something similar for my racecar build - I am using an OBDII solution to connect to a tablet with the app RealDash which allows you to make full custom digital dashboards. They've got some good tech - and there are several varitions on how to get data off your rig and into the realdash app.
    slow is fast...
    Mar 05 2018
    Czech Republic
    Did something similar. The main thing for me was to controll the Android Auto app with RNS-E buttons. The only problem is, that on the CAN-Bus behind radio, there are only limited number of data - Coolant temp, RPM, time, speed. Im planing to make K-line reader to get more data. I've got the hardware, but not the time :)
    And the usecase you might be interested in
    Mar 13 2007
    After spending the last few days reading everything I could find, I think I need to go with something OEM-ish. A Renesas R-car D3 seems to be a good choice if I can find one, or a similar purpose-built computer. I can run the gauges and integrated MMI on the cluster screen, and also drive a large TFT screen in the center console, eliminating the head unit. Hell, there might even be a way to ditch the HVAC control panel and integrate that.
    -Tim
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by Padouch View Post
    Educate me!!! I know some python, so what else do i need!
    Mar 13 2007
    Quote Originally Posted by icanfly View Post
    I'm looking to duplicate the virtual cockpit in the newest Audis, and the realdash app takes too long to boot for my liking. The goal is OEM-level fit, finish, and appearance, but with customization available for apps and gauge finishes, or the startup splash.
    -Tim
    Mar 05 2018
    Czech Republic
    If you want only coolant temp, Rpm, speed then only think you need is a Arduino or raspberry and a canbus transceiver like mcp2515. If you want more information, you have to make some kind of k-line reader. At least that's what I found out. I can send you the code and some more information if you are interested.
    Mar 22 2015
    2012 Mini Countryman S
    Va Beach
    I am interested, but I also want the android auto in my RNS-E... That surely took more than just an RPi and canbus transceiver with a "little" coding.
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by sonosam View Post
    same here
    Mar 05 2018
    Czech Republic
    I'll try to write something up as soon as possible. But for RNS-E you will need multimedia adapter, VIN hack and a RPi with canbus transciever. Look up Crankshaft app for raspberry. It handles the Andoid Auto part. Then it is just a simple python script, that reads the canbus behind radio and simulates keyboard presses. I can upload my sd card image if you want. I'll try to comment my code better.
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    yea I was reading about that last night! Why the VIN hack tho?
    Mar 05 2018
    Czech Republic
    I meant VIM hack :) Autocorrected
    Mar 13 2007
    Do you guys mind starting a separate post about the RNS-e stuff?
    -Tim
    Mar 13 2007
    And now I have a 2016 TT cluster to play with.
    Nov 03 2011
    All Over!
    Following this. 👍
    1986 Type 85 Audi 90 quattro
    Mar 13 2007
    Following this. 👍
    Hey man, can you do me a favor and measure the dimensions of the area in the center of your Exeo's dash? I'm looking for the measurements from the top of that storage area or whatever is above the hazard light button all the way to the bottom of the HVAC controls.
    -Tim
    Mar 13 2007
    Does anyone have opinions on incorporating the HVAC controls into a touchscreen display? It would replace both that and the stereo, possibly along with taking up the area where the crappy cupholder, hazard light switch, and ESP button are located.
    -Tim
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    I like tactile buttons for HVAC, because i can change it without looking...
    Apr 27 2019
    madrid
    Please its posible send me your sd imagen for put android auto in my raspberry for rnse, i have other os and dont found well
    Junior Member One Ring Shift_bag_Sean's Avatar
    Nov 15 2019
    Cleveland/OH/Midwest
    Quote Originally Posted by sandspeed View Post
    A few years later, it seems such a technology has finally become available...
    https://www.ebay.com/itm/164918725775?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=164918725775&targetid=12627494929 42&device=m&mktype=pla&googleloc=9015312&poi=&camp aignid=10454521904&mkgroupid=122766957512&rlsatarg et=pla-1262749492942&abcId=2146002&merchantid=119072811&g clid=Cj0KCQjwpreJBhDvARIsAF1_BU1FZ_355978zgYxnv2W_ CggIKNcsjzXsAte9N_KCOFhSThctsAfgW0aAlxMEALw_wcB
