Results 1 to 40 of 52
Hybrid View
    Veteran Member Three Rings 4.2 prototype's Avatar
    Nov 01 2011
    Grove City, OH
    2003 Audi RS6 - Quickest and Fastest C5 RS6 in the USA Stage 3+ 650HP
    2003 Audi RS6 - 163k Miles and will go up because I daily it ;)
    Mugello Blue with the Silver interior.
    I am the second owner, the original owner is also on our RS6 forum. This thing has been documented for a while now :)
    Condition:
    The exterior shows the normal wear for a car this age including small front bumper chips. (had a clear bra on bumper and headlights for awhile) That was pulled off the front and the car was fully corrected and ceramic coated a little over 2 years ago. It could technically use a refresh now, that or i was just going to have it wrapped at this point to hide all the little annoying things around the car because of my OCD. The underside is in great shape and I've recently power washed it as well. The side skirts have some clear bra on them which I haven't removed yet, but it's faded... paint should look new when removed.
    The interior looks great with minor wear showing on the driver's front seat bolster. No rips tears or blemishes. There is a small fingernail mark on the headlight switch, cup holder has marks and needs super glued back on lol. and a mark on the defrost button. Everything is regularly cleaned and conditioned. everything works properly. it stays super clean. Needs new floormats.
    Issues:
    Will need plastic wiper cowl replaced soon, I left tcu out of the floor because of this, it doesn't soak anything just a precaution as its a known issue with c5's and I've felt it damp before after a hard rain. Sunroof drains are clean.
    Trans pan seeps a little, will need to be resealed... was just going to do it at next fluid change.
    Passenger rear speaker is annoying some days lol
    The last shop scratched passenger fender putting the bumper on :(
    Other than that there are no major issues whatsoever. No other leaks/etc.
    Let's get to the goods!
    Aftermarket Mods:
    Engine:
    New Garrett GT28RS's machined into the stock RS6 Housings
    New Braided Oil Feed/Return Lines/Fittings
    New Braided Water Lines
    Full custom 3" Downpipe Back Mandrel Bent Stainless Steel Exhaust With Only an X-Pipe
    4" Milltek Exhaust Tips
    New R8 Coil Packs/V8 Derlin adapters and brand new Denso copper plugs.
    New Custom 4" to 3" enclosed intakes.
    New 1000cc Bosch injectors and adapters
    Welded -6an return line bung to fuel stock rail
    Braided -6an feed
    New Fore AFPR with new -AN fittings
    Forge Diverter Valves
    New Walbro 450 Intank Fuel pump
    New AEM 400 External Fuel Pump
    New 100 Micron -8an Fuel Filter and Fittings
    Stock FPR Block off Plate
    Venair Intercooler Hoses
    Wagner Intercoolers
    034 SAI Delete Plates
    Aux Radiator Delete
    Gates Racing Blue Timing Belt W/ New Timing Components
    New timing chain Tensioners W/ New Gaskets
    Powdercoated Wrinkle Red Valve Covers / New Gaskets
    Powdercoated Silver Intercooler Pipe into the Throttle Body
    New Stern Motor Mounts
    Tuned by Nubcake on our RS6 Forum. With Switchable Tunes from E85 to Pump Gas via wiper stalk. Also has ANTILAG and Decel Pop
    Always Fresh Oil, I have always used Amsoil Euro
    Trans:
    NEW Trans Specialties fully built 5HP24 with 5 extra prototype exedy friction disk, Thicker stronger clutch basket, HD bearings...etc. (I also Had Stage 2 Friction Disk's made just in case if these wouldn't hold) Joe will help you out in the future on this trans if you wanna upgrade it to stage 2 disk.
    NEW Custom made Precision ONH Billet Triple Disk Torque Converter. Anti Balloon Plate, Billet Cover, Balanced, Furnace Brazed, Hardened Splines, Upgraded Stator, Reinforced, 2800 RMP stall... The works...
    NEW specialty made trans fluid by BND for this car, Brian over there has all the specs for this car.
    NEW 034 Upgraded Trans Mounts.
    Mirza TCU Tune (This needs to be updated again)
    Brakes:
    New front Brembo pads last week.
    Wavy R8 Rotors upfront
    New Aki Pads in the rear.
    New Motul Brake fluid
    Suspension:
    H&R Coilovers
    NEW Mahle HD Lower Control Arm Kit
    Hotchkiss Swaybars Front/Rear
    Wheels/Tires:
    NEW 19x10 ET22 Enkie RPF1's
    Semi New 285-30-19 Continental Extreme Contact DWS Front/Rear
    Motorsport Hardware Extended Wheel Stud Kit w/ Lightweight Lugs
    No spacers ;)
    Exteror:
    Imported Duckbill Wing from Germany and had it Painted.
