I wanted to create the optimal setup. Here were my requirements:
-As a student a former student of fluid dynamics I loved the incorporation of a velocity stack.
-No/minimal diameter transitions. Maintain 3.5" diameter from the bellmouth velocity stack, to the TB (which will be 3.5" in the future).
-Filter as far away from the engine/heat as possible
-aFe filter
-No welding (I never learned)
-Under $200
Here are the pics:
Throttle response is noticeably improved. The SC whine is definitely there, and louder than my friend's ECS intake.
In case this inspires someone, here is the part list with links:
https://www.amazon.com/gp/product/B002TUNY6G/ (fit recessed inside the filter, on the 4th and 5th grip lines, to optimize bellmouth design)
https://www.amazon.com/gp/product/B001ABMMW2/
https://www.amazon.com/gp/product/B01K96L9ZO/ (used a hack saw to cut 4" off, so a total of 8" in length)
https://www.amazon.com/gp/product/B01ITYD0DM/
https://www.amazon.com/gp/product/B00TGP7PW6/
https://www.amazon.com/gp/product/B073V6VBP1/
https://www.amazon.com/gp/product/B00JPZEKOS/
Also bought a pack of vacuum elbows from Advanced Auto, for the TB vacuum line, that contained several like this (NOT sure of the size I used, but it was close to stock) https://shop.advanceautoparts.com/p/...m=vacuum+elbow I cut the part on the outside of the flange off with a razor blade, so that it would not stick out into the air path. I was going to use plastic epoxy to secure this into the silicone TB connector. However, after drilling small hole in the silicone connector, and testing the fit- I found it was so tight after the trimmed flange popped through, to the inside, that I just left it alone. It is very tight, and doesn't budge when pulled on.
When the new TB is available, all I have to do is buy an 3.5" to 3.5" 45 degree coupler for $12 bucks, and I am good to go.
Heat shield is next to fab up. Sorry about the dirty intake and engine bay, and poor hose clamp positioning in the pics (probably remedy that tonight). If anyone has any questions, let me know.
