Results 1 to 12 of 12
    Veteran Member Four Rings vailshred's Avatar
    Aug 20 2011
    Arizona/Colorado
    Engine difference between the 07 and 08 Rs4 BNS
    Hi guys
    Just wondering if you know of any engine differences between the two years?
    I had someone tell me yesterday the there were changed made from the 07 to the 08.
    Is this true?
    Thanks
    May 01 2017
    Lincoln DE
    What did they say the change was?
    2008 DTM RS4
    Instagram--@tjbradney
    Aug 20 2011
    Arizona/Colorado
    Something with the injector locations or how they attach to engine?
    May 01 2017
    Lincoln DE
    I mean its direct injected im sure they didnt change anything. Maybe he meant from S4 to RS4 its different since S4 is port injected.
    2008 DTM RS4
    Aug 20 2011
    Arizona/Colorado
    Thanks but Im sure he was not talking about a s4.
    If anyone knows of a difference please fill me in.
    I have a 2007 BNS long block for sale and this guy is telling me it wont work in a 08. Im not aware of any differences in the 2 years
    Jun 15 2017
    Wisconsin
    Just had a look at ETKA and there’s no difference in part numbers for the ‘07 and ‘08 RS4.
    Aug 20 2011
    Arizona/Colorado
    Quote Originally Posted by Kenny147 View Post
    Account Terminated Two Rings
    Mar 19 2018
    Boston
    Quote Originally Posted by vailshred View Post
    There is a vin split ,some timing component are differant and also the rear chain covers on the heads are differant but that’s it
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    This is partially true.. the engine is essentially the same, however there is a VIN split in 2007. They made changes to odd things and it only effected certain part numbers.
    The engine shield for example is different.. the mount points were changed slightly and the mold is different.
    I ran into this issue on a few different part numbers when sourcing parts for my build. The BNS block was post VIN split and I remember there were a few different parts where this mattered.
    I can’t recall if the injectors were the same, though i would suspect they are.
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Jun 15 2017
    Wisconsin
    Apologies to the OP, my morning coffee hadn’t kicked in. There was a VIN split on 20 March, 2007 but I can’t see what VIN the change took place at.
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    Split happens at 7N900410. 2007-a cars are 7N900409 and lower, 2007-b cars are 7N900410 and higher. They had minor interior changes, so safe to assume some small changes in mechanical components as well.
    2005 Ferrari F430
    2007 RS4 Daytona Grey | 2008 RS4 Mugello w/Ti Package | 2007 RS4 Avus Silver (ex-Audi Corporate) | 2008 RS4 Avus Silver w/Exclusive Package
    B6 S4 Avant 6MT Dolphin Grey
    B5 S4 Avant 6MT Laser Red Stage 3+
    B5 S4 Sedan 6MT Silver Stage 1
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    aren't the valve covers different as well?
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
