Originally Posted by
JamesRS5
Well now that you’ve said that I can’t take offence.
I did post a whole thread on dyno runs but unfortunately it all died with PhotoFucket, I used a Maha dyno (as used by Audi, BMW, Mercedes, etc) which gave some very honest results and stirred up a real hornets nest but the fact that a car in Germany and another in the UK all using the same dyno made the same power down to one decimal place tells you those machines are very accurate, that’s why the manufactures use them. I just get very sceptical on some of these big power for little mods dyno runs, you’ve gained what, almost 70hp from a stock car? That’s an amazing result for an exhaust, intake and map on a na engine.
Let me see if I can get the maps posted up, they aren’t S5 but they may be something you can compare against?
Look, I like to post messages as if I'm talking in real life, not being a keyboard warrior. For some reason on this forum there's always more speculation & bashing rather than constructive input, which doesn't happen on mercedes,bmw, etc, forums. I'm not going to defend the dyno because I mentioned before other S5's have run the same dyno and run under 300whp with almost the same amount of mods. My highest run I will repeat was on e30 so thats not a surprise gain from the 333whp on pump fuel.
If you're unsure about it making that kind of power check out Jhm's record all motor 1/4 pass with the S5 at 12.6. The Car & Driver 1/4 time for the RS5 stock was 12.5 so that means that Jhm seems to have come very close to that hp level. My car is running basically everything they had on that record setting car plus a few mods of my own. Jhm doesn't like posting dyno graphs and I get why. They post real world numbers, which I agree with and this summer I will make it to my local track and put down some 1/4 mile times and we will see what the results are. The one thing you also have to understand is cars have large differences in power, for reasons like maintenance, and even how you drive your car makes a difference because if you're stuck in traffic all the time with it, its no bueno. Before I did these recent mods, I've taken down 5.0 mustangs and the new ones, 4.7 Masterati Granturismo, 335i, and e92 M3 with mods but I must mention not the greatest driver but still.
034 motorsport has a tread showing the various stock V8 audi's and like mentioned they put down in the region of ~300awhp.
Jhm's S4 also was the highest hp 034 had tested with an ~10whp variance from others they had tested and their dyno isn't a dyno jet.
http://www.audizine.com/forum/showth...no-Comparisons
look at the win vs fail RS4 dyno graphs lol
