Page 2 of 15 FirstFirst 123412 ... LastLast
Results 41 to 80 of 580
  1. #41
    Veteran Member Four Rings MK2SQ's Avatar
    Aug 11 2018
    Quote Originally Posted by JD S4 View Post
    That’s awesome man!! Thanks for the write up and pictures. Super helpful.
    Question - I’ve read 3-4 owners instance of this install and all have same the same thing about having to do it 2-3 times to get the adjustment right. What do you attribute that to? Seems simple - set them all the same and go but clearly not that easy. Do you have to removal them completely to adjust them each time?
    If you did it again - what would you do differently? Skip the jacking and wheel removal?
    You should make that post a DIY and we can have it stickied
    After some miles - post your thoughts on ride quality, handling and the trade offs.
    Thanks for the informative post! This is the best part about forums.
    Sent from my
    The reason for my multipole adjustments is that the front and rear are hard to judge the adjustment before you done it once. Then side to side was also not perfect first time around. I also removed then to make the adjustment as I was worried to damage the sensor if performing the change connected.
    If I did it again I would get the drive on ramps. They would give you all the clearance you need, also would do it at a warmer day. I would also count the full rotation of ball joints to measure length vs a ruler.
  2. #42
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    Quote Originally Posted by SQ5/2018 View Post
    Excellent tips! I’ll use both. I’ll use ramps and measure the turns. Great stuff!
    Sent from my
    '18 S5 - BBS / EPL
  3. #43
    Aug 11 2018
    Sent from my
    Anything I can do, we are all in this together and should help one each other.
  4. #44
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Kumbaya, my Lord. . .Kumbaya
  5. #45
    Veteran Member Three Rings cmoore86's Avatar
    Nov 11 2014
    2018 SQ5
    San Jose, CA
    Sent from my
    Any tips on installing just let me know. I have taken them on and off several times. I just put the car in the offroad mode and there is plenty of room under the car to access the sensors for me. My estimation is one full turn of one of the side of the links is about 1mm. When doing height adjustments make sure that the lower side of the link has more threads and only take the lower side of the link off the control arm and adjust the link then while the top of the link is still attached to the height sensor.
    Another possible reason for the multiple adjustments is that not every car/sensor is the same exact position. A .5 mm makes difference in sensor position. The sensors are set and then the suspension height is calibrated by Audi. So while 5mm difference in link length works for some, 6.5mm may be the right for you. Then on top of that you have the OEM sensors trying to level the car. Change just the rear right, your front left will change slightly. Dont go crazy chasing the heights to be exact the same side to and front to front...the OEM set up was not exactly perfect either. At least not for me.
    2018 Audi [] SQ5: Navarra Blue | BBS | AWE | 034 |
    Sold - 2015 Audi RS5: Sepang Blue My Sepang Blue RS5
    Sold - 2015 Audi SQ5: Sepang Blue cmoore86 2015 SQ5
  6. #46
    Aug 11 2018
    Quote Originally Posted by cmoore86 View Post
    All great point Cmoore and thanks for the help with the installation
  7. #47
    Aug 11 2018
    Just found out what is making the mouse like sound in the rear. After few visits to the dealer they found that the muffler actuator is not working correctly requiring muffler replacement (under warranty). I’m glad we found it finally as it was getting annoying.
  8. #48
    Aug 11 2018
    No big update still waiting for the service to be done to install the JB4. I halve replaced the old wipers with Rain-X Silicone, and treated the window with Rain-x and Rain-x fog.
  9. #49
    Senior Member Three Rings Symko's Avatar
    Jun 10 2011
    ‘12 Glacier S4 ‘19 SQ5 (wife’s)
    Reston, VA
    Any updates/impressions on the JB4 tune?
    Thx, Dave
    Got some goodies today from Terry and George from Burger Motorsports. Super team and great company do deal with, definitely recommend to reach out to them if you want more power.
    Thanks guys!!!!
  10. #50
    Aug 11 2018
    Quote Originally Posted by Symko View Post
    Thx, Dave
    Should have something this week as I got the service visit on Tuesday. Unit will be installed after that. Will keep you updated
    Prestige B9 SQ5 / Moonlight Blue / S sport / DAP / Dynamic Steering
    JB4 Tuner / ROC-Euro Intake / Lowering Links / 034 Trans Insert / V-FF 109
    / Brembo GT 380mm / AWE Exhaust /
    Build Thread | Instagram @_kademan_v60cc_ | YouTube @MK2 SQ
  11. #51
    Jun 10 2011
    Reston, VA
    Great thank you
  12. #52
    Aug 11 2018
    Found a perfect location for the "dragy" GPS performance tracker just in time to test out the JB4 tuner.
