For a current generation TT-RS, what are considered the must-have mods or upgrades for real track (road course) use??
Or, if there is another Audi forum with more specific info on track use, please lmk! Doesn't seem to be much out there.
What modifications or upgrades do you suggest at a minimum?
I have read the brakes are a weak point. Will stainless lines, new pads and high-temp fluid be sufficient? Or are new rotors and/or calipers suggested also? I have the Audi carbon ceramic front brakes. I've seen several options for front caliper replacement, but so far only rotors for the rear. Any full brake kits for the rear? Has anyone found a source for the Audi Sport brake cooling ducts?
Is an intercooler and/or intake upgrade needed to help with heat soak?
Any 18" wheels that will fit?
What suspension mods will allow increased negative camber for tire wear?
Thanks for any suggestions!!