    Imported Maxton Front Lip, Side Skirts and Rear Diffuser
    New Hella Euro Smoked Tails
    Recent Window Tint Done at I Think 35%
    Detailed/Ceramic Coated
    New Blue Side Mirrors :)
    New 8k Headlight Bulbs
    Wagner Intercooler Grills
    New Aero Wiper Blades
    Interior:
    Upgraded to an RNSE
    Imported Rare Blue Carbon from Germany (no cracks)
    AEM Wideband Gauge (have a 3D printed vent mount for it, not installed yet)
    Bobs Auto Sport Headrest Camera Mount
    Metal Gas/Brake Pedal Covers
    New Battery
    And with all that said I'm sure I'm leaving something out... the car has recently set the NHRA world record for the quickest and fastest C5 RS6. (has gone 11.40's and 126MPH) Your job will be to put this bitch in the 10's, it has the MPH to do it. Trans tune needs adjusted (send it back out to Mirza or a few other shops can do it if you take the car there) OR put a standalone trans computer in the car was probably my next route so I could make changes on the fly.... yes it's possible now! I just don't have time to be the guinea pig to do it..... ANYWAY... wanna see some pics???
    So there you have it! let me know if your interested, this thing drives amazing (esp in sport) and some might not like how loud it is, but it does sound good... you can add mufflers later :)
    I know what I want out of it, and I would be happy at 24k.... But I know it's just not gonna pull that.... So please make me a reasonable offer I can't refuse. I'm simply moving on into another Audi Project. I've reached my personal goals with this one :)
    03 C5 RS6 - Quickest/Fastest C5 RS6 in the USA - Sold
    10 B8 S4
    13 C7 A6 Prestige - Nexttt
    Veteran Member Four Rings ENV²'s Avatar
    Nov 04 2010
    I love this car
    Sent from a misfiring cylinder
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    Man that stance is perfect IMHO. Hows the ride on the H&Rs? 24k is a good price considering what's been done. If I was in the market, I'd jump on her. GLWS.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Nov 01 2011
    Grove City, OH
    Slightly firm with the H&R’s but it’s really not too bad honestly. She’ll take a corner tho! ;)
    10 B8 S4
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Did you beat Corbett’s record?
    He has a 6 speed 600sportec
    rs6. I forgot what his car runs
    but it’s really quick.
    Established Member Three Rings conspiracy's Avatar
    Feb 23 2019
    NorCal (Burlingame)
    Wow that things stance is perfect, and the Maxton lips all around look awesome. Only thing missing is manual conversion.
    Nov 01 2011
    Grove City, OH
    Quote Originally Posted by conspiracy View Post
    For me personally it’s drag racing, and for that reason I just went all out with the Auto. Although if the next owner continues this project and they put the 01E in, it will be a really really fun car on the street haha.
    10 B8 S4
    Nov 01 2011
    Grove City, OH
    Yes, but he has since upgraded his car a shit ton so until he takes it out again this car holds the record. He has a lot more power/mods, which technically you could also do to this car, it just needs custom manifolds and a really good fab guy to make bigger turbo’s fit the auto.
    10 B8 S4
    Jun 23 2008
    Gorgeous, clean car for this style, don't see too many of them around. Always loved these big boys!
    Sep 28 2009
    suburb
    nice car. good luck
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Nov 01 2011
    Grove City, OH
    Thanks guys! Officially got my next project on the way so she really does have to go...
    Just a FYI I do own a dealership and can take credit cards, provide 45 day tags... etc.
    10 B8 S4
    Nov 04 2010
    Where is it located?
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Nov 01 2011
    Grove City, OH
    Columbus, Ohio.
    10 B8 S4
    Senior Member Three Rings freuds's Avatar
    Sep 21 2008
    2002 911 Turbo X50, 2004 4runner
    Delaware, Ohio
    Quote Originally Posted by 4.2 prototype View Post
    Columbus, Ohio.
    Damn!! You're right by me too! If i didnt' have my Noggy, i'd jump all over this.
    Current: 2004 4runner SR5, 2002 911 Turbo X50
    Sold: 2000 Nogaro Blue S4 Stage 3, 90,000 miles; B6 A4 Eurospec 2.0T/GT3071R Turbo/Spec Stage 3 Clutch/AWE FMIC/AWE Catback Exhaust/ 3in dp/630 cc injectors/revo software.
    B5 Silver S4 Stage 1.
    Sep 21 2008
    Delaware, Ohio
    How did you know that it was at Dandini's haha. The rebuilt tranny just got sent back from JHMotorsports. Not sure of an ETA on all the other work that's being done but damn this baby is gonna be sweet when she's all done.
    Nov 01 2011
    Grove City, OH
    Quote Originally Posted by freuds View Post
    Sent my S6 there for some work, your car is beautiful man!
    10 B8 S4
    Sep 21 2008
    Delaware, Ohio
    Thanks!! I can't wait to get her back. Long story why the car is even there, but my insurance company screwed me over pretty good. Truly unbelievable.
