Results 1 to 11 of 11
    Apr 11 2016
    Phoenix, Arizona
    Car died at a light for no reason, tune issue?
    I was sitting at a red light today waiting to turn left when all of a sudden my MMI screen turned off, and the screen in between the RPM and MPH on my dash died. Then then every light on my dash came on, and the car went "beeeeeeep" and then the entire car died completely. I quickly put the car in park, and restarted it and it turned on fine and I was able to get it into a parking lot. I have an obd scan tool which I used but no codes came up. Does anyone know what the hell causes this?
    Just for reference I am full APR Ultra + DP. I'm not sure if this is a tune issue, or if it is a mechanical issue.
    Thanks in advance
    21 RS6 Stage 2
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    Loose battery terminal? Alternator issue?
    *2013 B8.5 S4
    APR Stage 2+ ECU/TCU 100oct Tune, JHM 187mm CP, Injen Intake. Stasis Touring Exhaust/ Springs & Rear Sway Bar, PLM HX.
    11.468 @ 122.06mph. 90ft DA. *Totaled* RIP
    2016 B8.5 S5 Prestige - APR Stage 2+ ECU/TCU 100oct Tune, JHM 187mm, modded stock air box (Loe mod!), PLM HX, OE Springs, Stock Exhaust.
    11.264@ 124.46. Best MPH 11.269 @ 125.13
    Apr 11 2016
    Phoenix, Arizona
    I thought it might be a battery issue but it was replaced by Audi less than 6 moths ago. Then I thought about the alternator so I went to AutoZone and they tested everything, and the only thing came up was a voltage regulator failure. I'm not sure how accurate AutoZone's little handheld is but it could definitely be the problem.
    21 RS6 Stage 2
    Apr 28 2016
    ^^^A faulty voltage regulator can cause all sorts of issues. I would find out for sure if that is the case before something expensive potentially gets fried.
    *2013 B8.5 S4
    Apr 11 2016
    Phoenix, Arizona
    I'm bringing it to my shop tomorrow. This is the first time this has happened so I think I should be okay. Just wondering if this has happened to anyone else.
    21 RS6 Stage 2
    Apr 11 2016
    Phoenix, Arizona
    I just don't see how the voltage regulator could make the entire car die?
    21 RS6 Stage 2
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    Sounds like the voltage regulator is faulty. If the system detects too much voltage (over voltage condition) it shuts down the components for protection. I had this happen a couple of times, every occurrence was sitting at a light and on a hot day. As soon as I'd get going each component shut down and lost power completely until I restarted the car.
    http://www.audizine.com/forum/showth...tage+regulator
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Oct 30 2012
    Oxford, MS
    This is exactly how mine acted and I got similar codes when my battery was on the way out. Would only happen when stopped. But that you've recently had your battery replaced means the replacement battery is crap or there's another problem.
    Nov 10 2014
    Apex, NC
    my car did this once when i had 3000 miles... hasn't happened since.. freaked me out
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Apr 11 2016
    Phoenix, Arizona
    Yup, was the alternator.
    21 RS6 Stage 2
    Apr 11 2016
    Phoenix, Arizona
    My car is still having a weird problem idling. It gets super clunky and then revs itself, then the revs drop back to normal and it starts getting super clunky almost like it's cammed
    Edit: After scanning with Carista, it seems to be misfiring. My guess is the spark plugs from ultra?
    21 RS6 Stage 2
