After a lot of trial and error and a lot of help from forums/internet research I thought I would share what modifications that I have successfully got to work on my C7.5 Audi A6
OBDeleven Mods:
VIM (Video in motion) will not work with Vagcom right now. From what I could see no one has figured out the security code but you can do it with the OBDeleven tool and i can confirm its working.
Green Engineering Menu will not work with Vagcom right now either. But I did get it to work using OBDeleven. The options seem a lot limited I couldn't figure out to really do anything worth customizing but i have confirmed its working. The layout is different then the 2012 A6 engineering menu.
Vagcom Mods:
Comfort Windows Roll Up
Enable Coming Home & Leaving DRL Function
Euro Parking Lights
Enable Adaptive Brake Lights
Tail Lights On With Front DRLs
Curb Lighting
Enabling The Daytime Running Lights On/Off Setting In The MMI
Enabling Tourist Mode Setting For Headlights In The MMI
Activation Of Footwell Lighting For Vehicles Without Lighting Pack
Gauge Test/Needle Sweep
Lap Timer/Oil Temperature/Boost Gauge/Shift Light
Enable Automatic Gear Selection Shown In DIS
Seatbelt Reminder Chimes
Add Sensitivity Menu For Active Lane Assist (If Equipped)
Close The Trunk Remotely (If You Have Power Trunk)
Change The Time Before The Heated Seats Auto-Change From Level 3 To 2
What I COULDN'T Get To Work:
Enable Independent Fogs Control With High Beams
Enable Auto Handbrake When Shift Into Park
Enable Battery Meter
Change Massage Seat Time (Seems To Only Work On Some Comfort Seats)
There is an amazing post that gave me 90% of the information i needed to do these changes. Most of the mods work for C7-C7.5 but there is a select few that don't work by the old methods. I hope this helps.
Below is some websites that I used to find the information needed to do these mods. They should have all the information for Vagcom mods to do yourself. OBDeleven is very straight forward but you do have to buy the device and pay for PRO and finally each mod costs money but it's super easy. If you live in my area I would happily let you use my OBDeleven.
Sources
https://www.audiworld.com/forums/a6-...a6-a7-2882436/
https://www.audizine.com/forum/showt...st-for-C7-C7-5
http://forums.ross-tech.com/showthre...-Vagcom-Tweaks
http://www.audizine.com/forum/showth...st-for-C7-C7-5
http://www.audizine.com/forum/showth...-list-and-help
http://www.vwaudiforum.co.uk/forum/s...C7-VCDS-Tricks
http://www.audienthusiasts.com/VagCom.html
http://vcds-expert.com/2015/05/26/au...s-coding-list/