    Veteran Member Three Rings xFvse's Avatar
    Sep 08 2016
    Wuhan
    Not sure if this is the fastest, there was one that made about 900 wheel
    Nov 01 2011
    Grove City, OH
    Anything has 900 until they post a NHRA slip to prove it ;)
    I’ll wait.
    10 B8 S4
    Nov 01 2011
    Grove City, OH
    Full tank of fresh E85 this morning :)
    10 B8 S4
    Nov 01 2011
    Grove City, OH
    Fire Sale... 20k
    10 B8 S4
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Nov 01 2011
    Grove City, OH
    Quote Originally Posted by q_dubz View Post
    It's ok, new project shows up to me today hopefully :)
    10 B8 S4
    Veteran Member Four Rings jolio1994's Avatar
    Sep 06 2011
    Little Egg Harbor, NJ
    How this hasn't sold yet is beyond me. I'm sure the modifications alone well exceed the asking price...
    Loving the blue carbon weave, it complements the exterior very nicely.
    Nov 01 2011
    Grove City, OH
    Quote Originally Posted by jolio1994 View Post
    Thanks man! If they wanted someone could easily sell the built trans and converter and put those funds towards a 6 speed swap kit, that alone would pay for the swap.
    Also, if it were me, I'd probably sell the new turbo kit and upgrade to something a little bigger since you'll have more room in there... maaybeee some EFR 7163's
    As of today she's in the garage until the new buyer picks it up.
    10 B8 S4
    Nov 01 2011
    Grove City, OH
    Thinking about putting this thing up on BAT when I get back from vacation, until then make me a reasonable offer!
    10 B8 S4
    Nov 01 2011
    Grove City, OH
    Is it the Noggy at Dandini's?
    10 B8 S4
    Veteran Member Three Rings barbear1978's Avatar
    Jul 07 2016
    'murrca
    Love the stance and blue carbon! Where in Germany did you import from?
    CURRENT: 24 A5 Sportback nbm (wife) - 21 RS6 Avant TE nbp - 17 VW Mk7 GTI sport nbm - 93 Civic 5-speed mr
    GONE: 10 R8 V10 sbp - 20 SQ5 mb - 08 RS4 ti sbp - 17 Sienna SE sw - 15 Macan S sbp - 15 S4 dgp - 08 .:R32 dbp
    Nov 01 2011
    Grove City, OH
    Thanks! Ebay.de is my go to lol
    10 B8 S4
    Nov 01 2011
    Grove City, OH
    I apologize in advance for how shitty this video is lol... but you guys need to hear it a bit ;)
    https://youtu.be/dbXkeuUWF7c
    10 B8 S4
    Oct 30 2012
    Arizona
    You're right the video is shitty but it sounds NOICE!!!
    Nov 01 2011
    Grove City, OH
    Lol I was trying to txt it to a potential buyer but it was too big so I put it up on the tube.
    10 B8 S4
    Nov 01 2011
    Grove City, OH
    Next owner will be the first to break the 10 second barrier on the C5 platform.
    Let me know if you’re interested in being the one.
    10 B8 S4
    Nov 01 2011
    Grove City, OH
    10 B8 S4
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Good luck! This gives me slight buyers remorse for my stock S5 that I just bought at the same price, but with 34k on the odo.
    C6 RS6 seats, a paint correction and maybe a muffler would just make this thing perfect (for me!)
    Nov 01 2011
    Grove City, OH
    The seats? it really needs something lightweight and nice to help with its times at the track... I was going to do it but you'll lose the heated seats :(
    Paint is still pretty awesome from the last correction/ceramic coat... wouldn't take much work at all really.
    Mufflers.... maybe... until you hear it in person... the x pipe only and turbo noises are just.... ugh.....amazing.
    I'll admit if you daily this thing it might get to ya and you'll want a deeper tone... I was getting to that point but I also didn't want to add more weight.
    10 B8 S4
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Sorry if that came across as negatives. Those are just the things that I would do to it in my head to put my stamp on it. I would daily the thing so those creature comforts would be well worth the sacrifice in tenths of a second at the track. It really is a fantastic RS6 and I am fairly surprised it hasn't sold yet.
    Nov 01 2011
    Grove City, OH
    It's all good!
    The car gets fantastic responses when I daily it everywhere it goes. From the sound to how it looks really wide in person haha.
    10 B8 S4
    Veteran Member Four Rings ThewhippetsS5's Avatar
    Jul 12 2013
    MD & HI
    Holy moly that sounds glorious. Always loved these cars
    Sent from my SM-G960U using Tapatalk
    - Jeremy | Instagram: Oahu.Homes
    2012 Audi R8 GT
    2016 Audi RS7
    2015 BMW X5M
    Nov 01 2011
    Grove City, OH
    Welp, she hit her reserve this morning so we will see what happens from here :)
    10 B8 S4