    Love the unit especially the voice cue for speed and distance so you can keep looking on the road, would definitely recommend it.
  13. #53
    Veteran Member Four Rings DiscoDan's Avatar
    Sep 07 2018
    Colorado
    Great build thread.
    Curious what pinch weld adapter you're using on your floor jack? Link to it as well?
    Thanks
    2020 SQ5 - Prestige | Quantum Gray | 034 Stage 1
  14. #54
    Aug 11 2018
    Quote Originally Posted by 2018_SQ5 View Post
    Great build thread.
    Thanks
    Thank you...
    this is the product, DEDC Advanced Grooved Universal Magnetic Jack Pad Pinch Weld Frame Rail Adapter (Orange).
    I used the rubber (hockey puck) design first and it ripped in half first time used this is the link,
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  15. #55
    Aug 11 2018
    First, I would like thank George and Terry from Burger Motorsports. They make an excellent product, but the support and their availability is what places them in a category on their own. Anyone looking for some extra power for B9 or any Audi give them a shout.
    Now to the fun part… I hope some will find this usefully.
    Sensor, JB4 box and harness output location.
    Remove the weather seal to gain access to the comportment
    Cut the grommet in the fire wall to run the OBDII connector. Use a small gauge stiff wire from outside to then pull the connector from the inside. I found the wire worked great and would not recommend using a coat hanger.
    JB4 unit placement (will work on more secure mount)
    Results tracked by dragy, and image of the app.
    If anyone has any questions or request for more pictures let me know.
  16. #56
    Sep 07 2018
    Colorado
    Nice... do you have the #'s for the hp and torque gains? Both advertised from Berger and from actuals on a dyno?
  17. #57
    Aug 11 2018
    advertised is ~50hp i have no access to a dyno but this is the run before numbers... not sure of the number but definitely significant in all of the power bend testing by the butt dyno
  18. #58
    Sep 07 2018
    Colorado
    any plans to dyno it?
    also, what octane of petrol?
  19. #59
    Aug 11 2018
    if i find one and the cost is not a lot i will dyno it also looking to get some drag time on it next year. as for octane 93 from BP
  20. #60
    May 13 2015
    Georgia
    Hey man great log! I also installed the JB4 on my SQ5 and is worth every penny. Would love to see the dyno if you get to it. I almost pull the trigger on the Draggy myself, how os it working for you?
  21. #61
    Aug 11 2018
    Quote Originally Posted by Fabre80 View Post
    Thanks, and welcome to the JB4 club
    Overall dragy is a great product that i recommend. The app is easy to use, it gives you voice feedback to speed and distance, and never had an issue with coverage. i do however have two points that i hope that the manufacture would take to consideration.
    1. battery life is very low, i understand that is probably to keep the unit small but with the current technology you would think this would be addressed.
    2. this is really what surprised me and got my mad, i paid for the unit but still have to watch a ad for a product on the app when i lunch it. granted its for few seconds but seriously not cool !!
    still, i would recommend the product to anyone that has no access to dyno or a drag strip and is performing performance changes to the car.
  22. #62
    Stage 2 Banner Advertiser Three Rings
    Nov 13 2018
    South Africa
    Thanks for the detailed review.
    Which map did you do the dragy runs on?
    If you find a place to dyno let me know and we will sponsor the runs. We always looking for end user results.
  23. #63
    Aug 11 2018
    Quote Originally Posted by George@BMS View Post
    Hello George!
    Map 3 is what I was running when tested... but will use Map 1 for daily driving. Looking forward to some longer trips to see any potential MPG increase. Map 3, boy what a difference the part that I like the most is that the power is across the power band. You can enjoy it and use it without getting to trouble with triple digits speeds. The car shift and sounds awesome as well. For the quick, easy, no special tools required installation this is truly the best performance mod you can install.
    Thank you for the offer on the dyno runs sponsorship will definitely look in to getting it done now. Will spend some time in Chicago for holidays should not be hard to find a 4 wheel drive dyno. Let me know if you would like a more detailed SQ5 B9 installation guide and will get one written up.
    edit*** i just emailed you with a dyno option. let me know ty.
