Page 9 of 15 FirstFirst ... 7891011 ... LastLast
Results 321 to 360 of 580
  1. #321
    Aug 26 2018
    Boston MA
    Haha, just some good natured trolling from the peanut gallery. Your updates have been fun to follow. Looking forward to seeing those Brembos and Vorsteiners mounted up!
  2. #322
    Veteran Member Four Rings MK2SQ's Avatar
    Aug 11 2018
    Quote Originally Posted by Salty Mope View Post
    You had a good point regardless, I’m glad you enjoying the build 👍
    Prestige B9 SQ5 / Moonlight Blue / S sport / DAP / Dynamic Steering
    JB4 Tuner / ROC-Euro Intake / Lowering Links / 034 Trans Insert / V-FF 109
    / Brembo GT 380mm / AWE Exhaust /
    Build Thread | Instagram @_kademan_v60cc_ | YouTube @MK2 SQ
  3. #323
    Veteran Member Three Rings 4-ring-sleepers's Avatar
    Feb 17 2018
    2018 SQ5/2021 SQ8
    Central FLorida
    Quote Originally Posted by JD S4 View Post
    Perfect.. Will your phone pick up the sound? If your GoPro doesn't pick it up - that's abit surprising and I suppose good because it means that it's not obnoxious...
    I've got a big weekend coming up.. Lowering, tune, intake, spacers and rack pads - all on the same day. Just need a 50+ weekend day and it's go time.
    I have to admit, cell phones are getting better and better with lenses and mics. Helps if you have high quality sd card also. My vids are from Note8.
    Here is inside car under moderate exeleration at highway speeds. I have awe exhaust also so there is sounds from that also. Not sure if Im posting videos correctly with youtube link.
    https://youtu.be/gUrjXnJk2QE
    Sent from my SM-N950U using Audizine mobile app
    2018 SQ5 Prestige - AWE Carbon Intake, AWE Touring Resonated Exhaust, RedStar Exhaust HFC Downpipe, Turbo Systems Stage1 Hybrid Turbo, Forge Motorsports FMIC, Forge Motorsports Transmission Insert, Cete Active Suspension Controller, EPL Stage 3 (beta) tune, Carbon Fiber (w/alcantara sides) Steering Wheel, Vorstiener VFF-110 20x9 et35 Zara Gray, APR 10mm Spacers, Ti extended Lugbolts, Suntek Ultra PPF, Cquartz Finest Reserve, Full Cquartz Interior, Formula One Stratos Tint 30%
  4. #324
    Feb 17 2018
    2018 SQ5/2021 SQ8
    Central FLorida
    Quote Originally Posted by 4-ring-sleepers View Post
    Also this little short clip can hear full sounds with windows up.
    https://youtu.be/6ApKHP-mCgw
  5. #325
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    Thanks man! Those aren’t too loud at all from the video
    Sent from my
    '18 S5 - BBS / EPL
  6. #326
    Aug 11 2018
    Quick city driving clips from iPhone 7
  7. #327
    Feb 17 2018
    2018 SQ5/2021 SQ8
    Central FLorida
    JB4 issues
    cant get my wireless bluetooth to connect to JB4r36 bluetooth unit. also my mobile app will not connect to "KIT" times out every time. did u have any initial issues with connecting and setting up? I registered and logged in on mobile app but cannot get any connection to JB4 unit and my car throws all kinds of error codes!! I already contacted Burger just wondering if there were any quick tips. thanks!
  8. #328
    Aug 11 2018
    I did not have any issues, do you have the new unit that is shipped with the Bluetooth unit connected with the JB4 controller or did you wired it in? As you are not able to connect to the JB4 you can’t look up the codes you get. My first step other then contacting BM as you did would be to disconnect the Bluetooth unit from Jb4 and see if it works normal (no engine codes) without it. I would also check all my connections especially the OBD2 both under the wheel as well up at the unit as some report plugin in the 4 pin connector backward (190deg) and was not really connected.
    If you need more help just ask or DM.
  9. #329
    May 07 2016
    Having the exact same problem.
    Sent from my
    '18 S5 - BBS / EPL
  10. #330
    Aug 11 2018
    Sent from my
    I think the “new design “ that grabs power from the connector is the culprit. I wonder if you get the power to it as documented in the past instructions if it would fixe it? However he is also getting check engine light that would potentially not caused by just Bluetooth error. Let’s see that BM will respond with as you both already are working with them. Good luck !
  11. #331
    May 07 2016
    Quote Originally Posted by SQ5/2018 View Post
    Yes - I have no CEL and car is running good ans fast in Map 1. It’s only the BT connection part I can’t get to work.
    Yet.
    I’m gonna try the 180 swap above and see if That’s it. Will try tonight after work
    Sent from my
    '18 S5 - BBS / EPL
  12. #332
    Aug 11 2018
    Yet.
    Sent from my
    As you don’t have codes it’s probably not the 190 change. In your case the only thing I would try is to remove the blue wire from the B9 pin and wire it per old instructions taking power from the wire harness and not the JB4 controller. I would however see what BM recommends as the unit you both have is a newer gen that my unit.
  13. #333
    Aug 11 2018
    love the trunk space on the SQ. how many "sports" vehicles can carry its own parts
    Thanks MOPS for getting it all to me so quickly !!!
  14. #334
    Nov 16 2015
    Northern Mass
    Awesome!!
    Sent from my SM-G950U using Audizine mobile app
  15. #335
    Aug 11 2018
    Quote Originally Posted by cb4rings View Post
    Awesome!!
