Results 1 to 22 of 22
Hybrid View
    Senior Member Three Rings Richieru456's Avatar
    Apr 30 2017
    New Haven, CT
    Reverse lights upgrade
    So I upgraded my reverse lights to some leds. Only ordered them because they say error free. Well I got the error smh. Anyway I can change this? Any bulbs you guys know of that you don't get an error? Do I just have to code it off? Definitely a big improvement either way.
    B8.5 gear shift retrofit | Led interior lights | Led license plate light | Led backup lights | Honey comb fog grille | Rs4 “quattro” grille | Afe dry filter | Ecs turbo inlet hose | Usp hfc w/ custom downpipe | SUMITOMO HTRZ-III on Enkei EKM3 | custom Euro plate | Carbon fiber interior trim | Audi logo flog lights | Audi logo seat belt covers | “quattro” seat stopper
    Senior Member Two Rings jorte014's Avatar
    Apr 16 2013
    Mercedes-Benz ML 350
    Coral Springs, Florida
    Maybe try this? https://www.youtube.com/watch?v=OrlJUfYwSH8
    I did it from a post on Audizine but can't find it. If I do I'll post it here.
    2014 S4 6MT - Milano Red | Premium Plus | Black Optic | Bang&Olufsen
    Feb 02 2017
    Beaverton, OR
    I have deautokey reverse leds in my 2013 allroad with no errors. Which ones did you buy?
    Apr 30 2017
    New Haven, CT
    Quote Originally Posted by chip_ View Post
    Some off amazon https://www.amazon.com/gp/aw/d/B01FI...?ie=UTF8&psc=1
    But for the extra $30, I'll just code them lol
    Veteran Member Three Rings keiffr's Avatar
    Feb 19 2014
    2006 Land Rover LR3 SE V8 4.4L
    Fresno/Clovis, CA
    +1 I've tried all the bulbs from Amazon and eBay and they all gave me an error. deautokey bulbs were the only ones that didn't give me errors. Hhttp://deautokey.com/product/audi-b6...or-free-bright
    Great company! And stands by it's product! I bought the interior LED bulb set, reverse LED bulbs and also the front turn signal LED's and I had some issues with of few of the bulbs. They sent me brand new sets with no hassle!
    2011 A4 2.0T TFSI Quattro P+/ Phantom Black
    IE Stage 1 / A5 S-Line Y-Spoke 19x8.5 Wheels Offset: ET32 / 255/35/19 General G-Max AS-05 Tires/ Solowerks S1 Coilovers
    Feb 02 2017
    Beaverton, OR
    Quote Originally Posted by keiffr View Post
    +1 I've tried all the bulbs from Amazon and eBay and they all gave me error. deautokey bulbs were the only ones that didn't give me errors. Hhttp://deautokey.com/product/audi-b6...or-free-bright
    Totally agree I run there LEDs in my allroad and GTI.
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    get 7 dollar reverse bulbs on ebay. code it out. theyre all the same build.
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    May 04 2016
    Brooklyn NY
    Quote Originally Posted by JeriQo View Post
    Does that coding completely bypass the reading or does it lower it to the energy used by the leds? I want white fogs and that's where the difference in price bothers me $30 regular leds vs. $100+ from deautokey. Any idea if carista has this feature? ( i haven't invested in a diagnosis tool yet but I'm leaning towards carista because I'm a apple guy)
    Jul 08 2015
    Quote Originally Posted by Srramirez View Post
    its just bypasses the error code.
    i have $30 ebay fanless led fog lights thats enabled as drls. 2 years no issues. the fogs never gave me error codes nor had to be coded.
    Apr 30 2017
    New Haven, CT
    Same question, can I use carista to code my led reverse lights?
    Apr 13 2017
    Lithuania
    Talking about the fog lights, I ended up using $13 leds with resistor I picked on ebay. No errors, works well. Although, they could be a little bit brighter and they throw more blueish (~6000k my guess) color than DRLs, but does look better than traditional halogen bulb.
    Apr 16 2013
    Carista doesn't have this feature. You have to use VAG-COM
    Apr 30 2017
    New Haven, CT
    Quote Originally Posted by jorte014 View Post
    Thanks. Cancelled my order lol
    Senior Member Two Rings NYDCB's Avatar
    Aug 22 2016
    Washington, DC
    What about OBDEleven?
    Deactivated Two Rings
    Dec 01 2014
    DavidhogAJ
    Philippines
    You can use resistors, but don't be in reverse for more than two minutes
    Sent from my Nexus 6 using Tapatalk
    May 04 2016
    Brooklyn NY
    Thanks, I'm assuming you used Vagcom for the fog light coding as well? Can you PM me if possible the specifics of it. I may just go for vagcom.
    Quote Originally Posted by Garebear14 View Post
    How else am I supposed to commute to work if not in reverse? Audis suck!
    Veteran Member Three Rings Roadtrippn's Avatar
    Sep 15 2011
    Hilton Head Island
    Hmmm i need to put my 300$ vagcom to use...I'm jumping on the ebay bandwagon
    18' RS3 Stage II and all the Fixn’s
    21' SQ8
    2011 A4 2.0TQ 6MT Stage III
    2001 A4 Stage II
    Dec 01 2011
    i've got LED's on my reverse bulbs i got from superbrightleds.com, i guess it has a resistor or w/e built in but it's definitely error free, says it too on the website. didn't have to do any coding or anything else just plug and play.
    IG @theshawon
    Sep 15 2011
    Hilton Head Island
    Anyone know if coding is needed for eBay tag lights?
    21' SQ8
    2001 A4 Stage II
    Veteran Member Four Rings LionKing's Avatar
    Mar 09 2017
    2009 A6 Avant - 5.2L V10 Swapped, 2013 S4 Backroads Warrior
    MD
    Quote Originally Posted by Roadtrippn View Post
    Tag light coding is not needed. The problem is, with reverse lights, our vehicles are not supposed to be using LEDs. The other problem is that's what everyone wants to run. I coded mine out and it's really easy. Personally I used a VAG-COM..
    You're first going to go to your central convenience control module, which is number 46.
    Afterwards you're going to go into Security Access (16). Input the code of 16017 and select Do It! This is going to allow you to make changes in the control module that you can't do by just clicking check boxes.
    Afterwards you're going to go into your adaptations (10), then go into channel 181 and select read. If I remember right, I had to type that in. You're next going to go into the "Value" box and instead, change that to 62463, click "test" then "save".
    Close everything out, there may be a little pop up box and hit yes. Finish closing everything out, turn the vehicle off and back on, next time you shift into reverse, there should be no error code! Don't be skittish, it isn't going to change anything but telling the vehicle that you're using LED bulbs instead of halogen.
    "Exhaust Gases go in the turbocharger and spin it, witchcraft happens, and you go faster"
    Sep 15 2011
    Hilton Head Island
    Quote Originally Posted by LionKing View Post
    Awesome thanks man. Got mine in today then did the programming. #hakerman
    21' SQ8
    2001 A4 Stage II
    Dec 01 2011
    i have LED reverse lights and LED fog lights. reverse LEDs from superbrightleds.com and fogs are the Sirius brand ones from Amazon.
    both work great, no errors at all, no vagcom or coding needed. just get the ones that have the resistors built in and say "error free", havent had any issues with those and don't need the hassle of the coding part.
    IG @theshawon
