Results 1 to 11 of 11
Thread: Drop in filter?
    Jun 21 2018
    Drop in filter?
    Anyone have any experience with drop in filters for the RS3? I ultimately would go the CAI route, but that will come after warranty ends and real tuning begins. In the interim I'm looking for something that increases throttle response, provides a small power gain, and improves sound. I understand all these will be small increases, but I'll take it for now. Recommendations?
    May 03 2018
    11th gen Honda Accord Hybrid EX-L
    Jax, FL
    Drop in won't do anything for noticiable, maybe placebo effect, with throttle response.
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Think most probably just use K&N (33-3036). aFe doesn't have one out yet.
    May 03 2018
    Jax, FL
    Quote Originally Posted by jl87 View Post
    X2, been waiting and submitting requests for one to be made. But a clean OEM filter still breaths just as much air as any drop in, esp stock tuned.
    Mar 09 2018
    2018 RS3
    I noticed a slight MPG bump with the K&N. I'm sure it flows better... I also see more 18psi spikes on the P3 gauge than with the stock filter.
    Florett RS3+DS1+034TCU
    May 03 2018
    Jax, FL
    I got a huge mpg jump (150-160 mpt to 250+ miles per tank), like after 1500 miles of kicking it's butt, guess car broke in finally.
    Zero mods, just tune. Have stuff sitting here, waiting for a tuner to get me pumped up to more power on E85.
    But, want to go BT.
    Apr 02 2018
    Pennsylvania
    I installed one a week or 2 after I bought the car and I felt zero difference...but really, who is gonna feel like 3 or 4 HP on a car this powerful anyway.
    Just looking at the stock filter, the K&N drop in HAS to flow better. The stock filter has that cloth layer at the bottom which looks pretty restrictive. It doesn't look like the RS3 box has that snow screen that the S3/Golf-R/GTI guys usually remove. In fact, when you remove the stock filter to drop in a K&N the airbox actually looks pretty direct from the snorkel up to the throttle pipe.
    The real value of the K&N is that it is reusable AND you know you're getting a bit more flow at the expense of some added dirt but I assume frequent oil changes should mitigate that.
    Apr 20 2018
    Chicago
    Quote Originally Posted by Nardo_RS3 View Post
    The RS3 box does have the snow valve in the box. I noticed when I swapped out the stock filter that about 1/3 of it was completely clean (basically no air was going through that side of it. Not sure if it makes any difference taking out that snow valve as I've never had a single issue with snow clogging the entire box, but I've also never felt a single difference with an aftermarket intake or filter either.
    Aug 04 2018
    2017 Audi Q7, 2022 Silverado 2500HD
    Sacramento, CA
    2018 Nardo Blk Optic RS-3, DA, RS Design, Dynamic Package
    UNI Stg 1+ (E85) ECU, Stg 2 TCU, UNI 3"Turbo Inlet, IE Intake, 034 St.Stl Intake HTshld, Eurocode FMIC, IROZ Eng Oil Catchcan, 3D Prntd DSG Vent, OEM Euro Catless MidPI, CTE Exhst Valve Cont., 034 Upr/Lwr DgBne Insrts/Billet Arm, MSS Springs Fnt Track/Rear Sport, Eurocode SWB E.Links/Rear Strut Brc, 034 Rear SbFrm Mnt Insrts, ECS Rear Diff Mnt Insrts, Signature SV303S/Gloss Blk Barrels/Flat Blk Spokes/Slvr Hdwr, F 19x9.5+41, R 19x9.0+43
    Jul 25 2010
    WI/IL
    Removed mine yesterday, didn't notice any difference.
    May 03 2018
    Jax, FL
    You won't, only time it is good is when snow/water/#FamilyofGerbils are blocking off air into the box from the front.