    Also anyone in OH area that needs help with installation let me know
  24. #64
    May 07 2016
    Can you post the stock dragy vs. map 1, 2 and 3 dragy? That would be dope.
    4.75 is a good start for a pig of an SUV. There is more in this motor for sure - FMIC, e85, intake and downpipe and crank it up to Map 5 and we're talkin!
    Thanks for building and sharing. Stoked to see it.
    '18 S5 - BBS / EPL
  25. #65
    May 13 2015
    Georgia
    Sure! I just noticed you have the same color combo as well. Mythos black/ Gray interior nice choice!
    I may put some E85 this week and run it. My friend here has an S4 with the JB4 and is already running E85, told me is a big difference.
  26. #66
    Aug 11 2018
    will try to get it all done... currently i'm out of the state plus i think we got some snow.
  27. #67
    Aug 11 2018
    thanks, and that is awesome! What mixture of E85 is he running?
  28. #68
    May 07 2016
    I’ve seen 25-35 hp on my S4. Depends on tune and ECU and fueling - but probably a safe bet to think you could gain 20-30 hp if you max out your *safe* e content
    Sent from my
    '18 S5 - BBS / EPL
  29. #69
    Nov 13 2018
    South Africa
    You can go up to 5gal to the tank or keep it in the region of E35 or so. The blends seem to be all over the place at the pumps so there is no reason to be scientific of the mixture and what I have suggested has got leeway in it. You can go straight to map 5 with that and there will be a decent gain similar to the jump from map 1 to 3.
    in the cooler weather we are seeing quite a few cars doing fine on 93 and map 5 as well. I would suggest you shoot some logs over though if you want to try it.
  30. #70
    Aug 11 2018
    Thank George,
    I’m so happy with the power gain that have no need to go with the Emix right now. I’ll hold of on it until I can get some track time in the summer. Definitely great to have this ability.
  31. #71
    Aug 11 2018
    For people that like to follow the build, the journey, the life of an Audi enthusiast
    please follow on Instagram @sq5_mk2
    Fist post will be today from TURN IN CONCEPTS in Cincinnati, to test the JB4 from Burger Motorsports, Inc.
    Thank you to George from Burger Motorsports for sponsoring the dyno runs.
  32. #72
    Veteran Member Three Rings Speedooooo's Avatar
    Sep 13 2015
    Cincinnati, OH
    Nice ride! Do you live in Cincinnati? I emailed Tune In the other day about a dyno request. They didn't respond :(.
    2018 Glacier White A6 3.0T | Driver Assistance | Sport | Black Optics
    2016 Mythos Black Q5 3.0T SOLD
  33. #73
    Aug 11 2018
    Quote Originally Posted by Speedooooo View Post
    Thanks sir, I live north of Dayton. I got them to respond only when I called. They were very nice and helpful especially as my phone died (completely failed) and needed them to get JB4 app (that I still paid for) but they did let me use the phone.
    It’s a long story I will post everything soon hopefully with some images when they send them to me as well the data.
  34. #74
    Sep 13 2015
    Cincinnati, OH
    Let me know if you're back. Would love to see the ride.
  35. #75
    Aug 11 2018
    I’m home this week, the should have a working phone Monday afternoon and will follow up with them about the data and pictures if they won’t email it by then. You got anything done the Audi?
  36. #76
    Sep 13 2015
    Cincinnati, OH
    Post up!
    I have a Chipwerke, but just bought EPL S1. Waiting on the cable to install it. Other than that I have some RS6 reps for wheels. Those are my bigger mods.
  37. #77
    Aug 11 2018
    still nothing from the dyno so got some more dragy data
  38. #78
    May 07 2016
    Please post more info on your Dragy runs. What settings on your box, what octanes, what weather, what altitude. 35,
    Sent from my
    '18 S5 - BBS / EPL
  39. #79
    Aug 11 2018
    Sent from my
    Map 3
    Outside temperature at 32f
    93 octane
    Used launch control
    Elevation 873’
    Let me know if you need more
  40. #80
    May 07 2016
    Great info! Still waiting for the B2B tuned vs stock dragy to see the impact. Not sure that’s been posted. Great progress man!
    Sent from my
    '18 S5 - BBS / EPL
