Results 1 to 4 of 4
    Established Member Two Rings S4ork's Avatar
    Jun 02 2017
    2000 Kawasaki ZG1000
    Babcock Ranch, Florida
    Engine Oil Light Won't Clear
    Checked oil level and all is good. VCDS would not clear it. Checked other posts and Youtube. Only found a sensor for the hood latch and this warning light are the same. Anyone else have this issue and know how to fix it?20180725_131537.jpg
    Sent from my SAMSUNG-SM-G891A using Audizine mobile app
    2011 Audi S4 DSG Presitige w/ Drive Select, Carbon Package, Side Assist, Black Phantom Pearl, Roc-Euro Intake, 034 Trans Mount, 034 X-Brace, 034 Rear Diff Mount Inserts, 034 Rear Sway Bar, H&R Front Sway Bar, Canyon Road CR15 Front Strut Brace, ECS Lower Control Arm Brace, 034 Sub-frame Mount Inserts, APR CPS, B&M Super Cooler, 034 Density Line Adjustable Upper Control Arms, VMR 810 18x9.5 wheels, EPL 57 mm SC Pulley, Fluidampr 183 mm Crank Pulley, 3.117 Pulley Ratio, EPL TCU and DP ECU Tune
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    It's likely hood latch related. Did you happen to review this post in your search effort? The procedure the OP posted in that thread appeared to solve the issue.
    Edit ... adding that there are a lot of threads with resolutions to the problem. Hopefully one of them will be helpful for you.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    was just going to post the hood latch being the issue. Can you believe Audi linked these two items? Pretty darn funny
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Jun 02 2017
    Quote Originally Posted by LYKUNO View Post
    Excellent! Thanks very much. I took it out and cleaned it, but no luck. I'll get the hood latch and sensor ordered. Great links...very much appreciated.