    Thanks brother looking to get the tires mounted and get the car cleaned up. When I know the salt and snow is gone they are going on.
  16. #336
    Sep 28 2010
    NW NC / DE
    Looks like you have a race seat on the drivers side at quick glance 😛
    What is that I'm seeing?
  17. #337
    Aug 11 2018
    Small takeaway from Germany and the cars I owned. Coat hanger
    https://www.mercedes-benz-shop.ca/en...0?sv=No-Models
  18. #338
    Sep 28 2010
    NW NC / DE
    Awesome! I assumed so. Looks really cool. Good for hanging underwear to dry.... once they see the whip on the new wheels? 😁
  19. #339
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    Who needs to see out the back window when you got thousands of dollars worth of aftermarket parts in your car!
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
  20. #340
    Aug 11 2018
    Quote Originally Posted by choppstixxx View Post
    There’s no looking back 😎
  21. #341
    Aug 11 2018
    What underwear? 😅 I believe in full contact with the vehicle 🤪
  22. #342
    Aug 11 2018
  23. #343
    Veteran Member Four Rings buggravy's Avatar
    Jun 25 2016
    Mountain bikes and snowboards
    Calabasas, CA
    Hot damn those look good.
    '23 S4 Prestige - Chronos Grey
    '24 Q4 55 e-tron Glacier White
    '24 Q5e District Green
    TOTALLED: '21 Q5 P+ - Glacier White (wife's)
    SOLD: 21 S4 - Mythos Black
    SOLD: '19 SQ5 - Quantum Gray
    TOTALED: 21 SQ5 - Ultra Blue
    SOLD: '19 e-tron - Typhoon Gray
    SOLD: '16 SQ5 - Sepang Blue w/Black Optics
    IG: @gravysq5
  24. #344
    Apr 24 2017
    Hilton, NY
    Get em coated up! Also is the center cap suppose to have texture like that in the black area (maybe it's just a reflection from your ceiling)?
  25. #345
    Junior Member One Ring
    Aug 21 2018
    WPB, FL
    Summer is coming time to get the body in shape, first we need to work on legs.
    NIIIICE!!!
  26. #346
    Aug 11 2018
    Quote Originally Posted by buggravy View Post
    Thanks🙏 And they look even better in person 🤤
  27. #347
    Aug 11 2018
    Will do, the center caps on pictures do reflect the ceiling excellent catch. The cap is gloss black with raised txt and logo. Also will be replaced with red soon 😉
  28. #348
    Sep 28 2010
    NW NC / DE
    LOL!! That was my reaction in the wheel thread. Saw them there first. Too funny!
    MOPS on the Move!
  29. #349
    Established Member Two Rings Kamakazi's Avatar
    Jul 08 2010
    2018 SQ5//2002 VW GTI 337//84 VW GOLF MK1 1.8T
    they look good can't wait to see it on the SQ
    Sent from my SM-N950U using Tapatalk
  30. #350
    May 07 2016
    Kamil setting the benchmark for the B9...
    Gonna be fire!
    '18 S5 - BBS / EPL
  31. #351
    Aug 11 2018
    Gonna be fire!
    Thanks brother! Got to be first to something someday 😂
  32. #352
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Wow! Full depreciation in one post.
  33. #353
    Mar 21 2016
    2018 SQ5
    Scottsdale, AZ
    Did you change your fake exhaust outlet grills? Mine have honeycomb like the trim in the center.
    2019 SQ5 - Quantum Gray - Premium Plus - 21's - S Sport - Napa - B&O - Roc Euro Intake
    Previous:
    2018 SQ5 - S Sport - Napa Leather - B&O
    2018 Q7 3.0T - Premium Plus - 20's - Vision - Warm - Cold - Towing
    2017 Q5 3.0T S-Line
    2016 A5 S-Line
  34. #354
    Sep 28 2010
    NW NC / DE
    Gonna be fire!
    For real!!
    We've got a few other B9 21x10 setups in the pipeline, too. Excited to see them!
    Quote Originally Posted by SQive View Post
    LOL'd 😂
    Quote Originally Posted by naudical View Post
    Mike - the 2019 has honeycomb. And with your post, it seems the later 2018 do as well.
  35. #355
    Feb 02 2019
    Vancouver, BC
    This wheels are stunning Kamil!! Might want to powder coat my HREs to black.. Lol
  36. #356
    Aug 11 2018
    Quote Originally Posted by spenkew View Post
    Thanks brother I’m excited to get them on can’t wait for this winter to be over with
  37. #357
    Feb 02 2019
    Vancouver, BC
    Same here dude. I can't wait to put it on but I want to squeeze in a last trip to Whistler before the snowboard season is out so guess I'll havta wait
  38. #358
    Mar 21 2016
    2018 SQ5
    Scottsdale, AZ
    I think it may actually be a Prestige thing? I saw another Prestige online with the smooth "tips". My 2018 and 2019 Premium Plus both had the honeycomb.
    Previous:
    2017 Q5 3.0T S-Line
    2016 A5 S-Line
  39. #359
    Sep 28 2010
    NW NC / DE
    I have Prestige...
    Well that doesn’t show them well
    Mexico is playing games!
    MOPS on the Move!
  40. #360
    Feb 17 2018
    2018 SQ5/2021 SQ8
    Central FLorida
    I figured out that the Audi MMI and my Note8 phone were somehow set as priority to connect on demand. so even though i disconnect the bluetooth from MMI on my phone ,the audi unit continuously re-connected. blocking out the JB4 r36 module from ever getting a chance to complete the "handshake". I everything working now and its way more pull and drives harder in each gear. Map 3 is the go to im assuming?
