Originally Posted by
Borg54
Thanks for the detail. I worked with Apple for a long time and they can make some brilliant but also some very frustrating choices.
The other issues I’m having in my video. Do you think those are because of the iPhone 7 Plus? The screen not loading properly etc? It isn’t just an audio issue.
Sent from my iPhone using
Audizine
That is the typical USB 2.0 signal degradation symptom.
CarPlay uses a lot of USB traffic so 480mbps connection is mandatory. So the reason that the screen is not loading properly is
- USB 2.0 480Mbps High-Speed handshake is established and iPhone and the interface try to exchange packets.
- However, the signal degradation in the communication terminates 480Mbps connection, but the interface tries to keep listen to iPhone as the handshake is done.
- Thus, the screen is not properly loaded.
- It's the duty of iPhone 7+'s USB IC to maintain the communication since iPhone is the host in this case. But the ic is to say 'B grade' stuff.
If we capture the signals using a lab equipment, it would look like (a) where there is a lot of noise, whereas (b) is an error-free signal.
This can be compensated by increasing the power delivery or well-shielded cable against EMI noise. Nevertheless, it's curable only and only if the host sends out proper and strong signal in the first place.
