More carnage last night! Ripped the rear subframe out and somewhat stripped it down. I'll hose it off today since it'll be warm out and after I remove the bushings from both subframes, I'll bring them to the powder coater. Unfortunately my area announced a covid lockdown so that might delay things on that front.
I also put a couple coats of paint down in on the rust spots of the engine bay, and a couple coats of black on the back end of the tranny (after a lot of scrubbing grease off).
Subframe out! Not that bad of a job, really. I pulled it with the diff / control arms / axles still installed, then pulled that apart on the garage floor.
For brake lines, a while back I had made a crow-foot-type tool, 11mm, because I was in a pinch and couldn't get to the store. I also find typical crowfoot wrenches can be a tad loose, and for soft brake fittings that are completely seized they can still slip sometimes. This tool I made fits nice and tight over the fitting, usually needs to be gently tapped on with a small hammer or nearest piece of metal (usually the latter). It's ugly but I haven't met a brake fitting it can't break loose.
To make it, I used both ends of a deep 11mm socket and welded them together, side by side. After I slit the hex portion for the brake line, I squished it slightly in a vice to tighten the fit over a fitting. Then I welded a reinforcing piece to prevent it from splaying when torque is applied. Again, nothing pretty or fancy, but one of the most functional tools in my box.
For example, these fittings don't appear to have ever been disassembled, and they popped loose like nothing.
I had picked up a silicone plug kit for my powder coating operation but found them incredibly useful for capping brake lines!
Today I'll pull the subframe / rear diff / wheel well liners out to the driveway to degrease and clean. I think it's supposed to be about 5 degrees out which is crazy for this time of year. I also think these are the final big pieces that need to be cleaned in the driveway, everything else can be done inside (smaller items). I've been very fortunate to have these little winter weather breaks for cleaning stuff outside.
Once those big pieces are clean, I'll jump onto cleaning the wheel wells and maybe some of the underbody. There is a bit of surface rust near the rear subframe mounting positions so I'll clean and paint all that. I'm really just trying to get all the tedious dirty work out of the way before tearing into the engine.
