Yea I did this a while back. It was definitely harder than expected to remove those rivets. If I remember right I used a pry tool under the entire rivet to pull it out slightly. Then I was able to get a small thin screwdriver under the rivet head and pop it out from the body of the rivet. Probably would have been much easier if i wasn't reaching from the side and could actually see the rivet better.
