i picked up a used usp intake and while it seems like a very nice intake i wanted a velocity stack and more 4" piping
i picked up a vibrant performance 4" velocity stack that has a 7" opening. this is connected to a 4" elbow and then a 4" to 3.5" reducer to a 3.5" to 3" elbow. The whole goal of making this intake was to have as smooth as transitions as possible from the 3" tb to the 4" piping. Most intakes on the market step up in size very quickly and IMO it looks like they cheaped out on the transitions.
As of right now I do not have a heat shield made, i will do testing to see if its necessary and will most likely fabricate something (if needed)
i will be putting this on the dyno against the usp as well as the stock airbox and if i can make time i will also try to test these out at the track to see if any real performance gains are possible
the velocity stack which is very easy to run by itself if I don't want to run a filter at the track
the vibrant filter compared to the usp filter (yes it fits inside the filter!!)
